    [Help]- How do I drop a Object and make it flat on XY axis?
    16 Posts 6 Posters 1.9k Views 6 Watching
    • X
      xrok1
      i remember seeing these and not knowing why in the world anyone would need or write them but... :
      FREE:http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=10599
      $10:http://www.smustard.com/script/Flatten
      • GaieusG
        I don't think Chango means to get it into a 2D shape as the simple Drape tool of the Sandbox or Didier's project scripts could do that.
        But why not rotate?
        • X
          xrok1
          i think Chris may have answered your prayers earlier this very evening:
          http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17306
          • Chris FullmerC
            But that depends on how the axis is set up in the component. If it is set up on the angle with the component, then yes my plugin actually will help (surprising, I know!). But if the axis is aligned to real world axis, then my plugin won't quite help unfortunately. And I'm going to guess that SU aligned its axis to the world axis system unfortunately. But you could edit it and change it as best you can by hand.
            • C
              chango70
              Hmmm does anyone know if sketchy physics can help in this situation?
              • X
                xrok1
                as far as i can see it should try it. did you try chris's script?
                • C
                  chango70
                  Yes but because of the geometry's group box isn't oriented properly it doesn't drop flat.
                  • C
                    chango70
                    Howto.skp
                    I've uploaded the file, can someone give it a go? I can't figure out sketchy physics, it keeps giving me bug splats...
                    • X
                      xrok1
                      i finally found a practical use for SP
                      Howtolevel.skp
                      • C
                        chango70
                        Amazing! How did you do it?
                          remus
                          You can do it natively in SU by drawing a line between opposite points on the shape then making it in to a plane. You can then rotate the shape+plane to get it flat then move the shape down.
                          Proof:
                          Howto_native.skp
                          • B
                            BTM
                            that would be easy. group it, convexhull, play, it lands flat, pause, save a copy as., and you're done. works for action poses too, if you have something in the middle of breaking down a wall or something.
                            • X
                              xrok1
                              the convexhull is probably what you missed. that and saving the file while the geometry was on the ground, oh that and you didn't have a (static) ground plane in your scene for it to land on. 😛
                              • C
                                chango70
                                lol YES! Convexhull! I was trying static mesh the whole time... THX Everyone!
                                • Chris FullmerC
                                  And if you ever need a script that would add spikes to everyone of those faces, you know where to find that in the future too 😄.
