    [Plugin]SketchyPhysics3 beta.
    69 Posts 14 Posters 27.2k Views 14 Watching
      BTM
      By the way, doesn't he mean mac alpha 2? Or am I not keeping up with what's going on?
        BTM
          CPhillips
          Next version of both Win and Mac was going to be beta2. Now it looks like both will be Release Candidates.
            phy
            no i meant beta 2
            Tableau de comparaison de Staxyn s'agit d'un mГ©dicament uniquement sur ordonnance.
              phy
              @cphillips said:
              I didnt know about that bug. I wonder why it would do that.
              But the version he is talking about does have some sound support. Not full on sounds. But you can play a sound when something happens.
              That is cool.
                Trimmer
                Hi Guys,
                I'm A newbie to this forum but the excitement that your work has brought to SketchUp has led me to watching these post for a wile now.
                I finally downloaded the file "SketchyPhysics3RC1-MacAndWin" yesterday. I installed into both operating systems. everything seems to work perfectly in the PC, but the MAC is giving me this "Load Error" message:
                Error Loading File sketchyphysics.rb
                no such file to load -- dl
                Any advice you can give me?
                P.S. Love what you Guys are doing!
                  CPhillips
                  Looks like I forgot a library "dl.bundle" in the latest version. Ill update it as soon as I can.
                    l.frisken
                    the joint connector isn't working at all for sp3 but is for sp2, even when I reinstall it. not much point sending a scene file, as it was just a box and a sphere with the joint grouped with the box. oh, and when I try to connect the hinge joint it shows a wireframe version of it's self at the axis. this is very strange!
                    • W Offline
                      Wacov
                      A scene might help, you never know. But could you post a picture(s) of what's happening?
                        l.frisken
                        just after I clicked on the joint to connect it to the sphere...
                        Screenshot
                        • W Offline
                          Wacov
                          That's always happened to me! I never mentioned it before... but the joints still got connected. Just to check, you are clicking the hinge, then ctrl/clicking the spehere, aren't you? I see you're using the beta; try RC1.
                            CPhillips
                            There is a bug in either my code or Sketchup that doesnt always draw the bounding volume for newly connected joints. It that the problem you are having?
                              l.frisken
                              yes, but it also doesn't connect. RC1? is that sp3? It work fine for me with sp2.
                                l.frisken
                                ok tried with rc1 with no success. ctr clicking on joint then sphere is stll not producing results
                                • W Offline
                                  Wacov
                                  This is what I see... like I said, it still works, but here you can see the ghost joint;
                                  Selected joint
                                  Connected joint
                                  Wierd.
                                    l.frisken
                                    mine does that but it refuses to connect. Very strange 😢
                                      CPhillips
                                      Could you try one more time. But this time open the Window->Ruby Console before you try to connect them. Then cut and paste any text after it fails.
                                        phy
                                        Try clicking on the sphere and then ctrl clicking on the joint. That's how I've always connected joints.
                                          l.frisken
                                          ok, will try cphillips.
                                          phy, I have tried that, and it works fine with sp2 but not with sp3 for me
                                            l.frisken
                                            this is the ruby script from creating the joint, grouping it with he rectangular prism, and then attempting to connect it:
                                            First click
                                            potentialParent #<Sketchup;;Group;0x86b5238>
                                            onSelectionAdded
                                            onSelectionBulkChange1
                                            Webdialog set to#<Sketchup;;Group;0x8681b30>
                                            onSelectionCleared
                                            Webdialog set to#<Sketchup;;Group;0x86b5238>
                                            onSelectionBulkChange2
                                            onSelectionBulkChange0
                                            onSelectionAdded
                                            Webdialog set to#<Sketchup;;Group;0x8675518>
                                            onSelectionCleared
                                            No version.
                                            Inspecting model for errors
                                            onSelectionAdded
                                            onSelectionCleared
                                            onSelectionAdded
                                            Webdialog set to#<Sketchup;;Group;0x86a78a0>
                                            • 3 / 4
