    [Help]- How do I drop a Object and make it flat on XY axis?
    16 Posts 6 Posters 1.9k Views 6 Watching
    • Chris FullmerC
      But that depends on how the axis is set up in the component. If it is set up on the angle with the component, then yes my plugin actually will help (surprising, I know!). But if the axis is aligned to real world axis, then my plugin won't quite help unfortunately. And I'm going to guess that SU aligned its axis to the world axis system unfortunately. But you could edit it and change it as best you can by hand.
      • C
        chango70
        Hmmm does anyone know if sketchy physics can help in this situation?
        • X
          xrok1
          as far as i can see it should try it. did you try chris's script?
          • C
            chango70
            Yes but because of the geometry's group box isn't oriented properly it doesn't drop flat.
            • C
              chango70
              Howto.skp
              I've uploaded the file, can someone give it a go? I can't figure out sketchy physics, it keeps giving me bug splats...
              • X
                xrok1
                i finally found a practical use for SP
                Howtolevel.skp
                • C
                  chango70
                  Amazing! How did you do it?
                    remus
                    You can do it natively in SU by drawing a line between opposite points on the shape then making it in to a plane. You can then rotate the shape+plane to get it flat then move the shape down.
                    Proof:
                    Howto_native.skp
                    • B
                      BTM
                      that would be easy. group it, convexhull, play, it lands flat, pause, save a copy as., and you're done. works for action poses too, if you have something in the middle of breaking down a wall or something.
                      • X
                        xrok1
                        the convexhull is probably what you missed. that and saving the file while the geometry was on the ground, oh that and you didn't have a (static) ground plane in your scene for it to land on. 😛
                        • C
                          chango70
                          lol YES! Convexhull! I was trying static mesh the whole time... THX Everyone!
                          • Chris FullmerC
                            And if you ever need a script that would add spikes to everyone of those faces, you know where to find that in the future too 😄.
