    Flatten a building...
    25 Posts 5 Posters 4.2k Views 5 Watching
      museummaker
      I never used it but there is a Unfold Ruby that should do the trick
        Mark_S
        Ohhh thanks sooo much. That will work but I was thinking something along these lines...
        http://i49.photobucket.com/albums/f291/markszo/Picture1.png
          Mark_S
          I will try the Ruby script also
            Mark_S
            Heads up to everyone:
            The Ruby script does EXACTLY what I wanted it to do. Thanks so much. You guys are life(and time!) savers.
              Mark_S
              One more question...
              Now that I have all my pieces taken apart how do I get them to lay flat on the same plane? I know I could use the move/rotate tools but is there an easier way?
                museummaker
                Another ruby... Drop
                it will crash to the ground
                • X Offline
                  xrok1
                  smartdrop will work on a plane that isn't flat 😄
                    Mark_S
                    I found the drop.rb script but I think I get a popup saying "no such file to load - engine/command"
                    I'm assuming this is another script that is needed for drop to run...where can I find it?
                      Mark_S
                      I found the drop.rb script but I get a popup saying "no such file to load - engine/command"
                      MOD: delete above post please.
                      • X Offline
                        xrok1
                        you can delete your own last post. see the little eraser by the word edit. 😉
                          Mark_S
                          Hmm I don't have a little eraser...just "report this post"
                          Either way...I installed the smartdrop plugin but I can't find it in sketchup.
                          • X Offline
                            xrok1
                            you need sketchup.rb in your tools folder, can you check for that?
                              require 'sketchup.rb'
                              You should have already had sketchup.rb in your SU V6 /Tools folder. If it is not there, I would suggest you re-install SU V6.
                                Mark_S
                                It was in the tools folder so I made a copy of it into the plugins folder but it still doesn't work 😕
                                • X Offline
                                  xrok1
                                  the little eraser is only there as long as your post is the very last one, when someone posts after you its gone.
                                  smartdrop and drop will appear in the right click menu near the bottom. drop and smartdrop only appear and work if you have a group or component selected. they won't work just on faces.
                                    Mark_S
                                    I'm sorry...but I'm having trouble figuring it out haha 😳
                                    I'm uploading the .skp and if you have a moment could you try?
                                    pieces.skp
                                    • X Offline
                                      xrok1
                                      first of all, i can't imagine how that's a building. 😆 but anyways; smartdrop and drop both need something to drop onto such as a face. but they will not rotate your shapes for you.
                                        Mark_S
                                        Well all the faces are unfolded already that's why it doesn't look like anything... 😄
                                        ok so I figured out how to drop them to the same y plane. Now I just have to rotate them to all be on the same x plane. Thanks sooo much for the help
                                        • X Offline
                                          xrok1
                                          try this file 😉 don't forget that unfold doesn't have to be attached. 👍
                                          pieces.skp
                                            Mark_S
                                            PERFECT! xrok...I can't thank you enough!
                                            And now...to build the model...here comes a looong night. Yay!
