    [Tutorial > Modeling] A PoorFlatEllipsoidIndian Bowl
    62 Posts 12 Posters 52.5k Views 12 Watching
    • MALAISEM Offline
      MALAISE
      Hi Simon
      Really good topic, and probably not a waste of time... 👍
      MALAISE
        Hi Simon,
        It's always a pleasure to read your posts, really! Good to see you around after such a relatively long time! 👍
        • simon le bonS Offline
          simon le bon
          Gaieus, Malaise, I can't wait until my next post to reply for your kindness pleased me so.
          I know myself as a spare time SketchUp user. But i can bring to this fine community my small stone, my energy, my curiosity and a little bit more maybe.. 👍 👍 simon
            MikeR
            great tuts.....help me a lot to understand how S works.....just one question thou....if ever i want to put a hole on the rounded edges....how do i do that?? thanks....to the mods...pls move my post if im being OT 😄
              T cut a hole into a curved surface (in general), you will need to build a 3D shape the cross section of which will be the shape you want the hole to be, poke it through the curved surface, select both the curved surface and the 3D shape, right click > Intersect... > Selected. This will create the edges between the surface and the shape and you can simply erase all unwanted geometry (generally the leftover of your 3D, cutting shape and the cut-away piece of your curved surface).
              Better understand by having a look at this tutorial - a little bit different example (not with a bowl) but the idea is the same.
                MikeR
                got it!!!big help thanks!!! 😍
                  simon le bon
                  Monday, March 2nd.
                  After months I come back on this thread.
                  First, it's because the illuminating and simple Voder Vocoder's solution isn't available anymore on DataFileHost.
                  So here is a permanent link for his (SU6)skp:
                  squat_bowl_vodervocoder.skp
                  In addition i have made this screencast in order to easy show it.
                  [flash=545,430:21w5tec9]http://www.viddler.com/simple/50d17f9e/[/flash:21w5tec9]
                  http://www.viddler.com/explore/slb02/videos/15/
                  re: Viddler videos are often hard to open. Given to the exceptional quality of it picture please don't give up: simply reload.. ;-)simon
                  • Jean-FrancoJ Offline
                    Jean-Franco
                    Excellent !!!
                    Jean-Franco
                      Well, sometimes they DO load a bit harder (probably this depends on connection speed as well as server side bandwidth limitations) but I do like them for sure.
                      Maybe sometimes, when one opens the topic and many of the videos try to start streaming, it can be hard for internet connection.
                        simon le bon
                        If at the end of your KitoRaupp Pottery, you deselect ( 😮 Oups!) the spiral line you wanted (and needed) to remove, >> No Panic!!
                        Just take a look on this strange but very efficient new selection tool: "selected edges by defined angle", our frenchy Matt666 have developped in his last Selection Manager. It is specificaly a good tool to achieve the job ( to remove the spiral line) 😉 simon
                          or the cool Select lines by length by Chris Fullmer 😉
                            simon le bon
                            (Re: I give up posting direct videos on this thread, cause they seem to load more and more harder)
                            PAINTING THE BOWL
                            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/SanIldefonsoPottery_th.jpg
                            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/PaintingThebowl_Ath.jpg
                            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/PaintingThebowl_Bbth.jpg
                            Plus: here is the basic skp if you want to play with it:
                            PaintedBowl_c_a.skp
                            Tools On Surface - v1.3 Fredo6
                            Mirror_ v3.1 TIG
                            Selection manager v1.1 Matt666
                            :-)simonlebon
                              simon le bon
                              Is it a Pottery Challenge or What? 😄
                              Here is another fantastic way i was totaly ignorant to model our Bowl. Thanks Pilou to link this to us!
