    [WIP] Discworld - Ankh Morpork - Assassin's Guild
    75 Posts 14 Posters 16.3k Views 14 Watching
      remus
      I see what you mean, your revision is looking good πŸ‘
        sepo
        I do not see it tapering like that. It goes agains logic of Gothic. I even think the left part projects for 450-600 mm to allow cornices to return properly. In that case railing goes past one on the right. Also I think You had your right bit correct first time.
        It appears there are some stone springers under the balcony on the first floor (you call it second)
          Yea. I keep doing that. In Norwegian we don't have 'ground floor'. The floor at the ground is the 'first floor'.
          Anyone got an idea of what the features above the windows are?
            Third revision.
            Thanks guys. I know it's neat picking being so obsessed about details in a sketch drawing, but... I like details. πŸ˜„
              sepo
              These are stone profiles which project. They are usually profiled. They are decorative and not really gothic...but than again the building looks more Victorian play of Gothic than true excersize in style.
              BTW again your right corner would never return dead in the corner of the building so I am convinced the return is 90 rather than 45 or so exactly like you did first time.
                sepo
                Railing to ground floor needs to go further to front of the left piece so that it allows railing to go past right piece and than return 90 to the corner.
                  I'm not on top of the term used.
                  I'm not sure what this means.
                  Return? Where the outset wall meets the original wall? I didn't intend changing that from the WIP model, which does 'return' before the corner. It was just the quick draft. (If I understood this right...)
                    Gotcha! Nice observation. πŸ‘
                      I'm not surprised that style clashes. Sketcher isn't an architect.
                      Do you know of any city's or building that'd be nice reference inspiration for further detailing?
                        sepo
                        Quick sketch
                          sepo
                          Now that looks much better. It is difficult one to pin on any city. I would think if the sketches are done by Terry or his mate they would probably reference what they know. A lot of town halls are doen in Gothic revival in England.
                            Ah, the balcony sticks further out. That would explains why the left side doesn't look deeper than the right.
                            Thanks Sepo.
                            Can I assume you're an architect? (They are usually good at spotting these things.)
                              I think Ankh is based quite a bit on old London.
                                sepo
                                Yes , I am Chartered Architrect, practising one but also lecturer at University of Northampton.
                                  sepo
                                  here is my local Guildhall... try to find more work by this guy...He was quite good.
                                  http://en.wikipedia.org/wiki/Northampton_Guildhall
                                    The sketch is from Stephen Briggs map.
                                    ..., so I began browsing through books of all the UK's main walled cities. I found one which fitted my requirements (Its name being withheld to prevent civil lawsuit)
                                    This is talking mainly about the street map structure though. But I'd think the illustration, which also came from the book, might be inspired from the same books.
                                      sepo
                                      Gothic revival is more likely as that size of houses were not known in London in middleages AFAIK
                                        Thanks. Unfortunately I haven't got much references to similar architecture in Norway. So I can't just take a walk around sampling inspiration. But I can use the internet of course if I only know what I'm looking for.
                                        Going to London next week. I'll bring my camera and drop by the old town. Should be some there I expect.
                                          Good point. This would be a skyskraper I suppose.
                                            Did the feature above the windows have a specific name?
                                            • 1 / 4
