    Leg for chair
    26 Posts 8 Posters 2.9k Views 8 Watching
      I think this TaperMaker plugin could help you with those shapes. You need to draw the path and apply the plugin. It works somewhat like the Follow me tool except you can give a value by which it will be "thinning".
        GLB
        Yes, seems interesting, I'll try and let you know the result, thanks
          GLB
          I did try the TapeMaker plugin, but couldn't find the way how to use my own profile for such leg ? If I use the ready made shapes, then how can I make the edges in fan shapes. Per attached the profile of leg I want to use. Thanks for your comments
            I think I could draw something like that. I'll do up a tutorial and post it.
            • boofredlayB Offline
              boofredlay
              Ok GLB, I made a tutorial here:
              http://www.sketchucation.com/forums/scf/viewtopic.php?f=18&t=18573
              Hope it helps.
              (Beat you Dave 😄 )
                Nevermind.
                Good work Eric.
                • X Offline
                  xrok1
                  push\pull your shape, scale one end, then use shapebender; viola!
                  • X Offline
                    xrok1
                      boofredlay
                      What does the mesh look like?
                      • X Offline
                        xrok1
                          Xrok's method is the method I was going to show. Works slick.
                            boofredlay
                            Yep, that works great as well. I just wonder about how much control you have if it needs to be precise.
                            I guess I am just a traditionalist 😄
                              If you place the line and curve properly, I think this would be an accurate method. It's certainly fast.
                              • X Offline
                                xrok1
                                yes, i think any method is as accurate as you care to make it. (unless you can create a random curve 😆 )
                                  GLB
                                  Many thanks to all of you, especially Eric with his great and clear tutorial.
                                  I do think that shape bender is the quickest solution but it seems that I have some problem with such plugin because cannot get any final result, maybe there's a bug ?
                                  So, I'll go back to work now and try to finalize such leg !
                                  • Chris FullmerC Offline
                                    There definitly bugs in the script, but they shouldn't keep it from working. I can you figure out whats wrong with it if you want,
                                    • W Offline
                                      watkins
                                      Further to another thread, perhaps someone (David?) could make a tutorial showing how shape bender may be used to make the complex shape of the chair leg.
                                      Regards,
                                      Bob
                                        Dear Bob,
                                        Were you referring to me? Would something like this work?
                                        Cheers,
                                        Dave
                                        • W Offline
                                          watkins
                                          Dear David,
                                          Exactly! As I said in another thread (http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=18210&st=0&sk=t&sd=a&start=120#p151205), Shape Bender is almost a loft tool, and so the more examples we have of its use the better.
                                          Kind regards,
                                          Bob
                                          Now, I had better go look at that video tutorial, hadn't I.
                                            GLB
                                            Hi Chris,
                                            Thanks again for your help, for the time being it seems to work quite without any problem except maybe it's not that fast but I really need to "clean" my labtop first.
