SP3x Apr3 version.
36 Posts 10 Posters 4.6k Views 10 Watching
    CPhillips
    SP3x is an experimental version of SketchyPhysics. At this point is is very much the same as the main version and all models made with SP3x should work fine in RC1 (and 3.0). But it exposes a few features for the hard core model creator. Specifically in the scripting area.
    There will be a Win SP3.0 release soon. Mac may take a big longer because we are still having WebDialog problems. Safari blows btw.
    The change from this version from the RC1 are:
    Exposed onTick and onTouch fields for bodies.
    Fixed camera FOV not being saved. This change will also be in 3.0.
    Win installer.
    http://sketchyphysics2.googlecode.com/files/SetupSketchyPhysics3x-Apr2.exe
    Mac and Win in a zip.
    http://sketchyphysics2.googlecode.com/files/SP3x-Apr5-MacAndWin.zip
    Details on the events and script commands in next post.
    • N Offline
      nosam55
      i downloaded it and when i open SU a box pops up with "Error Loading File sketchyphysics.rb
      unknown error"
        CPhillips
        Hmm. Wonder what I broke. Can you do this. Load sketchup. Skip the error. Open the Ruby console under the windows menu. And then type this into the bottom part.
        load 'sketchyphysics.rb'
        and post the error it prints.
          CPhillips
          Ah, I think I found the problem. I updated it. Let me know if it still errors.
            CPhillips
            sorry, I am out of time to write up the script commands tonight. But here is a sample that demos a few of them.
            AutoAimingGun5-Goal-Sunspawn.skp
              BTM
              ...So, once again, no mac yet?
              • F Offline
                FredIIVX
                Im not 2 great at scripting, so could you tell me how 2 control the sound, e.g. play a gunshot.wav when joybutton('RB') is pressed? I tried different variations of things like this joybutton('rb'); playsound('gunshot.wav') but can't get it 2 work -- Edit --
                DW i resloved it in the end
                  Sgt.A.Johnson
                  You always have to wait for everything on mac. My dad has one and it really annoyed me cos my pc at home wouldn't run sketchy physics and there was no sketchy physics on mac. At least i have my laptop now. not the best processor but more than enough RAM to make up for it.
                    MrPlanet
                    Are we allowed to post this version?
                    I reject your reality and substitute my own.
                      MrPlanet
                      Oh, yes and please could you post a zip file of this? Thanks.
                        CPhillips
                        Sorry, I had trouble with the PC version and ran out of time. I will post it tonight.
                          CPhillips
                          It should be ok. Just be aware some things could change.
                          I will outline some of the hazards in my script post. I will finish that tonight. Its too nice a day here to spend indoors.
                            Physicsguy1
                            Can you use your own sound files?
                              CPhillips
                              Nope! 😄 That was the problem I discovered soon after I got sound working. I cant possibly include a decent library of sounds, for one thing they are just too big.
                              What I am going to do instead is make it possible to embed .WAV files into the Sketchup model. That way you can put whatever sounds (or music) you want in. AND the copyright issue isn't my problem anymore.
                                Physicsguy1
                                How should i achieve this?
                                  BTM
                                  You can't right now. If you want someone else to get the sound file, post it on the forum or somewheres else, and tell them to go get it 😆
                                    CPhillips
                                    Thats right. But I'll get the embedded sound working asap.
                                      phy
                                      how, i can't get it to work
                                      Tableau de comparaison de Staxyn s'agit d'un mГ©dicament uniquement sur ordonnance.
                                        BTM
                                        its: playsound("gunshot.wav");100
                                        the;100 represents the value of the emitter's strength.
                                          Physicsguy1
                                          would playsound('gunshot.wav');-(a)*500 work?
                                          1 / 2
