    [Plugin]SketchyPhysics3 beta.
    69 Posts 14 Posters 28.0k Views 14 Watching
    • C
      CPhillips
      Looks like I forgot a library "dl.bundle" in the latest version. Ill update it as soon as I can.
      • L
        l.frisken
        the joint connector isn't working at all for sp3 but is for sp2, even when I reinstall it. not much point sending a scene file, as it was just a box and a sphere with the joint grouped with the box. oh, and when I try to connect the hinge joint it shows a wireframe version of it's self at the axis. this is very strange!
        • W
          Wacov
          A scene might help, you never know. But could you post a picture(s) of what's happening?
          • L
            l.frisken
            just after I clicked on the joint to connect it to the sphere...
            Screenshot
            • W
              Wacov
              That's always happened to me! I never mentioned it before... but the joints still got connected. Just to check, you are clicking the hinge, then ctrl/clicking the spehere, aren't you? I see you're using the beta; try RC1.
              • C
                CPhillips
                There is a bug in either my code or Sketchup that doesnt always draw the bounding volume for newly connected joints. It that the problem you are having?
                • L
                  l.frisken
                  yes, but it also doesn't connect. RC1? is that sp3? It work fine for me with sp2.
                  • L
                    l.frisken
                    ok tried with rc1 with no success. ctr clicking on joint then sphere is stll not producing results
                    • W
                      Wacov
                      This is what I see... like I said, it still works, but here you can see the ghost joint;
                      Selected joint
                      Connected joint
                      Wierd.
                      • L
                        l.frisken
                        mine does that but it refuses to connect. Very strange 😢
                        • C
                          CPhillips
                          Could you try one more time. But this time open the Window->Ruby Console before you try to connect them. Then cut and paste any text after it fails.
                          • P
                            phy
                            Try clicking on the sphere and then ctrl clicking on the joint. That's how I've always connected joints.
                            Tableau de comparaison de Staxyn s'agit d'un mГ©dicament uniquement sur ordonnance.
                            • L
                              l.frisken
                              ok, will try cphillips.
                              phy, I have tried that, and it works fine with sp2 but not with sp3 for me
                              • L
                                l.frisken
                                this is the ruby script from creating the joint, grouping it with he rectangular prism, and then attempting to connect it:
                                First click
                                potentialParent #<Sketchup;;Group;0x86b5238>
                                onSelectionAdded
                                onSelectionBulkChange1
                                Webdialog set to#<Sketchup;;Group;0x8681b30>
                                onSelectionCleared
                                Webdialog set to#<Sketchup;;Group;0x86b5238>
                                onSelectionBulkChange2
                                onSelectionBulkChange0
                                onSelectionAdded
                                Webdialog set to#<Sketchup;;Group;0x8675518>
                                onSelectionCleared
                                No version.
                                Inspecting model for errors
                                onSelectionAdded
                                onSelectionCleared
                                onSelectionAdded
                                Webdialog set to#<Sketchup;;Group;0x86a78a0>
                                • C
                                  CPhillips
                                  That doesnt look like the joint even tries to connect. Are you sure you are holding down the correct key (ctrl on the left side of the keyboard) when you are trying to connect?
                                  • L
                                    l.frisken
                                    I did use the left ctrl. It worked with sp2 which is strange, but I'll try right ctrl just in case it is a problem with my keyboard.
                                    • L
                                      l.frisken
                                      ok thankyou cphillips for solving the prob! I wasn't using the left ctrl like I usually do because I broke my left arm recently, and it is easier to use the right one on my laptop keyboard! but the is still that little glitch with the box in the wrong spot!
                                      • C
                                        CPhillips
                                        Sorry to hear that. I broke my arm last year and hardly used the computer the whole time it was healing. It was actually kinda nice....
                                        I'll make a note to hook up the right ctrl and shift keys.
                                          Alpha Wing
                                          I had this problem.... Error starting simulation undefined method... nilclass.... etc.......... I need help!
                                          • 3 / 4
