    SketchyPhysics3 Release Candidate 1
    64 Posts 18 Posters 35.4k Views 18 Watching
      Alienizer
      @wacov said:
      That's how it SHOULD be IF it's implemented. That's (I think) how it works in the newton physics playground, so the same kind of thing could be done with SP.
      Makes perfect sense to me.
      I'm from Mars and moved to Earth to alienize you. Unfortunately, I became humanized.
      • W Offline
        warriorcat
        Hey,how do you make magnets and thrusters work? I can't seem to make them work.
          Physicsguy1
          For an uncontrollable thruster, check the box placed next to thruster in the UI. Then put in a simple value like 5000 in the strength field. If it is a big object, then the number must be increased. A controlled thruster code(placed in strength field)will be like this: -(controller)*value. A simple example will be -(key('space'))*5000. You can replace space with any character on the keyboard. If you have a joystick, you can put in just A or B or X or Y for the buttons. You can also put in lefty or leftx, being y axis and x axis respectively. You can do the same with right in the place of left, for the right stick(if you have one) Remember that if you don't have a joystick, you can still control the lefty and righty with the keyboard. Lefty is w/a/s/d, and righty for the arrow keys. For magnets, check the magnet box in the UI. Then enter a value. Create another object and check the magnetic box. The magnetic object will cling to the magnet. Try a higher value. You can also control magnets. Hope this helps!
          • W Offline
            warriorcat
              CPhillips
              I might not be right. When you wrote that it will retrieve the variable, i thought you could change the variable, like on a control panel slider. it is like two joints controlled with the same name.
              Ok, I think I understand. Right now you can only get variables that have been set. That may change at some point.
              What var did you want to change?
                CPhillips
                @alienizer said:
                @wacov said:
                The physics material would be entirely separate from the SketchUp material; so you'd be able to set a box to behave like wood, but it could be painted as steel. These materials would be like templates, with settings you can modify, like density and friction. Maybe a material manager could be implemented? The UI's kinda crowded.
                If it's going to work that way, then it'll be perfect, as long as we can make our own material of course. Do you know for sure that's how it'll be, or you're just guessing?
                Yes that is more or less how it works. If it was just a matter of setting mass it would be easy, but it also has all the other properties of a material like friction.
                Part of the problem is that you need to setup material to material values. So if you have wood and ice you have a wood/wood table and a ice/ice table and a wood/ice table. Then if you add say steel then you need all those plus steel/steel and steel/wood and steel/ice. As you can see it adds up to a lot of tables to fill in. The UI is going to be tricky.
                  Alienizer
                  Why the need for material to material values? If one material has more friction than another one, it shouldn't make any difference what material it comes into contact with, because both material will then be evaluated to simulate the proper friction, say, rock(friction=10) on glass(friction=1) will slide more than rock(friction=10) on rock(friction=10)
                    CPhillips
                    I dont know. That how the physics engine is setup.
                    • W Offline
                      Wacov
                      I suppose that could be useful; something like rubber could have the same friction value as rock, but it'd stick to glass really well.
                      • W Offline
                        Wacov
                        What I'm really interseted to know is if we can use multiple physics materials in the static mesh... so you could have slippery mud next to rock and sand, all with their own settings. I've noticed that the realism becomes pretty unreliable if you use more than one static mesh in a large model, so that's not really an option.
                          Alienizer
                          I think the material interaction should not be done using the "material to material" approach. We should use the laws of physics. In real life, what make rubber stick to glass? Well, there is how porous the object is, its flexibility, how smooth it is. That's 3 things I can think of right now. Having settings such as these for each material would simplify the task, and then we would not need to do material to material.
                          • W Offline
                            Wacov
                            Unfortunately, flexible (deformable) geometry is totally impossible with the current engine. You could probably make stuff bounce, but that's it. Bouyancy would be a useful setting, but as far as porous objects... maybe something can increase gradually in density when it enters the bouyancy plane? True fluid simulation has already been ruled out, although some physics engines support it, SU probably can't handle dynamic geometry that complex. I see what you're saying about smoothness though.
                            I agree with you, but specific settings could come in handy. Maybe there could be a general blanket effect, but with user-defined exceptions? The laws of physics have already been thrown out of the window πŸ˜„ ... flying cars, anyone?
