    [Plugin]SketchyPhysics3 beta.
    69 Posts 14 Posters 23.8k Views 14 Watching
      l.frisken
      mine does that but it refuses to connect. Very strange 😢
        CPhillips
        Could you try one more time. But this time open the Window->Ruby Console before you try to connect them. Then cut and paste any text after it fails.
          phy
          Try clicking on the sphere and then ctrl clicking on the joint. That's how I've always connected joints.
          Tableau de comparaison de Staxyn s'agit d'un mГ©dicament uniquement sur ordonnance.
            l.frisken
            ok, will try cphillips.
            phy, I have tried that, and it works fine with sp2 but not with sp3 for me
              l.frisken
              this is the ruby script from creating the joint, grouping it with he rectangular prism, and then attempting to connect it:
              First click
              potentialParent #<Sketchup;;Group;0x86b5238>
              onSelectionAdded
              onSelectionBulkChange1
              Webdialog set to#<Sketchup;;Group;0x8681b30>
              onSelectionCleared
              Webdialog set to#<Sketchup;;Group;0x86b5238>
              onSelectionBulkChange2
              onSelectionBulkChange0
              onSelectionAdded
              Webdialog set to#<Sketchup;;Group;0x8675518>
              onSelectionCleared
              No version.
              Inspecting model for errors
              onSelectionAdded
              onSelectionCleared
              onSelectionAdded
              Webdialog set to#<Sketchup;;Group;0x86a78a0>
                CPhillips
                That doesnt look like the joint even tries to connect. Are you sure you are holding down the correct key (ctrl on the left side of the keyboard) when you are trying to connect?
                  l.frisken
                  I did use the left ctrl. It worked with sp2 which is strange, but I'll try right ctrl just in case it is a problem with my keyboard.
                    l.frisken
                    ok thankyou cphillips for solving the prob! I wasn't using the left ctrl like I usually do because I broke my left arm recently, and it is easier to use the right one on my laptop keyboard! but the is still that little glitch with the box in the wrong spot!
                      CPhillips
                      Sorry to hear that. I broke my arm last year and hardly used the computer the whole time it was healing. It was actually kinda nice....
                      I'll make a note to hook up the right ctrl and shift keys.
                        Alpha Wing
                        I had this problem.... Error starting simulation undefined method... nilclass.... etc.......... I need help!
                        • 4 / 4
