    [Tutorial > Modeling] A PoorFlatEllipsoidIndian Bowl
    62 Posts 12 Posters 51.1k Views 12 Watching
    • simon le bonS Offline
      simon le bon
      Dear Voder, please to see you again.
      Surely a better way: much easy and faster, but more importantly much more flexible. Ok! not so bad topic: we learn.
      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/squat_bowl_vodervocoder-1.jpg
      ](http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/squat_bowl_vodervocoder.jpg)
      PS Sorry to be heavy, i regret that your DataFileHost don't kept the files permanently:"Your files will be kept on our servers as long as it is downloaded every 30 days."
      slb
        Hi Folks,
        Interesting and useful topic. 👍
        Just an addition to Voder's bowl: you can soften the dividing lines after painting them so that the bowl looks more "roundish" but still keeps the different colours in the pattern. It is especially useful if rendering in a 3rd party software (it would show any non-softened edges really aswul).
        • MALAISEM Offline
          MALAISE
          Hi Simon
          Really good topic, and probably not a waste of time... 👍
          MALAISE
            Hi Simon,
            It's always a pleasure to read your posts, really! Good to see you around after such a relatively long time! 👍
              simon le bon
              Gaieus, Malaise, I can't wait until my next post to reply for your kindness pleased me so.
              I know myself as a spare time SketchUp user. But i can bring to this fine community my small stone, my energy, my curiosity and a little bit more maybe.. 👍 👍 simon
                MikeR
                great tuts.....help me a lot to understand how S works.....just one question thou....if ever i want to put a hole on the rounded edges....how do i do that?? thanks....to the mods...pls move my post if im being OT 😄
                  T cut a hole into a curved surface (in general), you will need to build a 3D shape the cross section of which will be the shape you want the hole to be, poke it through the curved surface, select both the curved surface and the 3D shape, right click > Intersect... > Selected. This will create the edges between the surface and the shape and you can simply erase all unwanted geometry (generally the leftover of your 3D, cutting shape and the cut-away piece of your curved surface).
                  Better understand by having a look at this tutorial - a little bit different example (not with a bowl) but the idea is the same.
                    MikeR
                    got it!!!big help thanks!!! 😍
                      simon le bon
                      Monday, March 2nd.
                      After months I come back on this thread.
                      First, it's because the illuminating and simple Voder Vocoder's solution isn't available anymore on DataFileHost.
                      So here is a permanent link for his (SU6)skp:
                      squat_bowl_vodervocoder.skp
                      In addition i have made this screencast in order to easy show it.
                      [flash=545,430:21w5tec9]http://www.viddler.com/simple/50d17f9e/[/flash:21w5tec9]
                      http://www.viddler.com/explore/slb02/videos/15/
                      re: Viddler videos are often hard to open. Given to the exceptional quality of it picture please don't give up: simply reload.. ;-)simon
                      • Jean-FrancoJ Offline
                        Jean-Franco
                        Excellent !!!
                        Jean-Franco
                          Well, sometimes they DO load a bit harder (probably this depends on connection speed as well as server side bandwidth limitations) but I do like them for sure.
                          Maybe sometimes, when one opens the topic and many of the videos try to start streaming, it can be hard for internet connection.
                            simon le bon
                            If at the end of your KitoRaupp Pottery, you deselect ( 😮 Oups!) the spiral line you wanted (and needed) to remove, >> No Panic!!
                            Just take a look on this strange but very efficient new selection tool: "selected edges by defined angle", our frenchy Matt666 have developped in his last Selection Manager. It is specificaly a good tool to achieve the job ( to remove the spiral line) 😉 simon
                              or the cool Select lines by length by Chris Fullmer 😉
                                simon le bon
                                (Re: I give up posting direct videos on this thread, cause they seem to load more and more harder)
                                PAINTING THE BOWL
                                http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/SanIldefonsoPottery_th.jpg
                                http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/PaintingThebowl_Ath.jpg
                                http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/PaintingThebowl_Bbth.jpg
                                Plus: here is the basic skp if you want to play with it:
                                PaintedBowl_c_a.skp
                                Tools On Surface - v1.3 Fredo6
                                Mirror_ v3.1 TIG
                                Selection manager v1.1 Matt666
                                :-)simonlebon
                                  simon le bon
                                  Is it a Pottery Challenge or What? 😄
                                  Here is another fantastic way i was totaly ignorant to model our Bowl. Thanks Pilou to link this to us!
                                  http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/PilouMiniPottery.jpg
                                  Pilou's link linking to:
                                  http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/watkins.jpg
                                  which linking to:
                                  KitoRaupp Pottery Twist on Youtube
                                  and
                                  KitoRaupp Spirale Tutorial on Youtube
                                  and others KitoRaupp productions 👍
                                  On another hand the technic used is not so easy to reproduce. So I made this small video to clarify it. (I'm the author of nothing here). 😉 😉 😎 Simon
                                  http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/canyon_de_chelly_05t-02b.jpg
                                  http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/KitoRauppPottery.jpg
                                  CenterPoint v.1.20 by Todd Burch
                                    These gif animations are very cool, Simon! Why don't you include the full size image with the [img] tags instead - after all they are not too big?
