    Flatten a building...
    25 Posts 5 Posters 4.5k Views 5 Watching
      museummaker
      Another ruby... Drop
      it will crash to the ground
      • X
        xrok1
        smartdrop will work on a plane that isn't flat 😄
          Mark_S
          I found the drop.rb script but I think I get a popup saying "no such file to load - engine/command"
          I'm assuming this is another script that is needed for drop to run...where can I find it?
            Mark_S
            I found the drop.rb script but I get a popup saying "no such file to load - engine/command"
            MOD: delete above post please.
            • X
              xrok1
              you can delete your own last post. see the little eraser by the word edit. 😉
                Mark_S
                Hmm I don't have a little eraser...just "report this post"
                Either way...I installed the smartdrop plugin but I can't find it in sketchup.
                • X
                  xrok1
                  you need sketchup.rb in your tools folder, can you check for that?
                    require 'sketchup.rb'
                    You should have already had sketchup.rb in your SU V6 /Tools folder. If it is not there, I would suggest you re-install SU V6.
                      Mark_S
                      It was in the tools folder so I made a copy of it into the plugins folder but it still doesn't work 😕
                      • X
                        xrok1
                        the little eraser is only there as long as your post is the very last one, when someone posts after you its gone.
                        smartdrop and drop will appear in the right click menu near the bottom. drop and smartdrop only appear and work if you have a group or component selected. they won't work just on faces.
                          Mark_S
                          I'm sorry...but I'm having trouble figuring it out haha 😳
                          I'm uploading the .skp and if you have a moment could you try?
                          pieces.skp
                          • X
                            xrok1
                            first of all, i can't imagine how that's a building. 😆 but anyways; smartdrop and drop both need something to drop onto such as a face. but they will not rotate your shapes for you.
                              Mark_S
                              Well all the faces are unfolded already that's why it doesn't look like anything... 😄
                              ok so I figured out how to drop them to the same y plane. Now I just have to rotate them to all be on the same x plane. Thanks sooo much for the help
                              • X
                                xrok1
                                try this file 😉 don't forget that unfold doesn't have to be attached. 👍
                                pieces.skp
                                  Mark_S
                                  PERFECT! xrok...I can't thank you enough!
                                  And now...to build the model...here comes a looong night. Yay!
                                  • X
                                    xrok1
                                    i'd like to see pictures when you're done! 😛
                                    here's a pictorial of the process for next time. 😉
                                      Mark_S
                                      Thanks for the pic tutorial. I'll get pictures of the model up when it's done...even though it's not even a final model. How I love being an architecture student.
                                      • GaieusG
                                        the little eraser is only there as long as your post is the very last one, when someone posts after you its gone...
                                        😲 I didnát know that, thanks...
