    [Plugin][$] FredoScale - v3.7c - 19 Aug 26
    1.2k Posts 347 Posters 3.4m Views 345 Watching
    • utilerU
      utiler
      Shame shame shame on Google for not patting this guys back! How is it that a lone programmer can take sketchup to this level with little resources in comparison to Google? Yet we get Version 7 which is a polished version of 6 yet we all had to pay. Google should either hire Fredo, Whaat, and a few others (did not mean to leave anyone out) or leave the programming to them for 2 years and see what Sketchup becomes!
      Fredo....thank you for an absolutely AMAZING plugin!
      Google.....take notice!
      Scott
      second that Scott!!! πŸ‘
      Just Curious...
      • X
        xrok1
        thanks, going now! gladly. πŸ˜›
        • T
          Tekelwriter
          Beautiful! Thanks a lot!
          • fredo6F
            @jmmad said:
            Only one feature you could add is to give the strech tool the ability to make more paralel planes that deform the model, so it can afect more parts of the geometry at the same time.
            I thought about it, but then it becomes cumbersome in the UI, and you may not easily reach the expected result.
            By the way, 2 tips:
            1. because Stretching is often just applying an offset, I suggest to call the Dimension box and just type '+100' or '-100' at the end of the current dimension, if your offset is 100. The field supports arithmetic formula.
            2. double-clicking on the divider will bring it back to center.
            @jmmad said:
            I only have one problem with the stretch tool some times when I strech something even a simple geometry SU freezes and does not respond, and i have to restart SU.
            a) Do you apply it to a selection made of embedded components, with several instances (insinde or outside the selection)?
            b) Is this something you can reproduce on a given model (if so, can you post it)
            to all users: do you encounter similar cases of Freeze?
            • FletchF
              Fletch
              Fredo,
              You may have just saved me hundreds of hours bending text in SU... much less all the other great things we can think of for these tools....
              http://www.kerkythea.net/phpBB2/images/smiles/kt_thanks.gif
              http://www.kerkythea.net/phpBB2/images/smiles/kt_respekt.gif
              wish you would have sold them thru Smustard, but hope that folks will at least go donate $20 or more to you for this amazing collection.
              Fletch
                Matt666
                I second that. Fredo, do you have a paypal account? Or Where can I send you a donation? Thank you!
                Frenglish at its best !
                My scripts
                • BurkhardB
                  Burkhard
                  Hi Matt, there is a donation page - html file with Fredos installation.
                  Thanks also from me for such a great collection
                  http://www.ia-plus.de
                    Also: Tools->Fredo6 Collection->Freescale->Donation...->Fredo6 at Paypal
                      Matt666
                      Ok, thank you!!
                      My scripts
                        rv1974
                        Fredo it's genious as always!
                        Meanwhile I have a lot of unbreakable freezing on stretchig and other tools.
                        It happens with not over complicated geometry (only one "brick" with a row of simple glued windows onboard).
                        2/ When I manage to skip su freezing every component inside becomes unique. Could they be treated under the same
                        definition?
                        Thank you once more. I really think all those official product managers,evangelists and easy riders shold be embarrassed
                        • fredo6F
                          Could you post one model where you get these freezes.
                          Does it happen, if prior to the transformation you make the all components unique, via the icon command with a pink '1'?
                          definition?
                          This is normal, as each individual component instance may be deformed differently from the other instances, they have to be made unique.
                            dylan
                            Thanks for this, it's an awesome tool!
                            Stretch alone is a function I will use so much.
                            Fantastic work
                            http://dmdarchitecture.co.uk/
                              rv1974
                              quote]
                              Problematic command is called "stretching with orientation of scaling box".Try to stretch a couple of times. Freezing happens with twist tool also.
                              kkk.zip
                              • soloS
                                Here is the link to paypal's site, click on 'send money then insert Fredo's email addy and amount you wish to donate.
                                https://www.paypal.com/us/cgi-bin/webscr?cmd=_home
                                  rv1974
                                  It's understandable for twist\bend\melt etc. But why for uniform stretch command?
                                    The stretch command isn't uniform.
                                      And you can use the "moving Plan" for make it Uniform by part πŸ˜‰
                                        Dan
                                        Stretching:
                                        F4 to to view the divider plane.
                                        Left click on the divider plane's border to move it parallel to itself.
                                        Double click the divider plane to reset its position to the center of the model.
                                        Right click on the divider plane to have additional (undocumented?) options.
                                          Still won't be a uniform stretch.
                                            rv1974
                                            OK "Uniform" is wrong definition. But what hamper to allwindows in bulding #3 to become the same "win1_3" (if say original window in unstreched building#1 is "win1"?
                                            • 58
                                            • 59
                                            • 5 / 59
