    [Plugin] Components onto Faces v1.2.0 UPDATE May 23, 2013
    61 Posts 16 Posters 75.4k Views 16 Watching
    • E
      Ecuadorian
      @chris fullmer said:
      And I have a little bit of script background, but I really mean very little.
      I hope assigning basic functions (play, stop) to Flash buttons in ActionScript also count as a "little experience", as that's all I have done, and I have already forgotten how it was done...
      Anyway, I've found this Ruby interactive tutorial for anyone interested:
      http://tryruby.hobix.com/
      Hackety Hack also seems to be a good resource, but they're currently updating it:
      http://hacketyhack.net/
      -Miguel Lescano
      • C
        Click Draw
        Any way to apply a brick like finish to a wall? Multiple components to face?
        Jeff
        Have I mentioned how much of a laugh I get out of some of the Signatures on here!
        • free agentF
          free agent
          thank you, very handy script!! and good idea for grouping your scripts into one subfolder, everyone should do that, soon the plug-ins menu will be a list of ruby script writers names. ๐Ÿ˜†
          question: is there another 3d with more plug-ins than sketchup?
          http://i167.photobucket.com/albums/u143/FreeAgent84/bug.gif
            The inverse of the Spray components by Didier Bur ๐Ÿ˜‰
            And totally indispensable for many different uses! โ˜€
            • X
              xrok1
              Jeff
              PS chris as you can see there is some logic to the alignment, ๐Ÿ˜ณ but i'm sure you know that better than i. ๐Ÿ˜‰
              โ€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.โ€
              • X
                xrok1
                Well, until I start making something I can charge for. Then just cold hard cash will suffice ๐Ÿ˜„
                i bet people would pay for a soft selection tool that would function with all the other tools, move, scale...๐Ÿ˜„
                the codes even hanging around in there somewhere (smoove). ๐Ÿ˜‰
                • C
                  Click Draw
                  Hey xrok1,
                  I assume you just used copy and paste???
                  Jeff
                  • X
                    xrok1
                    no? i used the script!
                    • C
                      Click Draw
                      Really?....kinda feeling silly now....how did you do it?
                      • X
                        xrok1
                        well... are you ready for this?
                        1] use construction grid (ruby) to make a grid
                        2] use edges from construction lines (ruby) to convert construction lines to lines
                        3] delete every second vertical line, staggering each row
                        4] use make faces (ruby) to make faces
                        5] build a brick and make it a component
                        6] run Components onto Faces v0.1 (ruby)
                        ๐Ÿ˜†
                        i told you there were easier ways.
                        if i had to do it all over again i would just make a rectangle the size of a brick with half a mortar joint. inset the face a little...
                        you know the rest.
                        • C
                          chango70
                          Amazing Script! Cheers!
                          • I
                            ilay7k
                            Chris, thank you for such panelization tool!
                            I attached sample with slightly modified by Fredo's tools
                            Uhh, need quads for for beautiful visualization for panels
                              is that normal?
                                About your bug of 2 components on a "same face" โ˜€
                                A tricky thing with your "Select lines by lenght" ๐Ÿ˜‰
                                Make the Surface with the Sandbox "By scratch"
                                Explode it
                                Enable Hidden geometry
                                Select one little diagonal of a square
                                your very tricky "Select lines by lenght"
                                Delete it
                                "Components onto faces"
                                Et voilร ! ๐Ÿ˜Ž
                                Edit hum hum works only if the tin stay "flat" ๐Ÿ’š
                                Maybe use the Smart Drop in addition! By a4architect โ˜€
                                Soon little tut ๐Ÿ˜‰
                                • Chris FullmerC
                                  Wow, great stuff everyone! I really like that paneled wall ilay. Looks great. And thats a cool method using smart-drop Frenchy. Thanks for showing it.
                                  Oh, and the menu is how I made it, but not really for any good reason I guess. I was hoping to have one or two other items in that sub-sub menu too, but I have not got them written yet. So I was planning ahead, but perhaps too early. Hopefully in time I'll get some more ability written into this script. I am currently working on solving the triangulated faces issue. I think I have a solution. I think.
                                  • boofredlayB
                                    boofredlay
                                    • Chris FullmerC
                                      You could do some serious off-roading with those tires! Or some serious damage. Either way, they look super cool!
                                      Is each face truly one square face and not 2 triangle faces with the middle line smoothed? If it is 2 triangles, how did you get around that issue where it copies a component to each of the 2 faces?
                                      • boofredlayB
                                        boofredlay
                                        Each is a single face, not 2 triangles.
                                        I used the sphere ruby to create a sphere then used your script to apply the component to a portion of the sphere. Then I deleted the extra and filled in with sidewalls. The bad part is I cannot think of any cool vehicle to place these under ๐Ÿ˜†
                                        • boofredlayB
                                          boofredlay
                                          Ok, so I found something... ๐Ÿ˜„
                                          • X
                                            xrok1
                                            you best be replac'n them there irons with some shoot'n irons where that thin's gona be a tak'n ya yer gona need 'em. he he... ๐Ÿ‘
                                            • 2 / 4
