    Column capital
    48 Posts 6 Posters 6.1k Views 6 Watching
    • K
      Kus
      o sorry... downloaded in: Library/Application Support/Google SketchUp 7/ Sketchup/Materials
      I am on a Mac...
      • GaieusG
        But what did you download? GTX is not an image format nor a sketchup material format.
        • K
          Kus
          I downloaded it from here http://www.spiralgraphics.biz/packs/download.htm
          • GaieusG
            OK, that's for Genetica - a texture generator software. There is a free viewer for it (where you can load these textures and export "usable" formats).
            Cool app, BTW - and the "real" product, the editor is worth every penny.
            • K
              Kus
              ok... i have the textures... now I would only need some vegetation on it... how do I do that??... the main problem is that nothing doesn't "fit"
              • GaieusG
                I think the best would be to download some vegetation (like ivy) images with transparent background and place them onto a billboard face in front of the capital. This would also make sure that it looks realistic (the leaves are a bit farther from the capital instead of being "painted" on it)
                • K
                  Kus
                  Great now I am done with that thx!!... but for the same project I would like to make some drawings on a sphere. I downloaded the Surface Tool but when I start up SU this comes up
                  no such file to load -- /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/BZ_Dir_12/bezierspline_main.rbError Loading File bezierspline.rb
                  I downloaded the plugin into /Library/Application Support/Google SketchUp 7/SketchUp/Plugins; and I didn't change the name of the folder, but it is named: ToolsOnSurface_131-1
                  what should I do??
                  • GaieusG
                    Obviously something is missing from Fredo's plugins (or someother plugin that would be needed). You'd better post this in the Ruby forum because the folks there may know what to do.
                    • GaieusG
                      Hm. The image doesn't want to load - I can't really compare. Why don't you attach it to the post instead?
                      • K
                        Kus
                        OK... I didn't get it working... so I decided to go another way... Here You see a picture that I have made (the finished project must be clean). But when I compare my birds to the 1 on the picture bellow they are pretty different. How can I make them more alike? The main problem are the visible edges.
                        poljanci.skp
                        • K
                          Kus
                          i did that... hope that it is fixed
                          • GaieusG
                            Now this is definitely a question of the segmentation of curves. With more segments, your design would be much more "smooth" and similar to that of the image.
                            I saw you post your question in the ruby forum (hope someone will answer - I don't have that plugin currently installed). What exactly did you try to achieve with it?
                            • K
                              Kus
                              well I wanted to make a school-boy smilie, that would fit in to the context that I need to fill... well I went with the school logo but I don't know how to make it smoother... I heard of CAD importing, but I don't know how...
                              • K
                                Kus
                                i guess that I need to import a dwg image... but how to I make a jpg file a dwg one??
                                http://www.gimnazija-poljane.com/P/LogoGimp.png?pic=5
                                • GaieusG
                                  You can either use software that "converts" raster images to vector images (Google some and find out which suites you) or use curves (arcs, beziers etc.) with higher line segments than what you are currently using when tracing around your image.
                                    wintopo free did this quickly - you'll see it's all 'steppy' because of the raster pixels becoming lines... You could quickly redraw over it to improve it before importing to SUp...Image of DWG convertionImage of DWG imported into SKP pushpulledDWG inside zip fileSKP with DWG imported
                                    • K
                                      Kus
                                      great... it looks great from far... but up close you can see the "steppyness"... I am on a mac... can't find a program that can open dwg files... can some1 tell me if there is a free 1??
                                        A Mac limits you a bit, but try this site http://www.lemkesoft.com/lemkesoft.html
                                        If you are on a budget this site has 'free' shareware ($30/35 each) (I think with unlimited use - it's up to you to be honest) for 2d-CAD and Image manipulation - including GraphicConverter which can change virtually any raster-image into many other raster-formats and also vectorize them too... I think that CADintosh only exports as DXF [that can be used in SUp], but it can import other file formats that you can first vectorize from raster-images with GraphicConverter [like HPGL and PICT]... If you have a DWG you can always import a DWG into SUp, and if the 2d drawing is too intense with that then export it as JPG or DXF into GCon' or CADin' etc...
                                        • K
                                          Kus
                                          well I have downloaded the GraphicConverter but don't know how to change it to be able to change in SU...
                                          • K
                                            Kus
                                            No problem... I have corrected it in SU... it turned out great!!! 😍
                                            • 1 / 3
