    Vray reflection mapping
    renderpluginsextensions
    55 Posts 8 Posters 27.8k Views 8 Watching
    • soloS
      Guys, this is probably slightly off topic however I need to know about Vue to vray integration of HDR images, I have created a simple .hdr sky and wanted to know how it works with Vray (I suck at Vray hdri usage) so if a knowledgable user could try the attched file and let me know i would appreciate it.
      Vue created hdr image
        Hmm... That's and odd HDRI sky. Why isn't the horizon flat?
        Do you know what kind of format this HDR are supposed to be?
        I tried with spherical mapping. But it just came out odd. The first two have Verical Repeat of 3. The last two 1.
        (Why doesn't the multiple upload work?)
        • soloS
          Great, I did something that I would normally not do so the result is as expected, I have another one that was done the standard way attached, the horizon should be fine now.
          Could you post a quick walkthrough as to your setup? I need to know how to create hdr image renders in Vray sometime.
          solotest1.zip
            That still doesn't look like an environment image. It needs to be covering 360 degrees. Spherical, cube cross format for instance.
            • soloS
              Okay, then if I render the sky as a spherical 360 panarama and save as hdr it may work, lemme give that a go
                My setup: With default physical camera settings:
                • Load the HDR image into the GI and Background maps
                • Set the mapping to Environment
                • Set Multiplier to 50 (Depending on the HDR, usually somewhere between 20-50. GI and Background often have slight different values.)
                • Adjust the Horizontal Rotation to orient the HDR sky as I want.
                • soloS
                  This is my archilles heal.
                  • soloS
                    This one should be perfect.
                    solotest2.zip
                    • soloS
                      Which one?
                      The global one or the image/texture editor one?
                        Which one?
                        The one in the Texture Editor.
                          Looking more into this, there seems to be a bug.
                          When you add a bitmap to the reflection slot in a V-Ray material, the bitmap is not used and you get instead a 100% even reflection.
                          So far, the only way I've managed to work around it has been by applying the bitmap to the Fresnel slot in a Fresnel map, setting the IOR very high.
                          All other map types seem to work, but VfSU (1.05.30) doesn't seem to use Bitmaps for reflection map type. Odd that it works by adding a bitmap inside a Fresnel, but not adding a bitmap into a Blend map.
                            Solo; just read thsi in the Vue manual:
                            Panoramic View
                            Real panoramic cameras are fixed to a handle that you have to hold when you take the shot. As it
                            takes the shot, the camera rotates around the handle, thus embracing any required angle of view.
                            Panoramic views can yield beautiful results.
                            This option is a numerical equivalent to the real panoramic camera. Here also, the camera is rotated
                            as the render engine makes progress. All-around panoramas can be achieved this way, but
                            beware: if the camera is not perfectly horizontal when you take the shot, the horizon will undulate.
                            This is not a numerical artifact: it happens also in the real world!
                            When you select this option, the panoramic
                            H Angle slider becomes available, letting
                            you decide on the horizontal angle swept by
                            the camera as it rotates.
                            This appear to be what happened to your VUE environments.
                            • 3 / 3
