    Fake or Foto?
    29 Posts 18 Posters 2.7k Views 18 Watching
      Mr S
      Lightbulb, Tower of London and the Egg fooled me.
        remus
        To make this a bit more constructive, what do you think it is that makes people suspect an image is CG?
        For me the main thing is usually composition, particularly an overly perfect setup.
        • ToboboT Offline
          Tobobo
          I only got 5 😳
          Toby
          Philippians 4:13
          • MarianM Offline
            Marian
            I only got 3 wrong.
              chango70
              I got all of them correct except for tower bridge.
              • H Offline
                HFM
                For me it is only the 'overly perfect setup'. Things that make me think 'nothing is that perfect' 😄
                • F Offline
                  FenS
                  For me it is 'is that really possible in SU?, that must be real', or 'that really looks like something that you should make with SU'. I only got 2 wrong, but i would not have been supprised if would have misguessed every single one of them...
                  Qué sais je? there is still so much to be learned...
                    remus
                    I think the materials can often be a give away as well. For example the screw of the lightbulb has lots of little flecks of dirt and stress marks, stuff that would most likely be missed if it was modelled.
                    Having said that, the material on the gavel looks almost CG in its perfectness 😉
                      BTM
                      True... That, and overuse and 'perfectness' of effects, like field of view, as well as perfectly tiled textures (pattern around radio clock), and perfectly straight edges with no blur; a few things that gave some of them away.
                        remus
                        Dodgy DoF is also a dead give away (see the first pic for a good example.)
                          Phil Rader AIA
                          The Results
                          Twelve out of twelve answers are correct. Excellent-- a perfect score and a superior performance.
                          look for imperfections...like the light bulb has a funny dent or bend to the metal that makes the reflections slightly different. But the imperfections are not at a "placed" place i mean they need to be at a place that they would actually occur. Look at the textures do they look to perfect if they do than it's CG. Look at the teddy bear picture one of the bears is just slightly of kilter...there is just a natural randomness to the photograph but in CG the randomness seems forced.
                          just my 2 cents.
                          http://www.philrader.com
                          • Alan FraserA Offline
                            Alan Fraser
                            I got the teddies and the gavel wrong…guessed CG (which they could equally have been). In some cases it’s the depth of field giving it away…much too overdone on the croc. Tower Bridge is very well done; I guessed it was CG only because The Tower of London isn’t floodlit in the background.
                            The door had to be a photo, even if it was a model. You can’t use photo textures to that degree on something that is essentially flat and claim anything else.
                            3D Figures
                              remus
                              Thats interesting, i dont think the tower bridge pic is particularly good. looks a lot like a scale model to me.
                                Though, some of them where hard. It would all depend on how much attention to detail the CD artist did. Some tell tales are uniform textures, and that CG images often doesn't have scratches and imperfections. Though, it's not impossible to add these imperfections, it's usually "good enough" without.
                                  To me, it was the repeating texture of the bridge foundation where it meets the water that immediately stood out.
                                    BTM
                                    Me, it was the fact that a lot of the beams from the lights were completely out-of place, and very similar, and the bridge even seemed out of place from the background.
                                    • 2 / 2
