    [Plugin] Components onto Faces v1.2.0 UPDATE May 23, 2013
    61 Posts 16 Posters 75.4k Views 16 Watching
    • C
      Click Draw
      Any way to apply a brick like finish to a wall? Multiple components to face?
      Jeff
      Have I mentioned how much of a laugh I get out of some of the Signatures on here!
      • free agentF
        free agent
        thank you, very handy script!! and good idea for grouping your scripts into one subfolder, everyone should do that, soon the plug-ins menu will be a list of ruby script writers names. ๐Ÿ˜†
        question: is there another 3d with more plug-ins than sketchup?
        http://i167.photobucket.com/albums/u143/FreeAgent84/bug.gif
          The inverse of the Spray components by Didier Bur ๐Ÿ˜‰
          And totally indispensable for many different uses! โ˜€
          • X
            xrok1
            Jeff
            PS chris as you can see there is some logic to the alignment, ๐Ÿ˜ณ but i'm sure you know that better than i. ๐Ÿ˜‰
            โ€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.โ€
            • X
              xrok1
              Well, until I start making something I can charge for. Then just cold hard cash will suffice ๐Ÿ˜„
              i bet people would pay for a soft selection tool that would function with all the other tools, move, scale...๐Ÿ˜„
              the codes even hanging around in there somewhere (smoove). ๐Ÿ˜‰
              • C
                Click Draw
                Hey xrok1,
                I assume you just used copy and paste???
                Jeff
                • X
                  xrok1
                  no? i used the script!
                  • C
                    Click Draw
                    Really?....kinda feeling silly now....how did you do it?
                    • X
                      xrok1
                      well... are you ready for this?
                      1] use construction grid (ruby) to make a grid
                      2] use edges from construction lines (ruby) to convert construction lines to lines
                      3] delete every second vertical line, staggering each row
                      4] use make faces (ruby) to make faces
                      5] build a brick and make it a component
                      6] run Components onto Faces v0.1 (ruby)
                      ๐Ÿ˜†
                      i told you there were easier ways.
                      if i had to do it all over again i would just make a rectangle the size of a brick with half a mortar joint. inset the face a little...
                      you know the rest.
                      • C
                        chango70
                        Amazing Script! Cheers!
                        • I
                          ilay7k
                          Chris, thank you for such panelization tool!
                          I attached sample with slightly modified by Fredo's tools
                          Uhh, need quads for for beautiful visualization for panels
                            is that normal?
                              About your bug of 2 components on a "same face" โ˜€
                              A tricky thing with your "Select lines by lenght" ๐Ÿ˜‰
                              Make the Surface with the Sandbox "By scratch"
                              Explode it
                              Enable Hidden geometry
                              Select one little diagonal of a square
                              your very tricky "Select lines by lenght"
                              Delete it
                              "Components onto faces"
                              Et voilร ! ๐Ÿ˜Ž
                              Edit hum hum works only if the tin stay "flat" ๐Ÿ’š
                              Maybe use the Smart Drop in addition! By a4architect โ˜€
                              Soon little tut ๐Ÿ˜‰
                              • Chris FullmerC
                                Wow, great stuff everyone! I really like that paneled wall ilay. Looks great. And thats a cool method using smart-drop Frenchy. Thanks for showing it.
                                Oh, and the menu is how I made it, but not really for any good reason I guess. I was hoping to have one or two other items in that sub-sub menu too, but I have not got them written yet. So I was planning ahead, but perhaps too early. Hopefully in time I'll get some more ability written into this script. I am currently working on solving the triangulated faces issue. I think I have a solution. I think.
                                • boofredlayB
                                  boofredlay
                                  • Chris FullmerC
                                    You could do some serious off-roading with those tires! Or some serious damage. Either way, they look super cool!
                                    Is each face truly one square face and not 2 triangle faces with the middle line smoothed? If it is 2 triangles, how did you get around that issue where it copies a component to each of the 2 faces?
                                    • boofredlayB
                                      boofredlay
                                      Each is a single face, not 2 triangles.
                                      I used the sphere ruby to create a sphere then used your script to apply the component to a portion of the sphere. Then I deleted the extra and filled in with sidewalls. The bad part is I cannot think of any cool vehicle to place these under ๐Ÿ˜†
                                      • boofredlayB
                                        boofredlay
                                        Ok, so I found something... ๐Ÿ˜„
                                        • X
                                          xrok1
                                          you best be replac'n them there irons with some shoot'n irons where that thin's gona be a tak'n ya yer gona need 'em. he he... ๐Ÿ‘
                                          • Chris FullmerC
                                            UPDATE: v1.0 released - The video in the beginning is also updated
                                            This new version has a new tool called "Components onto Face Collections". It treats collections of faces that have had their edges smoothed/hidden as a single face. So the terrain issue where it was copying 2 components onto each collection of faces is fixed. The new tool will only copy a single component onto the 2 faces. I hope that makes sense and I hope its helpful,
                                            • 2 / 4
