    Text on 2D plans
    16 Posts 10 Posters 1.9k Views 10 Watching
      Jim
      It doesn't sound like you're concerned with the text rotating with the view. Did you use the double-click method to place the text on the object? Double-click on a face with the Text tool ( ) to attach text, without leader, to the face.
      • GaieusG
        @jim said:
        Double-click on a face with the Text tool to attach text, without leader, to the face.
        Gee, thanks Jim! I didn't know that! 😳
        Although the text this way will still "rotate" with its "face" towards the view,it will indeed be attahed to the face! 👍
        • P
          pecan
          @jim said:
          ... Double-click on a face with the Text tool to attach text, without leader, to the face.
          Wow! I gave up on the Text tool becaue I didnt know we could do this.
          Double click... who knew?
          thanks Jim.
          • P
            paulside
            An even better solution is to download the TexTag plugin from
            http://www.crai.archi.fr/RubyLibraryDepot/Ruby/em_tex_page.htm
            this allows you to fix a text lable onto any surface, the lables are automatically put on a separate layer and they rotate with the surface, see attached images
            • Wo3DanW
              Wo3Dan
              @paulside said:
              ...An even better solution is to download the TexTag plugin from......
              (see post above)
              For planview text and dimensions IMO neither the 'Text' tool nor the '3D Text' tool are preferable.
              The first because of the rotating text depending on the view angle.
              The second for 'memory consuming' reasons. I suspect the plugin mentioned above is about using the second tool (3D Text) although I could be wrong.
              I prefer the 'Dimension' tool that lets you use text that sticks to the plan (or any plane, vertical or slanted) undependant of the view angle. See attached file. And it will not increase file size like any flat '3D Text'.
              Wo3Dan
              PlanviewDimensioning.skp
                Jim
                Hi wo3Dan,
                That's really a great solution.
                  massimomorandi
                  I DONT KNOW IF COULD HELP
                  I USE THIS METHOD:
                  1 MAKE A TEXT NOT LINKED TO ANY OBJECT (WITHOUT ARROWAY)
                  2 GROUP THE TEXT
                  3 MOVE IT EVERY WHERE
                  4 COPY AND CHANGE IT IF YOU WANT ANOTHER
                  THE TEXT NOW IS INDIPENDEN BUT NOT VIEW-LINKED
                  • mitcorbM
                    mitcorb
                    To Wo3Dan:
                    How do you remove the dimension witness lines and just keep the text? I didn't see any way to do it in entity info, nor was explode available.
                    mitcorb
                    edit: oops, paulside, didn't mean to jump in too soon.
                    • P
                      paulside
                      Hi Wo3Dan
                      Interesting!
                      Please enlighten me I must be missing something obvious,
                      How do you set up the dimension tool to zoom the text relative to the view angle and how do you hide the dimension lines?
                      [Edit] Ok just figured this out:
                      The dimension needs to be Non Associative, then scaled down to eliminate the dimension lines, no endpoints, the font size needs to be set to 'Size' not 'Points'
                      Not as simple as the TexTag, also you can't have different coloured lables - but it works
                      Neat!
                      • X
                        xrok1
                        you need to be aware that if you're going to render, not all of these methods will show in your render. for example the dimension method does not render and the TextTag plugin does. iwould expect that if your want to render your results that your need a method that actually produces geometry (faces), also i would suspect that the face you produce needs to stand off the face that its on or the results may be garbled.
                        so if you need to render its seems the TextTag plugin is the way to go.
                        • Wo3DanW
                          Wo3Dan
                          @paulside said:
                          ....Please enlighten me I must be missing something obvious,
                          [Edit] ...The dimension needs to be Non Associative, then scaled down to eliminate the dimension lines, no endpoints, the font size needs to be set to 'Size' not 'Points'
                          (not quite true, see blue text below)
                          This is how it works (it has been discussed before).
                          • Draw an edge.
                          • Tripple click on it with the 'Dimension' tool.
                          • Adjust the dim to be as close to the edge as possible (ON the edge, so to speak).
                          • Select the edge and edit its length in 'Entity Info' to 1mm (very short but not less).
                          • Select only the edge and delete it(*). From now on the short not associated dimension is on its own.
                          • you can group it or even save it as a component BEFORE you delete the edge.
                          • you can now set the dimension to: alligned to dimension / centered
                            ---------------------------------------Text position: centered
                            ------------------------------------------Endpoints: None
                          %(#0000FF)[You can do anything with it like: (what I did) change font to CityBlueprint/fat/(fixed)height to 500mm
                          You can even color each dimension its own color, assign them (with others) to their own layer(s)]
                          It's maybe best to create a dimension component to have in your comp.library.
                          Once you made the component it can be used multiple times without the hassle.
                          Remember that once you place the component you need to explode it and edit its text.
                          (otherwise same components will all change by changing one!)
                          You can even dump copied long text from Word into the dimension.
                          (Standard text that you saved somewhere in a text file)
                          Wo3Dan
                          p.s. If you want to see their different colors you need to
                          uncheck 'Highligth non-associated dimensions' in 'Model Info' => 'Dimensions' =>
                          'Expert dimension settings' and of course paint them.
                          • N
                            newbuyer17
                            Thanks Guys. Looks like I've started an interesting debate anyway.
                            I haven't had a chance to progress any of your ideas yet due to time contraints, but have some ideas anyway. Hopefully the double click will be enough, otherwise the dimension trick also looks good.
                            Will post again when I get somewhere, just wanted to post and say thanks in the meanwhile.
                            • Jean LemireJ
                              Jean Lemire
                              Hi folks.
                              For the ones who did not know that a double click with the Text Tool will attach a text to a surface , it is written in the User Guide at page 257:
                              ---------- BEGINNING OF EXCERPT ----------
                              Attaching Text Directly to a Face
                              Double-click on a face with the Text Tool to attach text, without leader, to the face.
                              ---------- END OF EXCERPT ----------
                              Just ideas.
                              • GaieusG
                                Hi Jean,
                                You can understand the reasons but I still use the "Old Guide". Yet on the Text tool page there is also some mentioning of double clicking though it's a bit more obscure:
                                http://download.sketchup.com/sketchuphelp/gsu6_win/Content/Z-images/Icons/tip-32.png
                                Tip- Double-click on any face, while in the Text Tool, to display the area of the face as a Text entity.
                                Thanks for your tip however... 👍