                                    http://i274.photobucket.com/albums/jj245/Spendauballet/videos/Spiral_b.gif
                                      simon le bon
                                      Hi! dear Gaieus, our cool "watching and listening man" (I guess at night you like listen the stars in the sky !!)
                                      In facts I have made this Gif (450x337) to fit the forum. It is an experiment to deliver an animated explanation which needs just few seconds, for it is the case very often. I've first tried to display it in full format, afterwords I thought an animated thumbnail leading to the full format was better. I don't know. It depends of the case for sure 😐
                                      PS: i remember now why i made this way! This Gif is 732Ko . So if we put several in the same page we are surely going to difficult loading..
                                      simon
                                        simon le bon
                                        Merci Jean-Franco 👍 😉
                                        Gaieus, "../but I do like them for sure. 👍 😄
                                        There is many advantages to use Viddler: great picture quality, easy upload, nice statistics, Flash or original downloads, video comments, good sharing options,... Nothing is perfect, the streaming is a bit erratic 😕 So I now put direct link systematically just below .
                                        I have made a mistake at the end of my previous second video, PaintingTheBowl_B.
                                        In order to reconstruct my Bowl, I have copied the single slice x49 (Cause my starting stripped tube was based on a 50 segments circle) (i had been surprise by the enormous time this operation had taken 😮 )
                                        In fact i had forgotten this supposed "single slice" was already made with a couple of slices (mirrored). So, it was only necessary to copy it by 24 !! 🤣
                                        Simon
                                          simon le bon
                                          %(#800000)[This thread is still intend to beginners. Regular SketchUp users might waste their time on this space (but who knows 🙂]
                                          Secondly i have missed to explore a modeling way which makes school inside SU. It is certainly not the easiest way nor time saving one. But it is a fresh handmade way.
                                          Indian bowls:
                                          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/th_Maricopa.jpg
                                          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/th_Qahatikawatergirl.jpg
                                          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/th_Potter_SantaClara.jpg
                                          The starting shape:
                                          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/PotterSC_StripedTube.jpg
                                          http://www.viddler.com/explore/slb02/videos/16/
                                          Main tips:
                                          [url=http://www.viddler.com/explore/slb02/videos/17/:dwaa06ky]
                                          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/PotterSC_MainTips-1.jpg
                                          [/url:dwaa06ky]
                                          [url:dwaa06ky]http://www.viddler.com/explore/slb02/videos/17/[/url:dwaa06ky]
                                          Potter Santa Clara
                                          [url=http://www.viddler.com/explore/slb02/videos/18/:dwaa06ky]
                                          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/PotterSC_IndianBowl.jpg
                                          [/url:dwaa06ky]
                                          [url:dwaa06ky]http://www.viddler.com/explore/slb02/videos/18/[/url:dwaa06ky]
                                          Additional References:
                                          [url=http://www.sketchucation.com/forums/scf/viewtopic.php?f=18&t=9079:dwaa06ky]GreenToaster "6 Minute Car" Vid Tuts[/url:dwaa06ky]
                                          [url=http://www.sketchucation.com/forums/scf/viewtopic.php?f=18&t=9561:dwaa06ky]Playing with curves[/url:dwaa06ky]
                                          Ruby scripts/Plugins:
                                          [url=http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=11212:dwaa06ky]Tools On Surface - v1.3[/url:dwaa06ky]
                                          [url=http://www.smustard.com/script/MakeFaces:dwaa06ky]MakeFaces v.1.40[/url:dwaa06ky]
                                            simon le bon
                                            Due to the intensive manipulations, we are driven to make a lot of small mistakes. Most of them they come from Move tool. This is problematic when we want to paint and modify the object.
                                            Here is cases of twisted rings.
                                            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/th_twistedRing_a.jpg
                                            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/th_twistedRing_b.jpg
                                            So here is a second method, yes less fun but more robust:
                                            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/PotterSC_alternate.jpg
                                            http://www.viddler.com/explore/slb02/videos/19/
                                            "Are you silly or what Simon? Just take a look at that and then tell me what!"
                                            [url=http://www.viddler.com/explore/slb02/videos/20/:vfaskebg]
                                            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/PotterSC_simple.jpg
                                            [/url:vfaskebg]
                                            [url:vfaskebg]http://www.viddler.com/explore/slb02/videos/20/[/url:vfaskebg]
                                            "And please give me now only a reason to waste your time this way!"
                                            [url=http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/twistedRing_motive.jpg:vfaskebg]"I surely have a reply to you (just clic on me:-)"[/url:vfaskebg]
                                            "Here is an exemple of what i mean"
                                            [url=http://www.viddler.com/explore/slb02/videos/22/:vfaskebg]
                                            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/PotterSC_temple.jpg
                                            [/url:vfaskebg]
                                            [url:vfaskebg]http://www.viddler.com/explore/slb02/videos/22/[/url:vfaskebg]
                                            [url=http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=13563&st=0&sk=t&sd=a:vfaskebg][Plugin] BezierSpline v1.21[/url:vfaskebg]
                                            Aren't you tired with all these video?
                                            ;-)simon
                                            • 1 / 4
