    [Plugin][$] FredoScale - v3.6a - 01 Apr 24
    1.1k Posts 345 Posters 2.6m Views 343 Watching
      Matt666
      wish you would have sold them thru Smustard, but hope that folks will at least go donate $20 or more to you for this amazing collection.
      I second that. Fredo, do you have a paypal account? Or Where can I send you a donation? Thank you!
      Frenglish at its best !
      My scripts
      • BurkhardB Offline
        Burkhard
        Hi Matt, there is a donation page - html file with Fredos installation.
        Thanks also from me for such a great collection
        [http://www.ia-plus.de(http://www.ia-plus.de)]
          Also: Tools->Fredo6 Collection->Freescale->Donation...->Fredo6 at Paypal
            Matt666
            Ok, thank you!!
            My scripts
              rv1974
              Fredo it's genious as always!
              Meanwhile I have a lot of unbreakable freezing on stretchig and other tools.
              It happens with not over complicated geometry (only one "brick" with a row of simple glued windows onboard).
              2/ When I manage to skip su freezing every component inside becomes unique. Could they be treated under the same
              definition?
              Thank you once more. I really think all those official product managers,evangelists and easy riders shold be embarrassed
              • fredo6F Offline
                Could you post one model where you get these freezes.
                Does it happen, if prior to the transformation you make the all components unique, via the icon command with a pink '1'?
                definition?
                This is normal, as each individual component instance may be deformed differently from the other instances, they have to be made unique.
                  dylan
                  Thanks for this, it's an awesome tool!
                  Stretch alone is a function I will use so much.
                  Fantastic work
                  http://dmdarchitecture.co.uk/
                    rv1974
                    quote]
                    Problematic command is called "stretching with orientation of scaling box".Try to stretch a couple of times. Freezing happens with twist tool also.
                    kkk.zip
                    • soloS Offline
                      Here is the link to paypal's site, click on 'send money then insert Fredo's email addy and amount you wish to donate.
                      https://www.paypal.com/us/cgi-bin/webscr?cmd=_home
                        rv1974
                        It's understandable for twist\bend\melt etc. But why for uniform stretch command?
                          The stretch command isn't uniform.
                            And you can use the "moving Plan" for make it Uniform by part 😉
                              Dan
                              Stretching:
                              F4 to to view the divider plane.
                              Left click on the divider plane's border to move it parallel to itself.
                              Double click the divider plane to reset its position to the center of the model.
                              Right click on the divider plane to have additional (undocumented?) options.
                                Still won't be a uniform stretch.
                                  rv1974
                                  OK "Uniform" is wrong definition. But what hamper to allwindows in bulding #3 to become the same "win1_3" (if say original window in unstreched building#1 is "win1"?
                                    Fredo, thank you. The Bend operation is way cool. It even works on unconnected geometry.
                                      That would be nice. Just wondering how easy it is to work out which components remain the same... But if Fredo can solve that I'll make another donation to him.
                                        pibuz
                                        Fredo! Thank you so much for this unbelieveable plugin!
                                        One step closer to 3dsMax 😄
                                        WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
                                        • jeff hammondJ Offline
                                          @xrok1 said:
                                          Just in case nobody else has noticed, there's an html file (freescale.donation.html) in the freescale_dir_20 folder.. you can make a donation via that link.
                                          i would love to see the donation page in english too so i could give you some kudos. please post english donation link, and thankyou very much.
                                          the donation is via paypal so you can go to your language version of that and send to:
                                          fredosix{at}hotmail{dot}com
                                          • E Offline
                                            Ecuadorian
                                            I don't know what they taught you at the École Polytechnique, but they certainly did a good job with you, Fredo!
                                            -Miguel Lescano
                                            • 57
                                            • 58
                                            • 5 / 58
