    BEST landscape boulders ?
    43 Posts 23 Posters 19.8k Views 23 Watching
    • I
      Iglesias
      Very beautiful composition. I like it very much
      • david_hD
        david_h
        @solo said:
        David,
        I see you are getting into sub-smooth, there are a few new tools like 'UV tools' that can map your textures pretty well these days in SU.
        If you use bumps and/or displacement you can create some really cool rock textures too.
        I saw on another thread you enquiring about flower beds, Clipmaps will work on one view only (unless you are up to moving each on individually as 'face me' will not suffice)so I suggest modeling some low poly flowers (mapping the textures right) and using them as components.
        Thanks solo. . .as usual. . .I think I have UV tools. .. I just don't know what to do with them. . .I guess I need to play around with thos alittle bit more. I have so many rubies in my files it's hard to keep track of them all.
        Thanks for you input on the flower beds too.
        EDIT p.s. I do have UV tools. .. .I have no idea what it does. . . 😳
        • david_hD
          david_h
          oka--this is getting to be like "look what I did in school today Mommy" .. .but i have played around with the UV tools. . ..(thanks Solo) . . .and now I am starting to get it. okay .. it takes me a while. . .
          anyway. .thse are starting to look better. . .not like stupid dinosaur eggs or something. n'est-ce pas?20080801093644_1m42s.jpg20080801092535_1m54s.jpg20080801094610_3m49s.jpg
          • N
            neoshed
            Pardon my ignorance but where would I find the UV tools?
            • GaieusG
              Here you are
              http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=10404
              • EarthMoverE
                EarthMover
                I thought I'd add a collection of boulders I made a while back. They could use some retexturing, but the shapes are there. I used FFD on a sphere.
                Boulders.zip
                Content Creator at Skapeup
                • L
                  lz2008
                  thanks!!
                  • L
                    lz2008
                    I like it very much!!!
                    • utilerU
                      utiler
                      I need to do this too, Dave, I drool over Pete's work!!!!
                      Best make some time at big lunch to have a play....
                      Just Curious...
                      • B
                        BTM
                        my personal way of making boulders uses a rectangle, zorro, FFD, catmull-clark, polyreduce, and then texturing.
                        I make the rectangle, then I use zorro to add more organic subdivisions ( not uniform squares), then FFD to morph it, catmull-clark to get rid of some sharp edges (if you want), then polyreduce to lower the... well... polycount (if that's a real word). Then I texture it with U.V. tools or projected textures, and result:
                        I've got pics of the steps too, but can't post them here yet.
                        • utilerU
                          utiler
                          why not? would love to see then....
                          Just Curious...
                          • david_hD
                            david_h
                            So . .. what is this "Catmull-clark" of which I hear tell? And is this something I need?
                            tell me. . .. I want to know. . .
                            Hello. .. . Newman
                            • B
                              BTM
                              It's like subdivide and smooth (Sort of), in that it... well... subdivides and smoothes. Just not as well. It does it based on where lines are and such, so it's a bit random... which is good for boulders. And it's free. here's the steps showing the boulder after FFD, from catmull-clark to the end of polyreduce...
                              Link to the download page for catmull-clark: http://www.smustard.com/script/Subdivide
                              • utilerU
                                utiler
                                @solo said:
                                Texture using two different axis (I used a seamless texture found online and made seamless in PSP)
                                Hi Pete, where do I find 'seamless' textures? I like your process here... 👍
                                Just Curious...
                                • soloS
                                  Andrew,
                                  I can use any texture and make it seamless using either Crazybump, Imagesynth, Pixplant or even Photoshop, I prefer pixplant. Here is a screen shot and attached is the texture, it has diffuse, displacement, normal bump, and specular maps.
                                  http://img12.imageshack.us/img12/5308/pixplant.jpg
                                  seamless rock7.zip
                                  • utilerU
                                    utiler
                                    Thanks Pete, I'll have a look at these programs...
                                    Much appreciated!
                                    Just Curious...
                                    • K
                                      Karlfucious
                                      Thought I would make a couple as well. You can find them here [url](http://sketchup.google.com/3dwarehouse/details?mid=bcd911bb86acafe2e7526b618f37b43f[/url] if you are interested.
                                      http://img43.imageshack.us/img43/3583/boulderkitcomp.jpg
                                      • 2 / 3
