    [Plugin] Proper Animation V1.08 Beta(Updated 14/11/10)
    246 Posts 108 Posters 229.6k Views 108 Watching
      I don't believe you can 😞
      You can reduce time between scene transition (Menu View / Animation/ Settings)
      Or in this particular project : Use just 2 Scenes! πŸ˜‰ So no need beetween's levels floors β˜€
      • Tim DanaherT
        Tim Danaher
        Yes, that's what I figured...
        Is there, I wonder, a Ruby that allows you to vary the time transition between scenes? In combination with Proper Animation, that would be really cool.
        Cheers,
        Tim
        http://vizarch.blogspot.com
          That 's existing! β˜€
          And it's for the Proper animation! πŸ˜’
          Look here made also by Morisdov πŸ’š
          Ruby script plugin Controlling Animation Scenes Transition Times
          NΒ°4 Set_Transition_time.rb
          Tell me if it's good for you πŸ˜‰
          • Tim DanaherT
            Tim Danaher
            Fabbo...
            Blimey, I'll be able to get a whole othter article out of this... πŸ˜‰ πŸ˜‰ πŸ˜‰ !
            Cheers,
            Tim
              @Tim
              Just now see you Blog! 😳
              Funny because I had known your crazy modelings and animations on youtube for a while and was astonishing by the complexity of the structures! πŸ‘
              Happy that I can help you πŸ˜„
              • Tim DanaherT
                Tim Danaher
                  Fame at last!!!!
                Cheers,
                Tim
                  As seems you love schizophrenic structures πŸ˜„ take a look to TopMod πŸ˜‰
                  Free Standalone + Accept Import OBJ format (Ngons !) and export OBJ format (save as! )
                    morisdov
                    Thanks for the support guys
                    To Clarify usage below are some details
                    Each Position number X, corrsponds to the X'th sketchup Scene/Page
                    Position 1 will be for the FIRST scene tab
                    Position 3 will correspond to the THIRD tab etc
                    1) to begin with Set position number X, and Get position number X, you dont care about scenes or number of them. just make object selections, and Set their positions, move them and set additional positions, Get positions manually to see how things paly out
                    2) after you finished Setting the positions of various objects you may add scenes/pages as many as positions as you have or more
                    3) only now you should START the ANIMATION OBSERVER
                    this will make all objects that have position 2 set, to ANIMATE (move) to position 2 when you clickon the SECOND scene tab.
                    click FOURTH tab, objects with position 4 will animate to position 4
                    4) STARTing Animation Observer automates the objects animation by using scene tabs instead of manual right click command GET position X - via corresponding click on SCENE X in the order of scenes
                    5) to modify object positions and scene view angles youd want to STOP ANIMATION OBSERVER, otherwise the objects keep on moving disturbing your adjustments of new positions etc
                    so STOP ANIMATION OBSERVER, make adjustments
                    START ANIMATION OBSERVER again to use scenes tab clicks instead of GET position X
                    6) not all objects need to have all position numbers set, just those few you want to move on X'th scenes tab click
                    7) you can select multiple objects and SET their position X in one command click
                    8) to "enable" the command of "GET to position X" those objects currently selected should have "Position X" set or otherwise - the right click menu command "GET position X" will be grayed out ("disabled")
                    this way you can find out if an object has position X set or not, or groups of selected objects have position X set or not πŸ˜‰
                      Thx for precisions 😎 πŸ˜„
                      • Tim DanaherT
                        Tim Danaher
                        Cheers Moris...
                        And thanks for the link, Pilou -- that's some crazy sh1t!
                        Cheers,
                        Tim
                          skyscraper100
                          hi πŸ˜‰
                          if ive made an animation with this plugin, can i export and render it in kerkythea?
                          thanks πŸ˜„
                          The way you think Creates reality for yourself.
                          • E
                            Ecuadorian
                            You can "render" it inside SketchUp if you install Whaat's "Smooth Animation" plug-in and use the "export smooth animation" command.
                            BTW, Thank you very much, Morisdov.
                            -Miguel Lescano
                            • C
                              Chris-69
                              Most of the time i can solve most of the problems by reading the forums... πŸ˜„ (Thanks for that)
                              But i have a problem by using the "scenes transition times". I have more than 27 scenes.
                              I can't see more scenes when i want to set the times in this plug-in. Using the "tab", i can "blind" set the times, but i can't see it. Is there a solution?
                              ❓ Thanks!
                              Dulish new language? :smile:
                                ❓ Thanks!
                                Use the Scene manager window?
                                  Yes you right, there is a little problem πŸ˜„
                                  We must send a PM to Morrisdov!
                                  Done Wait and see πŸ˜„
                                  Till that you can move your sketchup window to the bottom screen and call the Scene transition, with that you can see 38 scenes πŸ˜‰
                                    morisdov
                                    quick solution is to use the following line in the ruby console to set the current selected scene -
                                    Sketchup.active_model.pages.selected_page.transition_time = 4
                                      One tricky solution indeed πŸ˜‰
                                        sambort
                                        nice work!
                                        but can someone upload one example with differents Scene Transition Times and/or Scene Delay Times? or can anybody explain what its wrong?
                                        because mys examples don't seems to work, some times the object arrive to position before the scene to it. it's not clear to me.
                                        thanks a lot!
                                        • C
                                          Chris-69
                                          Thanks for the quick response!
                                          It Works! Many, many thanks!
                                          • E
                                            evgenia
                                            How to fix the animation picture in the body of mail? When i try to send the mail with animation picture attachment, picture link only found in the recipient end. How to fix the picture in the composer body itself?
                                            keyword research ~ keyword tool ~ keyword tracking ~ affiliate elite
                                            • 12
                                            • 13
                                            • 4 / 13
