    Once upon a time... A Puzzle
    95 Posts 15 Posters 3.0k Views 15 Watching
    • jeff hammondJ Offline
      @ecuadorian said:
      Yes I could, at least with most ceiling fans 😉
      oh yeah.. i guess you could figure it out with fans..
      i was going to use electric clocks as an example you couldn't do it with but that too would actually work.. an electric Digital clock (meaning - the display turns off instantaneously when the power is shut off) on the other hand - i don't think that would be possible.
        ok, so i thought of a way you could do it with a digital clock as well..(and probably is the easiest of all)
        i'll just go ahead and give the answer.. for ease of explanation, let's label the switches 1, 2, & 3:
        • set switch 1 & 2 to the 'ON' position
        • wait a minute or two
        • turn off switch 2 and enter the room
        • the light that is on is controlled by switch 1... the light that is off and warm is switch 2... the light that is off and cold is switch 3
        and i'm stumped on frenchy's last question
          You never return to the same time and the same point in space
          Read more the question 😉
            Teezer
            Once upon a time, I got into a session with a couple of programmers who were trying to find a non obvious way to hide information in a binary format. This is one of the things we came up with.
            The following sequence is valid under this scheme:
            1 = 1
            2 = 110
            3 = 111
            4 = 100
            5 = 101
            6 = 11010
            7 = 11011
            8 = 11000
            9 = 11001
            10 = 11110
            Can you see why?
            Real life is just another website, albeit a rather boring one.
              Jim
              Outside a room there are three light switches. Each switch is connected to a different light bulb inside the room.
              Each of the three switches can be either 'ON' or 'OFF'.
              You are allowed to set each switch the way you want it and then enter the room. you can only do this once.
              Your task is to then determine which switch controls which bulb. How can you do it?
              There's window in the wall and you can see the lights inside?
              • david_hD Offline
                david_h
                Model it in Podium. 💚
                • E Offline
                  Ecuadorian
                  1 = 1
                  2 = 110
                  3 = 111
                  4 = 100
                  5 = 101
                  6 = 11010
                  7 = 11011
                  8 = 11000
                  9 = 11001
                  10 = 11110
                  Can you see why?
                  Ok, wait, I've solved the first 5 digits. It seems that you have to subtract and then add the relative values of the digits. I'm not a coder, so I might be way off... 😳
                  2 = 4 - 2 + 0
                  3 = 4 - 2 + 1
                  4 = 4 - 0 + 0
                  5 = 4 - 0 + 1
                  -Miguel Lescano
                  • E Offline
                    Ecuadorian
                    That's why I came up with my own puzzle, Pilou. Anyone wants to give it a try?
                    @ecuadorian said:
                    This one is for the Japanese speakers and Japanese language learners in the forum:
                    3txq
                    What is the next character in the sequence?
                    -Miguel Lescano
                      In Cheating 💚
                      In fact now with Internet it's very difficult to find new problem 😒
                      Solution is always somewhere 😉
                      Subject: Negative bases
                      Yes, there are negative bases. They aren't used much, but they are
                      quite interesting. They allow you to represent both positive and
                      negative numbers with only positive digits. For example, if the base
                      is -2, then you have the following equalities:
                      Base 10... Base -2
                      -11..... 110101
                      -10..... 1010
                      -9..... 1011
                      -8..... 1000
                      -7..... 1001
                      -6..... 1110
                      -5..... 1111
                      -4 ..... 1100
                      -3 ..... 1101
                      -2 ..... 10
                      -1..... 11
                      0..... 0
                      1 ..... 1
                      2 ..... 110
                      3 .... 111
                      4 ... 100
                      5 ... 101
                      6 ... 11010
                      7 ... 11011
                      8 ... 11000
                      9 ... 11001
                      10 ... 11110
                        Teezer
                        3txq
                        I know nothing about Japanese, but congratulations to you and Pilou for seeing that the sequence was base minus two. Most folks have never heard of negative base numbers. 😄
                        • E Offline
                          Ecuadorian
                          I had not heard about negative bases either, Tweezer. I just noticed that there was something rhythmic in the alternate subtract-add-subtract-add thing.
                          Since there seems to be no Japanese language students here, I'll post a (hopefully) less known puzzle:
                          One morning, Mr. Rich, the richest (and stingiest) man alive, entered a bank in downtown Manhattan. He went directly to the account officer and asked him for a $1 loan. The officer said:
                          -But Mr. Rich, you have gazillions in our bank. You can withdraw any amount you want.
                          -No, I want a loan, son. If you don't give it to me, I'll withdraw all my money from this bank and never return!
                          -Ok, I'll give it to you. You have to sign this paper here, and here.
                          -Aren't you going to ask me to pawn something?
                          -Of course not! We've known you for decades, Mr. Rich, we trust you with our lives.
                          -If you don't allow me to pawn something, son, I'll withdraw all my deposits and all my investments from this bloody bank!
                          -Fine. What do you want to pawn?
                          -Perhaps my car. It's right out here.
                          -Understood. I'll tell the guards to put it inside immediately.
                          -How much is the interest rate, son?
                          -It's just a 3% monthly interest rate, Mr. Rich.
                          -So, if I return this dollar before one month, I have to pay an interest of 3 cents?
                          -Exactly, Mr. Rich.
                          -Thank you, son.
                          And then Mr. Rich left the bank. Now, the question is, why did Mr. Rich do that?
                          -Miguel Lescano
                            Not sure but that's by far the cheapest parking rate I've ever seen in manhattan. 😄
                            • E Offline
                              Ecuadorian
                              Exactly! 😄
                              -Miguel Lescano
                              • chrisglasierC Offline
                                chrisglasier
                                Very nice ... and useful too!
                                • ToboboT Offline
                                  Tobobo
                                  I had the answer to the light bulb question but i've been out the last few days and missed my chance to answer! 😡
                                  A man is found in a remote mountian shack, hung from a 8 ft beam. The shack is empty of all furniture and there is a puddle beanth the dead man.
                                  How did he kill himself?
                                  Toby
                                  Philippians 4:13
                                    chrisglasier
                                    Stood on a block of ice?
                                      It was wintertime.
                                      He had a good fire lit in the shack.
                                      He brought in a block of ice [or compacted snow] from outside.
                                      He stood on the block and attached the noose to the high beam and put it around his neck.
                                      He stepped off the block and hanged himself.
                                      The ice/snow melted in the warmth of the room.
                                      Had you turned up a little later then all of the water would have melted and there would have been no immediate explanation...
                                      Had it been the summertime he couldn't have done it...
                                        Like the crime murder with an iced cone! 💚
                                        Nobody find the Sheep enigma? 😉
                                        • E Offline
                                          Ecuadorian
                                          Nope. Could you re-phrase it? I'm not sure to understand it.
                                          -Miguel Lescano
                                            No need, it's the exact sentence problem! 😄
                                            You will be agree with me when solution will be found 😉
                                            • 5 / 5
