    [Plugin] FollowMe and keep (v0.04 update 20090210)
    223 Posts 79 Posters 181.7k Views 79 Watching
    • mitcorbM Offline
      mitcorb
      It is not working for me either. I downloaded the later FAK.rb posted and the bit count was the same, just the date had changed. I even grouped the path-no dice.
      Ended up using native followme and cleaned up.
      mitcorb
        No special problem with helix except a big time to calculate 💚
        • jeff hammondJ Offline
          I must be doing something wrong. It doesnt seem to go for me. I am trying to test a shape around a helix form. I select all, select FAK and . . .nothing. In fact I get a Splat.
          Any ideas? ❓
          do you have the construction point in place? it's treated as the align point (see original post of this thread)..
          if you don't have a construction point laying around, get it here:
          constpoint.skp
          if you do have the point in place already then i have no clue what the problem is..
          • E Offline
            Ecuadorian
            The last FollowMe and Keep requires no construction point. It adds one automagically.
            -Miguel Lescano
              😳 uh.... ooops 😄
              [edit] even worse, i have the latest version and i've still been putting the point in there manually 😆
              • E Offline
                Ecuadorian
                Worse yet, and a big Duh!
                I spent $4 in Smustard.com just to buy the "put construction point" tool, only to discover later that Didier Bur's projections toolbar has a much better version, it's free... and after all, I no longer need a construction point to use FollowMe and Keep!
                -Miguel Lescano
                  you have inside 1001bits an another followme and keep 😉
                  Very long calculation too ! Maybe the helix is some hard to follow?
                    jonbassem
                    @wikii said:
                    FollowMe and keep the dirction of profiles.
                    Tip:construction point in selection will be treated as the align_point!
                    v0.04 20090210
                    1 if path started at a vertex of profile,the vertex will be treated as align point.
                    2 auto reverse face to get directviewing result.
                    v0.03 20090209
                    1 start at nearest vertex when path is closed
                    2 fix some bugs
                    http://www.sketchucation.com/forums/scf/download/file.php?id=21147
                    v0.02 20090208
                    1 perfect ending;
                    2 autosmooth.
                      So using Perpendicular face tool by Chris Fullmer will be some useful 😉
                      • david_hD Offline
                        david_h
                        I think I got it to work without adding any point. It took a sec to calculate, butTa-DaH! Good little plugin. Thanks 👍
                          aalaser
                          Uesful tool for me.
                            abryan
                            I'm afraid this is a stupid question but how do I get your plugin file downloaded? It's an .rar file and I'm not sure how to get it into a usable (.rb) format for Sketchup to use.
                            • Chris FullmerC Offline
                              .rar is like a .zip file, except that most normal users never have to deal with it. So its a bit painful for most of us to have to "unrar" a file, since having a rar utility is not common... <dislikes rar for day to day uses like this, just zip it!>
                              So the answer is to install winrar or even the new version of winzip might handle rar formats. Once you install a rar software, you just open the .rar file and it will have .rb files and maybe folders inside of it. Then copy those to your plugins folder.
                              Good luck. Wiikii, if your out there, mind hosting a non-rar version on the front page? Or do you care if a moderator addds it for you?
                                Go ahead, Chris. 😉
                                And welcome, Amanda. 👍
                                • Jean-FrancoJ Offline
                                  Jean-Franco
                                  Hi, using 7Zip freeware you can unzip without any problems both .rar/.zip files and other compressed formats too.
                                  Jean-Franco
                                  • david_hD Offline
                                    david_h
                                    i've had no trouble with rar files with just good ol' winzip!
                                      archmolding
                                      Great Ruby!!! My only problem is I cant get my crown to be smooth! The Crown molding is Welded, and is smooth when i use the FollowMFolow me and keep test.skpe tool. Just not when I use this Ruby. (Im kinda new at this, Thank you)
                                      http://www.archmolding.net
                                        Could you upload the molding profile? The file you uploaded has it fulll of many extra interior faces, which makes me think maybe something is wrong with the profile.
                                          Yeah, a bunch of internal faces. Not a big deal to delete them however - just keep hovering over with (say) the PushPull tool and hitting Delete.
                                            archmolding
                                            Nice one Gai, that is what im trying to do, your trick did not work for me though.... But I would think that this Ruby would auto smooth the faces right?
                                            Chris,
                                            Here is a new file showing the moldings using the Follow me and keep and the SU FollowME. Using the Same molding profiles on each example. Also scene 3 has the profiles. Thanks for looking at it and the help!
                                            -Jesse
                                            Follow me and Keep test2.skp
                                            • 11
                                            • 12
                                            • 5 / 12
