    [WIP] Discworld - Ankh Morpork - Assassin's Guild
    75 Posts 14 Posters 11.7k Views 14 Watching
      That's what I thought initially. But the extra lines next to it plus the fence-looking lines confuses me. And I can't see it making much sense. But it's not a real building anyway, so I'll just decide on something.
        @sepo said:
        I don't think it is meant like that. It is straight wall which has return. Railing is to close void (light for basement).
        Yea, I was leaning towards this. though it seems it's not quite straight. But I guess that's the hand sketch nature of it.
        Fence in front of basement makes sense, but there's a second set of railings of some sort on the second level.
          sepo
          I think that is balcony with railings. That balcony slab goes full depth of the projecting parts. You are right as it is hand sketch that balcony slab confuses further.
            I think I might have it now. The left most part that sticks out is deeper that it appears in the drawing.
              Hmm... A revision here:
                Ah! I see it now. There's some support underneath the balcony. That'd be a neat feature to model. Though the railing looks too short.
                  remus
                  I see what you mean, your revision is looking good πŸ‘
                    sepo
                    I do not see it tapering like that. It goes agains logic of Gothic. I even think the left part projects for 450-600 mm to allow cornices to return properly. In that case railing goes past one on the right. Also I think You had your right bit correct first time.
                    It appears there are some stone springers under the balcony on the first floor (you call it second)
                      Yea. I keep doing that. In Norwegian we don't have 'ground floor'. The floor at the ground is the 'first floor'.
                      Anyone got an idea of what the features above the windows are?
                        Third revision.
                        Thanks guys. I know it's neat picking being so obsessed about details in a sketch drawing, but... I like details. πŸ˜„
                          sepo
                          These are stone profiles which project. They are usually profiled. They are decorative and not really gothic...but than again the building looks more Victorian play of Gothic than true excersize in style.
                          BTW again your right corner would never return dead in the corner of the building so I am convinced the return is 90 rather than 45 or so exactly like you did first time.
                            sepo
                            Railing to ground floor needs to go further to front of the left piece so that it allows railing to go past right piece and than return 90 to the corner.
                              I'm not on top of the term used.
                              I'm not sure what this means.
                              Return? Where the outset wall meets the original wall? I didn't intend changing that from the WIP model, which does 'return' before the corner. It was just the quick draft. (If I understood this right...)
                                Gotcha! Nice observation. πŸ‘
                                  I'm not surprised that style clashes. Sketcher isn't an architect.
                                  Do you know of any city's or building that'd be nice reference inspiration for further detailing?
                                    sepo
                                    Quick sketch
                                      sepo
                                      Now that looks much better. It is difficult one to pin on any city. I would think if the sketches are done by Terry or his mate they would probably reference what they know. A lot of town halls are doen in Gothic revival in England.
                                        Ah, the balcony sticks further out. That would explains why the left side doesn't look deeper than the right.
                                        Thanks Sepo.
                                        Can I assume you're an architect? (They are usually good at spotting these things.)
                                          I think Ankh is based quite a bit on old London.
                                            sepo
                                            Yes , I am Chartered Architrect, practising one but also lecturer at University of Northampton.
                                            • 4 / 4
