    [Plugin] Shape Bender Beta
    1.3k Posts 331 Posters 2.2m Views 329 Watching
      sepo
      As I said I loaded it on Vista qaud desktop. It works no problem there.
      It has problem on my other desktop which runs on XP.
      • Chris FullmerC Offline
        😳 mis-read that bit. sorry about that. Could you send me a model that it is not working on? (which should be easy if it is every model). If I can't find anything, I'll just release a simulatenous version that does not call progressbar.
          sepo
          It seems it was component spray. When I removed plugins one by one I just upgraded to new compospray thinking that will do the job. I made a point to update it as you asked before but it seems it still clashes with other plugins. I removed it now completely and it works like charm. Also made my protrude work again. I am really sorry to have bothered you.
            Hey, thats great!
            And not a bother at all. But the new version of component spray really should be compatible now.
            Mind trying to upgrade it one more time? Here is the link to the newest compatible version:
            404 Not Found
            (www.sketchucation.com)
              sepo
              😳 I do not know what happened when I upgraded. It works now. Thanks very much for your patience. BTW some of the forms which would have taken long time to model or were almost impossible now can be done in no time. I suggest you change the name from bend to morph because that is exactly the thing this plugin is capable of. BTW I showed the plugin to my students today. There was just one big woooow.
              Thanks once again for your patience.
                WooHoo! Glad its all working now.
                • W Offline
                  watkins
                  Dear Chris,
                  I have just installed your shape bender ruby and tried one of the shapes shown in Massimo's post. Amazing!! You really are a very clever chap.
                  It struck me that we might begin a thread where people can post tutorial examples of using your ruby to solve tricky modelling problems. Perhaps Massimo could start the thread with his two examples. This could be useful to new users of Sketchup, and also to expand the use of your ruby. As it stands it is almost a loft tool which people have been asking for for a long time.
                  Thank you for all your hard work.
                  Regards,
                  Bob
                    dylan
                    I agree Bob.
                    Seeing a few examples with explanations would be a big help to people.
                    It seems this tool is far more poerful than it first seemed!
                    http://dmdarchitecture.co.uk/
                      gaucho
                      Hi Chris,
                      Not sure if I'm doing something wrong here.
                      It shows up the right bending, but when I finally press enter, it just desapers!
                      thanks for the plugin!
                      bend problem...
                      "eat well, stay fit, die anyway..."
                        @Gaucho - Could you open the Ruby Console (Windows>Ruby Console) and then run the script. It should hopefully output a bunch of errors when you hit enter. Please copy and paste those here into the forum. That should help figure out the problem. Does it happen with every model, or just that specific example?
                        @Bob and Dylan - I agree, I didn't think about my script doing those things quite honestly. I wouldn't mind seeing more examples to help my brain understand how the script is being used. Maybe its a gallery topic? Showing off the output from a script? I could see that. Or maybe in plugins - shape bender in action! I don't know. Or maybe I can include their images in the first post of this thread to show what the script does beyond my basic tutorial video.
                        • W Offline
                          waltw
                          @chris fullmer said:
                          That sounds like it did not get installed quite right. There should a file called clf_shape_bender.loader.rb in the main plugins folder. Then there should be a folder caled "clf_shape_bender" and inside that folder should exist the files:
                          clf_shape_bender.rb
                          I'm guessing you might have ended up with everything in the main plugins folder. So manually create the clf_shape_bender folder and move all those files above into it, leaving only clf_shape_bender_loader.rb in the main plugins folders.
                          See if that is by chance the problem and let me know, thanks!
                          Thank you Chris............you were spot on
                          You're certainly taking SU to higher levels
                            dtrarch
                            Hi Chris
                            Your magic script will also do a follow and keep and no need to align to the end point.
                            Just thought y'all would like to know. ☀
                              Hey, thats a good one! Thanks for all the examples, very useful!
                              • W Offline
                                watkins
                                Dear Dtr,
                                Not sure how you have arrived at that. Is the bending done out of plane? Could you be more specific? A brief tut would be good.
                                Regards,
                                Bob
                                • massimoM Offline
                                  massimo Moderator
                                  Watkins, the plugin works also out of plane.
                                    dtrarch
                                    Watkins
                                    Reference object and reference line must be on red axis.
                                    The reference line must also be the same length as the object and offset in plan as you want.
                                    (in this case it was centered and above one of the elements)
                                    1-Pick the object
                                    2-invoke the script
                                    3-pick the reference line
                                    4-pick the path and [enter] to create the sweep.
                                    Done
                                    dtr
                                    • W Offline
                                      watkins
                                      Dear Dtr,
                                      Thanks for that. I didn't know the script would bend a group/component around a 3D path. I must pay more attention.
                                      Kind regards,
                                      Bob
                                        For the fun ☀
                                        Only problem calculates become more and more longer 😄
                                        Choose very fine your second curve and some funny surprises will arrive 💚
                                          piyanan
                                          Hello any one
                                          I did install this plugin for my SU-7
                                          Lay down plugin clf_shape_benderand clf_shape_bender_loader.rbin my Plugin then try working see at below screenshot
                                          http://www.imageupload.samuisketchup.org/images/1er6bvci8bss7pgra53.jpg
                                          1 Make group model
                                          2 click tools
                                          3 click line
                                          3 click curve
                                          And wait but notthing happen
                                          Any one to know this problem ?
                                          Thank
                                            Hmm, interesting. Does it just stop right there and not keep going? I've never seen it stall like that. So try this.
                                            Open the webconsole by going to Window>Web Console.
                                            Then run the plugin
                                            If there are any errors or any messages that pop up in the web console, copy and paste them into this thread and I'll take a look at it.
                                            • 63
                                            • 64
                                            • 7 / 64
