    [Plugin] SmartDrop Beta
    43 Posts 27 Posters 69.2k Views 27 Watching
    • F Offline
      Fletch
      could come in very handy indeed! thanks!
      Fletch
      Twilight Render Cross-platform Plugin for SketchUp on PC or Mac
      • tbdT Offline
        tbd
        nice work a4chitect
        http://plugins.ro
        • F Offline
          Fletch
          Note it changes the definition of group to add a .definition method.
          This makes group more similar to componentInstance.
          from your google group link... I find this fascinating as it's one the many little annoying things about SU that would have been fixed if they hadn't been bought by google... makes no sense why the axes work the way they do in SU6... either they should work like SU5, or allow you to adjust the axes w/out making them a component. obviously could be done. 😒
          a tool simply in the SU shell called 'reset axes' that only appeared for Groups would be very nice... since you can't do that in SU now.
          Fletch
          • X Offline
            xrok1
            this one definately deserves a bump 😄
            • soloS Offline
              I agree.
              I never knew it existed, and what a great script it is.
              • X Offline
                xrok1
                i noticed that ver.1.4 also lets you undo with one action. in ver.1 you had to undo each drop and each rotation.
                • N Offline
                  NewOne
                  Wow !! that's cool!
                  You did it 😄 It was a discution about this http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=14543&p=110383&hilit=+fish#p110359 but I never thought somebody will go on.
                  I see that the script drops only if object have a face on bottom. I tried to drop vertical planes or lines and did not worked.
                  • X Offline
                    xrok1
                    @newone said:
                    Wow !! that's cool!
                    the original drop.rb will drop lines to intersection but they won't be rotated. 😉
                      Works cool with the Chris Fullmer "Select Lines by Length" + "Components onto faces" ! ☀
                      • majidM Offline
                        majid
                        thanx for handy script. i tested old version and 1.4 version. old one workes fine , but recent one just unhides the component!!!! and nothing!
                        what is wrong whit me? or something about the script?
                          caddict
                          very nice!! Thanks!!
                          • X Offline
                            xrok1
                            bump 💚
                            • bagateloB Offline
                              bagatelo
                              I think about this:
                              http://forums.sketchucation.com/viewtopic.php?f=323&t=20233&p=223396#p223396
                                ckho1985
                                i try to run it with Skup 8, however without success. anyone tried?
                                • shuraS Offline
                                  shura
                                  Hi ckho1985, maybe Chris Fullmers Components onto Faces works in SU8. It gives similar results.
                                  xxx
                                    ckho1985
                                    I tried, but i found it is really difficult to use... or am I doing something wrong? i selected a grouped object and the face I want to drop on, however its not doing it.
                                    I miss smartdrop, just one click then it sits.
                                    • shuraS Offline
                                      shura
                                      Like the name says, it has to be components, not groups. 😉
                                      • Chris FullmerC Offline
                                        I just tried smart drop with SU 8, and it worked like a charm. What exactly about it is not working?
                                          ckho1985
                                          that's very strange. I assume there would be just one file (smartdrop.rb) to copy right? However, on my SU8, the smartdrop function is not showing at all. any idea why?
                                            You mean there is no command visible? You really need to specify what the problem is. For example, you try to run it, and SU crashes. You try to run it, and your entire model disappears. You try to run it and nothing seems to happen. You install it and SU no longer opens. You install it, but can not find how to start the plugin. Please help us understand what the problem is.
                                            If you just can't figure out where to start it, it is in the right click menu when you have components selected.
                                            Good luck,
                                            • 3 / 3