                              BTM
                              Miss a few days, and get left in the dust... So much can change in a week!
                              ...oh, on mac, after installation, why do I get the message
                              %(#FF0000)[Error Loading File sketchyphysics.rb
                              no such file to load -- dl]
                              I must have done SOMETHING wrong... tried it twice to no avail...
                                Alienizer
                                Here's your flying car Wacov πŸ˜†
                                http://tbn3.google.com/images?q=tbn;-c_Xrc1AIozArM;http://www.davidchess.com/words/log200711a.jpg
                                Well, I suppose we could have only one setting instead of "material to material". What about...
                                Friction: range from 0% to 100%
                                The higher the number, the more friction.
                                Say...
                                Glass will slide very easily on a smooth wood table.
                                Glass will slide a bit on sand paper.
                                Glass will not slide at all on Scotch tape.
                                Sand paper will slide a bit on Scotch tape.
                                So we can say...
                                Glass.Friction == 1; // because it slides easy on smooth surfaces.
                                WoodTop.Friction == 3; // About like glass but not as much.
                                SandPaper.Friction == 30; // because it does slides on smooth surfaces, such as when sanding wood.
                                ScotchTape.Friction == 100; // because it doesn't slide at all on just about any surfaces.
                                Now we can calculate how to affect the velocity of an object when it slides on another...
                                if F1 == F2 then V == F1 else V == Abs(F1-F2);
                                where...
                                F1 = friction of the first object.
                                F2 = friction of the second object.
                                V the resulting percentage the objects speed should decrease on every frame...
                                Glass --> Glass = 1%
                                Glass --> WoodTop = 2%
                                WoodTop --> Glass = 2%
                                Glass --> SandPaper = 29%
                                Glass --> ScotchTape = 99%
                                SandPaper --> ScotchTape = 80%
                                SandPaper --> WoodTop = 27%
                                ScotchTape --> WoodTop = 97%
                                  CPhillips
                                  Sorry, I forgot a file. Its attached and I will update the ZIP.
                                  Put this in your plugins/SketchyPhysics3/ folder.
                                  • W Offline
                                    Wacov
                                    I see what you're saying but we're basically stuck with however the physics engine does materials. No way around it, no way to edit the engine, and really no option of changing engines at this point. Sliders in a new window for material config, like you say from 0 to 100%, would be good, but if possible I'd like to be able to set rubber to have high friction against glass, and low against, say, a carpet. The carpet would have quite good friction and the rubber would have very high friction, so if we only used a general system then it wouldn't work realistically. We can't simulate the interaction between the rubber and every fibre in the carpet, so this would be the best solution
                                      Alienizer
                                      I see what you mean. But since "material to material" can take a very long time to set up, perhaps we can use my suggestion to at least setup the default settings for "material to material"? It'll be better than all being zero!
                                      • W Offline
                                        Wacov
                                        That's what I mean. A default setting, but with user-controlled exceptions would be perfect; there should be some pre-made templates, say, wood, metal, rubber, glass, stone, fabric, plastic, polysterene, and cardboard... just off the top of my head. This would mean that, as long as people used them, the materials that use exceptions would be cross-compatible between models.
                                          mptak
                                          First off...Y'all are incredible. It warms my soul to see people so jazzed about something
                                          with so much possibility (and reality in a virtual sense)
                                          However...I am still locked in a semi_autocad world and have found the following snafu.
                                          If I import a solid model from Autocad, I think that the program assigns names of group#1, group#2, group#3 to all of the solids.
                                          This seems to cause SP3RC1 to stop working.
                                          However, if I just used the entity info tool and edit out the names it all works.
                                          Anyone else have the same problem....I am introducing my Autocad students (it is in the course title) to workflow and this extra step might actually
                                          be good for them but on the other hand it is maddening when you just want to hook up an xbox controller and throw virtual tomatoes.
                                          Keep rockin!
                                            Sgt.A.Johnson
                                            Keep rockin!
                                            Ive never had this problem before but throwing virtual tomatoes is a bit of a new one. I hope your joking.
                                            • 2 / 4
