    [Plugin] Three Line Tools (Updated March 9th, 2009)
    117 Posts 43 Posters 88.5k Views 43 Watching
    • Chris FullmerC
      Heehhe, glad you remembered. And I think over last weekend it made the jump to 2.0 when I made the toolbar. That was new. I didn't know that toolbars require some diffferent menu coding than just regular menus. So that was good to learn. I also made it register itself with the plugins extension manager. So I felt like those 2 things really made it a real script that should be a full 2.0. Silly little script,
      • JClementsJ
        JClements
        Hi Chris:
        Just saw your update. Nice going.
        The Normals line tool might proof to be helpful in setting up the camera for particular scenes.
        1- Draw a "Normals" line
        2- Click drag the Position Camera Tool from one endpoint of the Normals line to the other endpoint.
        John
        • BurkhardB
          Burkhard
          This script I can use also excellent for light fittings in Su Podium, thanks.
          Remember a request I do before. Can a normal set vertical to a line? Just the opposite of this fantastic script ( for ie balustrades or other stuff doing by follow me tool )
          ....and I know your workaround Ecuadorian πŸ˜‰ but looking for a better solution.
          http://www.ia-plus.de
          • Chris FullmerC
            Hmm, I'm trying to figure this out. A vertical line is vertical. And a mormal line is perpendicular to its base face/edge/vertex. Exaplain again what it is you would like? Maybe a diagram is needed πŸ˜„
            • BurkhardB
              Burkhard
              sorry, for that. With your script you can set the line vertical to a plane/face. The opposite should be to set a face vertical to a line. ( If you have a stair and need to set the handrail as a profile to the line which follows the stairs, it is not easy to set the plane vertical to that line.) Just an idea for making it easier, but I know it is a bit highjacked here.
                Ah, yea. That'd be useful. All though, after Profile Builder it's been less of an issue.
                But being able to set a drawing plane relative to an edge would be great.
                ...and cue version 3... πŸ˜‰
                • Chris FullmerC
                  Just adding a face perpendicular to a line end is easy enough to do. It could be the same thing where it will use the VCB values to determine its size. I would probably make it grouped from the start so as to not interfere with other geometry. And it probably would just have to be a square face that can be used as a drawing plane. Though I suppose it would not be too hard to make a tool that you could select a face, then click on a line end and it could redraw that perpendicular to the line end. Maybe one face tool, one circle tool and one copy any face onto the end of a line tool. So like 3 new tools? And how much of this is done in profile builder?
                    Well, profile builder let you add faces as profiles to it's library where you then select the profiles from a list where it then performs a FollowMe operation on the selected path.
                      A Tool Idea I've been toying with is a Drawing Plane tool. A tool that let you define a virtual plane to which drawing tools can be used on, allowing you to draw geometry in empty space. Not quite sure how it'd be implemented though...
                      • BurkhardB
                        Burkhard
                        Just a reminder, the profile builder is a great tool but it's commercial and not for everyone who don't need profiles a lot. This should be an easy step for the follow me tool. Let's see if there is a solution πŸ‘
                        To set up a plane to draw onto for follow me rotations is one tip I always suggested to my people when they are lost in free space. Yep, nice ideas here πŸ˜›
                        • Chris FullmerC
                          Well, its coming along nicely. I've got it mostly working for a single square face right now. Then I'll add a circle ability since many times we use plain circles. Then lastly will be a way to first select a face, then activate the tool and click onto a line endpoint and it will add that face to the end of the line perpendicularly. Once I get the face one working all the way, the others will be pretty straightforward. Hopefully I'll have it all done by late tongiht.
                          I think I need to create a single clf tools menu item and then add all my scripts under that single menu item. I feel bad clogging up people plugins menu with these small, but useful scripts.
                            dtrarch
                            Super and much needed script-ete
                            A Move / Copy option like in Didier's Align script so one can keep the profile if needed would be nice to have.
                            On a workaround (no ruby)that I cobbled up it worked to use a group/component and just explode when it was properly located as moving a plain face if attached to path will just drag the endpoint along with it.
                            My work-around alignment solution is attached for what help it may be.
                            In any case thanks a bunch for even giving this a shot.
                            dtrORTHO TO LINE.skp
                            • X
                              xrok1
                              sorry if this is a little off, but i have to know what this is:Capture.JPG
                              Jim, maybe you could move this to a more appropriate place. 😳
                              • Chris FullmerC
                                No worries, that is free-form deformation.
                                • X
                                  xrok1
                                  sorry to keep going here, but. how did you manage to get a toolbar for it?
                                  • Chris FullmerC
                                    I believe that it was bundled with the SCF power tools toolbar. I don't that is available right now, but will probably be coming back in time after some copyrights get worked out. It was provided by Cad Father. I believe he made the icons.
                                    • X
                                      xrok1
                                      thanks, sorry for the off topic, just curious.
                                      it would be sweet if someone would write a snippet of code that someone like myself could use to make our own toolbar. we could just add buttons, and link them to the ruby's we have. πŸ˜‰
                                      • Chris FullmerC
                                        Ahh, I see. Ok, I have some ideas how to set this up. It might just be a new tool altogether. Something like Perpendicular Face Tools.
                                        EDIT: From this conversation, I have since made Perpendicular Face Tools
                                          Does it possible to have the "line" as a component in the native plug? ❓
                                          Like this any difficulty to replace it by anything! β˜€
                                          PS a simple line can't make a component but if draw 2 lines, select both, make component
                                          Then edit component, kill the second line, close component = you have a simple line as component! πŸ’š
                                          • Chris FullmerC
                                            Yeah, its possible to make each line be a separate component. I think I could get all lines to be an instance of a single componeont too.
                                            As for makeing a component of a single line - it still works if you use the keyboard shortcut. On my computer it is defaulted as g. Select a single line and hit g and it will become a component.
                                            • 4 / 6
