    Connect aray to an arc?
    5 Posts 5 Posters 380 Views 5 Watching
      bisctboy
      I'm using SU for the first time and I can't seem to figure out how to connect an aray of slats to an arc that I made. What I'm trying to make is a garden bench that has a contoured seating surface. My aray is in a straight line and the arc obviously isn't. How do I connect the various objects in my aray to snap to the curve on the arc? I have attached the skp file to help explain what I'm asking.
      Thanks,
      bench.skp
        remus
        I dont really know of any easy way of doing this, you basically just have to move and rotate each piece in to place.
        It might be slightly faster to draw a rectangle for each slat on to the support bit and then push pull it.
        • Wo3DanW Offline
          Wo3Dan
          @bisctboy said:
          ...... My aray is in a straight line and the arc obviously isn't. How do I connect the various objects in my aray to snap to the curve on the arc? ......
          Please see attached file:
          bench.skp
          • ToboboT Offline
            Tobobo
            Try using the Copy along a path script from the Ruby Depot
            404 Not Found
            (www.crai.archi.fr)
            It is call Pathcopy.zip or pathcopy.rb
            You have to create the slat as a componant and the you can get it to rotate (I think)
            Edit: You might want to get 'weld.rb' from the same page, this script allows you to join lines together, this will help if you have a long curved section.
            Toby
            Philippians 4:13
              Simon B
              If you have access to Adobe Illustrator, you can use the customise brush tool to create the slat profiles along a curve, and then import the results into SU.