                              http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/PilouMiniPottery.jpg
                              Pilou's link linking to:
                              http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/watkins.jpg
                              which linking to:
                              KitoRaupp Pottery Twist on Youtube
                              and
                              KitoRaupp Spirale Tutorial on Youtube
                              and others KitoRaupp productions 👍
                              On another hand the technic used is not so easy to reproduce. So I made this small video to clarify it. (I'm the author of nothing here). 😉 😉 😎 Simon
                              http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/canyon_de_chelly_05t-02b.jpg
                              http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/KitoRauppPottery.jpg
                              CenterPoint v.1.20 by Todd Burch
                                These gif animations are very cool, Simon! Why don't you include the full size image with the [img] tags instead - after all they are not too big?
                                http://i274.photobucket.com/albums/jj245/Spendauballet/videos/Spiral_b.gif
                                  simon le bon
                                  Hi! dear Gaieus, our cool "watching and listening man" (I guess at night you like listen the stars in the sky !!)
                                  In facts I have made this Gif (450x337) to fit the forum. It is an experiment to deliver an animated explanation which needs just few seconds, for it is the case very often. I've first tried to display it in full format, afterwords I thought an animated thumbnail leading to the full format was better. I don't know. It depends of the case for sure 😐
                                  PS: i remember now why i made this way! This Gif is 732Ko . So if we put several in the same page we are surely going to difficult loading..
                                  simon
                                    simon le bon
                                    Merci Jean-Franco 👍 😉
                                    Gaieus, "../but I do like them for sure. 👍 😄
                                    There is many advantages to use Viddler: great picture quality, easy upload, nice statistics, Flash or original downloads, video comments, good sharing options,... Nothing is perfect, the streaming is a bit erratic 😕 So I now put direct link systematically just below .
                                    I have made a mistake at the end of my previous second video, PaintingTheBowl_B.
                                    In order to reconstruct my Bowl, I have copied the single slice x49 (Cause my starting stripped tube was based on a 50 segments circle) (i had been surprise by the enormous time this operation had taken 😮 )
                                    In fact i had forgotten this supposed "single slice" was already made with a couple of slices (mirrored). So, it was only necessary to copy it by 24 !! 🤣
                                    Simon
                                      simon le bon
                                      %(#800000)[This thread is still intend to beginners. Regular SketchUp users might waste their time on this space (but who knows 🙂]
                                      Secondly i have missed to explore a modeling way which makes school inside SU. It is certainly not the easiest way nor time saving one. But it is a fresh handmade way.
                                      Indian bowls:
                                      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/th_Maricopa.jpg
                                      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/th_Qahatikawatergirl.jpg
                                      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/th_Potter_SantaClara.jpg
                                      The starting shape:
                                      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/PotterSC_StripedTube.jpg
                                      http://www.viddler.com/explore/slb02/videos/16/
                                      Main tips:
                                      [url=http://www.viddler.com/explore/slb02/videos/17/:dwaa06ky]
                                      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/PotterSC_MainTips-1.jpg
                                      [/url:dwaa06ky]
                                      [url:dwaa06ky]http://www.viddler.com/explore/slb02/videos/17/[/url:dwaa06ky]
                                      Potter Santa Clara
                                      [url=http://www.viddler.com/explore/slb02/videos/18/:dwaa06ky]
                                      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/PotterSC_IndianBowl.jpg
                                      [/url:dwaa06ky]
                                      [url:dwaa06ky]http://www.viddler.com/explore/slb02/videos/18/[/url:dwaa06ky]
                                      Additional References:
                                      [url=http://www.sketchucation.com/forums/scf/viewtopic.php?f=18&t=9079:dwaa06ky]GreenToaster "6 Minute Car" Vid Tuts[/url:dwaa06ky]
                                      [url=http://www.sketchucation.com/forums/scf/viewtopic.php?f=18&t=9561:dwaa06ky]Playing with curves[/url:dwaa06ky]
                                      Ruby scripts/Plugins:
                                      [url=http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=11212:dwaa06ky]Tools On Surface - v1.3[/url:dwaa06ky]
                                      [url=http://www.smustard.com/script/MakeFaces:dwaa06ky]MakeFaces v.1.40[/url:dwaa06ky]
                                        simon le bon
                                        Due to the intensive manipulations, we are driven to make a lot of small mistakes. Most of them they come from Move tool. This is problematic when we want to paint and modify the object.
