    šŸ”Œ Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
    Irender nxt
    extensions
    23 Posts 4 Posters 3.2k Views 4 Watching
    • soloS Offline
      Use the batch render option.
        csilewski
        worked.. thanks.!!!
          csilewski
          I am still having problems with the Irender. For some reason it stops making the batch file about half ways through it. Any suggestions on what i may be doing wrong?
          • Al HartA Offline
            Al Hart
            I see you have sent us a file. We will take a look.
            Al Hart
            IRender nXt from Render Plus
              csilewski
              Thanks,
              I wonder if its cause of the number of trees in the model?
              • Al HartA Offline
                Al Hart
                @csilewski said:
                Thanks,
                Your model is over 50MB. So it is nearing the limit of what we can handle. (Or, at least larger than anything we have handled so far).
                It is currently downloading, so I haven't looked at it yet.
                We should be able to handle large models. But sometimes something shows up which we haven't handled before. Usually we can make changes to accommodate it.
                Have you tried RpTreeMaker trees - they take up much less room in the model, and render much better with IRender nXt then high-poly trees.
                Al Hart
                  csilewski
                  I tried tree maker and i love it..! Works great. Every tree in the model was made using that program. I do have on tree maker question. as you will see i made a tree that was was a pear blossom, so i used a png. file that was just the white bud. When it rendered out the buds showed up almost black. is it possble there was somthing wrong with the png file used to make the buds?
                    Should have a look at that png file but it can be because pgn transparency only works above a certain number of bit colour (can't remember) and otherwise the transparent channel simply renders black. But I am not very good at these things so you'd better check elsewhere, too. Or share the png image here so we can see.
                    • Al HartA Offline
                      Al Hart
                      As was implied in Gai's response - you have to be sure that you used a PNG file with a transparent background.
                      Al Hart
                        csilewski
                        Here is the png. i used.
                        • Al HartA Offline
                          Al Hart
                          It is definitely transparent and works in treemaker properly.
                          We are probably not passing it to the renderer properly.
                          (I placed the image as leaves on this tree. It looks fine inside of treemaker)
                          Al Hart
                            csilewski
                            ya i don't know what to think of it.. i rendered the trees in a sperate file that contained just the trees and they look great but when there rendered in the my big file they turn black.
                              csilewski
                              So i figured out why the trees where rendering black,
                              I made the trees with Tree Maker on one computer and then transfered them over to another computer to render out with Irender. when i did that apparently the leaf information did not transfer resulting in no images to make the leafs.
                                That would still be weird. Components are supposed to be transferable between computers and SU versions.
                                  csilewski
                                  The components where transfered but it seamed like the rendering information that went along with the trees got lost in the transfer.
                                  • Al HartA Offline
                                    Al Hart
                                    The RpTreeMaker definition contains the path name of the leaf, but not the leaf itself.
                                    We need to store the leaf on the the definition or on the component to make them more portable. We will have to add that to RpTreeMaker.
                                    Al Hart
                                      That's OK but once a SU component is made,it does contain the image (well, the whole, rendered image I mean), doesn't it?
                                      I see we are talking about two different thing however - I thought the component showed up black, sorry.
                                        csilewski
                                        They rendered black, on a different computer. But after i downloaded rp Tree Maker to that computer and then replaced all the original leaves with custome ones they rendered out great. So lesson learned i guess.
                                        • Al HartA Offline
                                          Al Hart
                                          I'm glad you found a way to make the trees work. However, it is our feeling that our users shouldn't have to do that much work. But it will be a little while before I get around to saving the leaf images on the component itself.
                                          I am still getting ready to take a look at your large model. (There were some other things I had to clear up first)
                                          Al Hart
                                          • Al HartA Offline
                                            Al Hart
                                            Interim Report
                                            The trees were indeed the problem during the extract. We sere exploding the trees into 3D faces, which we did not need to do until we were ready to render. I should be able to get the extract to work. (It is at 36% now and is not running out of memory yet.)
                                            The trees will probably be a problem when the Batch Rendering process starts. (It will take some time to get that far - this is a very large model even without exploding the trees). I will see what I can do, but we may have to hide any trees which are not visible.
                                            We have the ability to explode the geometry for similar trees only once - but we have not implemented that feature yet. I'll see what happens when the Batch Process starts.
                                            Al Hart
                                            • 2 / 2
