    Irender nxt
    extensions
    23 Posts 4 Posters 4.6k Views 4 Watching
    • C
      csilewski
      worked.. thanks.!!!
      • C
        csilewski
        I am still having problems with the Irender. For some reason it stops making the batch file about half ways through it. Any suggestions on what i may be doing wrong?
        • Al HartA
          Al Hart
          I see you have sent us a file. We will take a look.
          Al Hart
          IRender nXt from Render Plus
          • C
            csilewski
            Thanks,
            I wonder if its cause of the number of trees in the model?
            • Al HartA
              Al Hart
              @csilewski said:
              Thanks,
              Your model is over 50MB. So it is nearing the limit of what we can handle. (Or, at least larger than anything we have handled so far).
              It is currently downloading, so I haven't looked at it yet.
              We should be able to handle large models. But sometimes something shows up which we haven't handled before. Usually we can make changes to accommodate it.
              Have you tried RpTreeMaker trees - they take up much less room in the model, and render much better with IRender nXt then high-poly trees.
              Al Hart
              • C
                csilewski
                I tried tree maker and i love it..! Works great. Every tree in the model was made using that program. I do have on tree maker question. as you will see i made a tree that was was a pear blossom, so i used a png. file that was just the white bud. When it rendered out the buds showed up almost black. is it possble there was somthing wrong with the png file used to make the buds?
                • GaieusG
                  Should have a look at that png file but it can be because pgn transparency only works above a certain number of bit colour (can't remember) and otherwise the transparent channel simply renders black. But I am not very good at these things so you'd better check elsewhere, too. Or share the png image here so we can see.
                  • Al HartA
                    Al Hart
                    As was implied in Gai's response - you have to be sure that you used a PNG file with a transparent background.
                    Al Hart
                    • C
                      csilewski
                      Here is the png. i used.
                      • Al HartA
                        Al Hart
                        It is definitely transparent and works in treemaker properly.
                        We are probably not passing it to the renderer properly.
                        (I placed the image as leaves on this tree. It looks fine inside of treemaker)
                        Al Hart
                        • C
                          csilewski
                          ya i don't know what to think of it.. i rendered the trees in a sperate file that contained just the trees and they look great but when there rendered in the my big file they turn black.
                          • C
                            csilewski
                            So i figured out why the trees where rendering black,
                            I made the trees with Tree Maker on one computer and then transfered them over to another computer to render out with Irender. when i did that apparently the leaf information did not transfer resulting in no images to make the leafs.
                            • GaieusG
                              That would still be weird. Components are supposed to be transferable between computers and SU versions.
                              • C
                                csilewski
                                The components where transfered but it seamed like the rendering information that went along with the trees got lost in the transfer.
                                • Al HartA
                                  Al Hart
                                  The RpTreeMaker definition contains the path name of the leaf, but not the leaf itself.
                                  We need to store the leaf on the the definition or on the component to make them more portable. We will have to add that to RpTreeMaker.
                                  Al Hart
                                  • GaieusG
                                    That's OK but once a SU component is made,it does contain the image (well, the whole, rendered image I mean), doesn't it?
                                    I see we are talking about two different thing however - I thought the component showed up black, sorry.
                                    • C
                                      csilewski
                                      They rendered black, on a different computer. But after i downloaded rp Tree Maker to that computer and then replaced all the original leaves with custome ones they rendered out great. So lesson learned i guess.
                                      • Al HartA
                                        Al Hart
                                        I'm glad you found a way to make the trees work. However, it is our feeling that our users shouldn't have to do that much work. But it will be a little while before I get around to saving the leaf images on the component itself.
                                        I am still getting ready to take a look at your large model. (There were some other things I had to clear up first)
                                        Al Hart
                                        • Al HartA
                                          Al Hart
                                          Interim Report
                                          The trees were indeed the problem during the extract. We sere exploding the trees into 3D faces, which we did not need to do until we were ready to render. I should be able to get the extract to work. (It is at 36% now and is not running out of memory yet.)
                                          The trees will probably be a problem when the Batch Rendering process starts. (It will take some time to get that far - this is a very large model even without exploding the trees). I will see what I can do, but we may have to hide any trees which are not visible.
                                          We have the ability to explode the geometry for similar trees only once - but we have not implemented that feature yet. I'll see what happens when the Batch Process starts.
                                          Al Hart
                                          • C
                                            csilewski
                                            Thanks Al I just made a seperate file for every view and deleted the trees that were not showing up in that view. We made it work... right now i have the NXT version of Irender is that and bonus to using the Beta Version, and how well does the landscape side of the program work with revit? Specifically the trees and sod.?
                                            With your input, this post could be even better šŸ’—
