    [Plugin] Random Painter (Updated March 9th, 09)
    73 Posts 23 Posters 118.4k Views 23 Watching
    • E Offline
      Ecuadorian
      If someone has already worked on a "city generator" and makes it available for free, It wouldn't hurt to try and convince him to join the SketchUp Community and adapt those algorithms for SketchUp (either commercially or for free), share his source code, or provide an output in a 3D format SU can import. Check these efforts:
      This guy wrote a city generator include file for POV Render. The zip download includes the city script (which you can peruse with any text editor), some pre-made buildings in .obj format, and some documentation in .txt format:
      http://www.geocities.com/ccolefax/citygen.html
      And here's a way more sophisticated free city generator, scripted for Softimage's XSI (Now part of Autodesk):
      http://www.paoloemilioselva.it/citygenerator.html
      -Miguel Lescano
      • EarthMoverE Offline
        EarthMover
        My internet goes down for a week and so many great things happen on this site!
        Thanks so much Chris. I've been using 3DS Max a lot this week and one of the things I was playing around with quite a bit is the "Material by Element" modifier. When a Multi/mixed material is applied to an object, the modifier will randomize the various sub materials among the different elements nested within the object. It also allows you to add a percentage of each sub material that the modifier will apply.
        Max has material ID numbers which allow for the connection between materials and modifiers to be more fluid. I was wondering if there were a way via ruby to perhaps set the Random Painter script to call materials based on a naming function. Let's say I wanted to apply 5 random textures, or 5 variations of a single texture to group of faces. If those materials were named as Random_1, Random_2, etc, could the scripts be modified to called those textures and randomly apply them to the desired faces?
        Content Creator at Skapeup
        • Chris FullmerC Offline
          Hi Adam, just to clarify for my brain, you want essentially the same functionality but with image textures. Is that the idea? Or is it more in depth than just that?
          BTW, I don't know how to work with textures, so it will take me a little while to figure it out. But it should be possible.
            Chris, I think what he wants is to be able to use existing material instead of the plugin creating random new ones. You specify which materials you want the plugin to use, and the plugin will use them to paint faces randomly.
            • E Offline
              Ecuadorian
              That would be really cool... Just like Windowizer 3, where a drop-down menu lets you choose materials for each part!
              -Miguel Lescano
                Simon B
                You can also choose your colour values using this free utility from NOVOSIB:
                Not Found
                (www.linxexplorer.com)
                Visual Color Picker is very easy to use and powerful RGB-HSV-HSL-CMYK-HEX color selector. The program allows you to easily capture color value from any position of the screen even if program does not have input focus. The program has small screen capture preview area. By clicking associated button, you will get the associated RGB value in the dialog. The RGB color is automatically translated to RGB, HSV, CMYK and HTML HEX values. The program has standard and custom color tables. Text-background preview allows you to see how two colors will look next to each.
                I use it all the time 🤓
                  No Pantone/ RAL format? 😉
                    Hey, thats a great tool. I'll have to d/l it and play with it when I get home,
                    • EdsonE Offline
                      Edson
                      chris,
                      just for your information (i am not sure there is something you can do): having wxSU installed causes conflicts with windowizer4 (the dialogue appears blank) and immediate crashes after invoking it.
                      regards.
                      http://www.mahfuz.arq.br
                        Hi Edson, thanks for the note. I saw the post in Rick's windowizer script. Hopefully it gets worked out. I suppose I could also provide a version of random painter that does not require wxsu again.
                        • EdsonE Offline
                          Edson
                          i thought it would not work without it. 😕
                            Well, it is the nice User Interface that comes from wxsu. So I can remove wxSU and make pop up dialog boxes that require you to type in RGB values. Its more tedious than just clicking on the color you want. But it works fine. It is how the script worked at first. So if you'd like, I could re-write it and put the old inputbox version back. I'll just have 2 versions available for download. One with a nice GUI and one without.
                            • EdsonE Offline
                              Edson
                              i think it is a good idea and i would thank you for that. but i suggest you wait a few days to see if rick comes up with a solution to this problem.
                                Alex Jenyon
                                Great idea for a script - thank you! Should come in very useful for a bit of mattepainting.
                                I'm getting all kinds of errors with wxSU when sketchUP loads, which means that I haven't got 'randompainter' to run at all yet (though it's in the menu bar).
                                Obviously me having problems with wxsu is nothing to do with you at all 😳 , but until I can work out what's happening a version that doesn't require wxSU to run would be brilliant.
                                Thanks for all your work.
                                AJ
                                Concept artist / Matte painter
                                www.aj-concepts.net
                                  Oh bummer, sorry to hear it. I think I'll post a version that is independent of wxsu. Hopefully I can get it done today.
                                    OK Edson, I put another version of random painter up. It is non-reliant on wxsu. Its a bit slower to use, but I suppose if the other didn't work at all, then this is quite an upgrade 😄
                                    • EdsonE Offline
                                      Edson
                                      surely. thanks a lot. you have become quite an asset to this forum.
                                      is this "new" version up on the first post? why do you not keep both versions up? not all people use windowizer4; perhaps some would prefer the version that relies on wxSU.
                                        They are both up there - the latest version that supports wxsu and the stripped down version that does not. I think at some point I had added some features to pre-wxsu version that have been lost. So if there is something you remember it doing that it no longer does, let me know. All in all though, its still very functional. Thanks for the complements Edson, I'll let you take me out to a churrascaria if I ever make it down to Porto Alegre 😛
                                        • AdamBA Offline
                                          AdamB
                                          Cool plugin.
                                          However, I think wxSU isn't really ready for primetime. Specifically, it doesn't manage Ruby threads correctly wrt SketchUp.
                                          If you have a look at lib/App.rb there are some moderately scary comments. It seems to assume its the only plugin running - I think this is why it causes so many problems.
                                          Adam
                                            Adam, does having it installed for my plugin mean that it is possibly going to mess up other plugins?
                                            • 2 / 4
