    SP3 feature Thrusters.
    19 Posts 8 Posters 3.3k Views 8 Watching
    • C
      CPhillips
      @hobbnob said:
      what i meant is: can you have a thruster that is connected to a keyboard or slider, so it can change strength, as well as being a constant thruster as well. basicly, is it possible to combine two scripts?
      Not following that. Can you post an example?
      • H
        hobbnob
        you know that bit you put in the strength box(eg. -(0.5-righty)*5000), well, is it possible to have two in one box (eg. -(0.5-righty)*5000-(0.5-lefty)*5000)?
        My WIP Thread:Here
        • C
          CPhillips
          Yes, that should work.
          • H
            hobbnob
            thanks chris
            My WIP Thread:Here
            • C
              CPhillips
              Very Cool!
              • B
                BTM
                I tried using thrusters in a little game I made. I made a flyable spaceship, with retractable legs/grasper (when retracted above a ragdoll, works best with negative thrust turned on). It's pretty fun to use, but a little tricky to fly πŸ˜„
                spaceship game.skp
                controls:
                right X+Y (arrow keys): direction
                left Y (W and S): thrust
                left X (move only to the right/ D key): legs/grasper
                note: green side is front.
                updated post:
                I made a helicopter (model by Google) using a thruster, very easy to fly, accurate, and fairly fast.
                I used the script (0.5-lefty)*3500+slider('hover')*4000 to make it easier to fly, so you don't have to tap the thrust constantly, and can set the hover compensation to whatever you want
                (I wouldn't go below 35, or above 76 though)
                Also, the steering is made to keep the helicopter upright, and you'd have to change the settings for the servos if you'd want it to do flips or anything.
                helicopter game.skp
                controls:
                right Y (arrow keys): forwards+backwards
                right X (arrow keys): left+right roll
                left Y (W and S): thrust (more, or less)
                left X (A and D): left+right turn
                To turn, you could either roll while going forwards, turn while idle or moving, or do a mixture of both.
                • L
                  l.frisken
                  yes! this is great! making games can be so cool!
                  • L
                    l.frisken
                    btm, if you improve that helicoper a little more (or maybe sketchyphysics needs a little more tweaking) then this could be seriously great for games. So easy to make levels for it too! Already the helicopter is fun to fly!
                    • P
                      Physicsguy1
                      Frisken, There are also controllable planes. You can check them out on either hobbnob's account or my account. There are plenty of them, most of them are not alike. They are fun to fly and some are fitted with weapons.
                      • L
                        l.frisken
                        thanks for letting me in on that!
                        • W
                          Wacov
                          WIP on my next car game... improved stability and handling since warehouse upload, also with more detail on the dune buggy and slow reverse 'gear'... but, along with mid-air control, the best feature by far is the thruster-powered hyper-boost!! It's powerful enough to give you serious air-time, and you can even, um, drive vertically... πŸ˜„
                          Have fun!
                          Me about to crash....
                          leftx = steering
                          joyRY = throttle
                          a = Hyper-Boost
                          leftx/y = mid-air yaw/pitch
                          NOTE: Just the testing ground
