    [Plugin]SketchyPhysics3 beta.
    69 Posts 14 Posters 28.0k Views 14 Watching
    • C
      CPhillips
      That version has some serious bugs in it that we are trying to fix. Sounds wont exactly be in the next release. More like the one after that.
      • B
        BTM
        ...What I think he was talking about is the fact that, when the control pannel is selected, and you use keyboard input (w,a,s,d for the most part), the mac's "alert sound" goes off, and if the key is held, repeats. It can get quite annoying... 😄
        ...If that's not what he was talking about, I might aswell have mentioned that anyways, even though you probably already knew about it.
        • C
          CPhillips
          I didnt know about that bug. I wonder why it would do that.
          But the version he is talking about does have some sound support. Not full on sounds. But you can play a sound when something happens.
          • B
            BTM
            By the way, doesn't he mean mac alpha 2? Or am I not keeping up with what's going on?
            • B
              BTM
              • C
                CPhillips
                Next version of both Win and Mac was going to be beta2. Now it looks like both will be Release Candidates.
                • P
                  phy
                  no i meant beta 2
                  Tableau de comparaison de Staxyn s'agit d'un mГ©dicament uniquement sur ordonnance.
                  • P
                    phy
                    That is cool.
                    • T
                      Trimmer
                      Hi Guys,
                      I'm A newbie to this forum but the excitement that your work has brought to SketchUp has led me to watching these post for a wile now.
                      I finally downloaded the file "SketchyPhysics3RC1-MacAndWin" yesterday. I installed into both operating systems. everything seems to work perfectly in the PC, but the MAC is giving me this "Load Error" message:
                      Error Loading File sketchyphysics.rb
                      no such file to load -- dl
                      Any advice you can give me?
                      P.S. Love what you Guys are doing!
                      • C
                        CPhillips
                        Looks like I forgot a library "dl.bundle" in the latest version. Ill update it as soon as I can.
                        • L
                          l.frisken
                          the joint connector isn't working at all for sp3 but is for sp2, even when I reinstall it. not much point sending a scene file, as it was just a box and a sphere with the joint grouped with the box. oh, and when I try to connect the hinge joint it shows a wireframe version of it's self at the axis. this is very strange!
                          • W
                            Wacov
                            A scene might help, you never know. But could you post a picture(s) of what's happening?
                            • L
                              l.frisken
                              just after I clicked on the joint to connect it to the sphere...
                              Screenshot
                              • W
                                Wacov
                                That's always happened to me! I never mentioned it before... but the joints still got connected. Just to check, you are clicking the hinge, then ctrl/clicking the spehere, aren't you? I see you're using the beta; try RC1.
                                • C
                                  CPhillips
                                  There is a bug in either my code or Sketchup that doesnt always draw the bounding volume for newly connected joints. It that the problem you are having?
                                  • L
                                    l.frisken
                                    yes, but it also doesn't connect. RC1? is that sp3? It work fine for me with sp2.
                                    • L
                                      l.frisken
                                      ok tried with rc1 with no success. ctr clicking on joint then sphere is stll not producing results
                                      • W
                                        Wacov
                                        This is what I see... like I said, it still works, but here you can see the ghost joint;
                                        Selected joint
                                        Connected joint
                                        Wierd.
                                        • L
                                          l.frisken
                                          mine does that but it refuses to connect. Very strange 😢
                                          • C
                                            CPhillips
                                            Could you try one more time. But this time open the Window->Ruby Console before you try to connect them. Then cut and paste any text after it fails.
                                            • 3 / 4