                                        Here is cases of twisted rings.
                                        http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/th_twistedRing_a.jpg
                                        http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/th_twistedRing_b.jpg
                                        So here is a second method, yes less fun but more robust:
                                        http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/PotterSC_alternate.jpg
                                        http://www.viddler.com/explore/slb02/videos/19/
                                        "Are you silly or what Simon? Just take a look at that and then tell me what!"
                                        [url=http://www.viddler.com/explore/slb02/videos/20/:vfaskebg]
                                        http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/PotterSC_simple.jpg
                                        [/url:vfaskebg]
                                        [url:vfaskebg]http://www.viddler.com/explore/slb02/videos/20/[/url:vfaskebg]
                                        "And please give me now only a reason to waste your time this way!"
                                        [url=http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/twistedRing_motive.jpg:vfaskebg]"I surely have a reply to you (just clic on me:-)"[/url:vfaskebg]
                                        "Here is an exemple of what i mean"
                                        [url=http://www.viddler.com/explore/slb02/videos/22/:vfaskebg]
                                        http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/PotterSC_temple.jpg
                                        [/url:vfaskebg]
                                        [url:vfaskebg]http://www.viddler.com/explore/slb02/videos/22/[/url:vfaskebg]
                                        [url=http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=13563&st=0&sk=t&sd=a:vfaskebg][Plugin] BezierSpline v1.21[/url:vfaskebg]
                                        Aren't you tired with all these video?
                                        ;-)simon
                                          simon le bon
                                          @simon le bon said:
                                          Monday, March 2nd.
                                          Secondly because since the end of this first part thread, fantastic tools had been developped by some (wellknown) especially tallented Ruby Makers. An important part of those tools leads to allow SketchUp to be a modelling engine.
                                          so Here is my PoorFlatEllipsoidIndian Bowl made with: SubdivideAndSmooth v.1.00 _ by Dale Martens (Whaat)
                                          (I must say i'm not at all specialized with S&S. It is not an easy set of tools. I must confess that when after a while, i want use it again, i must go back to see the video tuts 1 & 2 again and again 😄. But, but, little a little i find solutions to obtain what i want!! 👍 )(So for asking help, you can face up to our great masters as: Solo, Teezer, Boofredlay, Kwistenbiebel, Mariocha,.. sorry for those I forget or ignore)
                                          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/PotterSC_SS-1.jpg
                                          Plugins:
                                          Zorro2 (beta) by Whaat on Sun Jan 25, 2009 5:55 am
                                          Tutorials:
                                          Tutorial Part 1
                                          Tutorial Part 2
                                          SubD2_fauteuil
                                          Pillow
                                          Various threads:
                                          In Development: Subdivide and Smooth
                                          Just Released! Subdivide and Smooth
                                          Curtains
                                          need help with Solos tutorial?
                                          Still playing with SubSmooth
                                          Organic Chair Model Question....I need help?
                                          [TUTORIAL]: texturing organic form (subsmooth)
                                          subd and smooth stuff
                                          . Ouf! simon.
                                            simon le bon
                                            Snippet pasted from Shaping a cylinder - interesting technique about the "fifteen degrees rotation" needed to achieve the spiral.
                                            personal asking:
                                            Why only a 15° disc rotation allows copy of ring angled edges to fit with the source, whatever the height is?
                                            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/th_spiral_ep.jpg
                                            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/th_spiral_15d.jpg
                                            Ecuadorian answer:
                                            360º (full circle) / 24 sides in circle (SketchUp default) = 15º
                                            If you want to use a 10º degree rotation you need to start with 36 sides in the circle.
                                            If you want to do it with 20º, you need an 18-sided circle.
                                            Solution during the night:
                                            I was thinking of this in the very morning before wake! And i've find this is not something of "big theory" as I thought, but something pretty simple 😄
                                            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/spir_A.jpg
                                            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/th_spir_B.jpg
                                            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/th_spir_C.jpg
                                            🤓 simon
                                            • 1 / 4
