    Whats the most Cost Effective Animation Renderer????
    extensions
    25 Posts 12 Posters 5.9k Views 12 Watching
    • SektaS Offline
      Sekta
      Hi All,
      The day has finally come which I was dreading. ๐Ÿ˜ฎ ๐Ÿ˜ฎ One of my clients asked me today for a a full rendered AVI of his project. I have done simple SKP fly throughs but he wants the real deal. I really do want to learn how to do it but my dilemma is I only have about 3-4 weeks to get up to speed with it and produce or do I just out source this one????
      I have looked at Irender NXT and a myriad of others but I really dont want to fork out the money till I hear some real experiences from you guys. I guess I am looking for a renderer which is simple, easy to use cost effective and give a whole lot of bang for the buck. that can have me producing some convincing 3d rendered animations of my SKP model. ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘
      Be great to hear from some of you about your experiences and recommendations ๐Ÿ˜„ ๐Ÿ˜„ ๐Ÿ˜„
      Stan
      • FrederikF Offline
        Frederik
        For obvious reasons, I suggest that you try Kerkythea 2008 Echo... ๐Ÿ˜†
        But I'm sure others will recomment their favorite render application... ๐Ÿ˜‰
        Making an animation in KT is quite simple... ๐Ÿ˜„
        You can check out the A quick clay animation... I posted a while back... ๐Ÿ˜‰
        Please check out the Walkthrough Animation Step-by-Step tutorial available from our repository...
        Although it was written for KT2007 the basics remain identical for KT2008 Echo... ๐Ÿ˜‰
        Cheers
        Kim Frederik
          As for cost effectiveness, Kerkythea is unbeatable... ๐Ÿ˜†
            remus
            Id probably go with kerkythea or possibly podium, not sure how easy animation would be in podium though.
            Whatever you go for make sure its a fast render engine otherwise you'll spend forever waiting for it to render.
            Other general tips: only render as big as you need, no bigger. Large image sizes push up the render time exponentially.
            Do a few experiments to find the minimum frame rate you can use, rendering as few frames as possible is a good way to speed up the rendering process.
            Try not to use too many complicated materials, if youve got a displaced SSS material it will slow things down considerably, at least in the render engines i've used before. This might not be the case in KT.
            • FrederikF Offline
              Frederik
              I'd say it's the same for ALL render applications... KT included... ๐Ÿ˜‰
              Materials, lightning, render output size, render method etc. are ALL very important parameters when it comes to render an animation...!!
              Yeah... You're definitely right about that... ๐Ÿ˜†
              Cheers
              Kim Frederik
                Cost or purchase is one thing, cost of learning and cost of time spent setting it up is another.
                • FrederikF Offline
                  Frederik
                  @thomthom said:
                  ...cost of learning and cost of time spent setting it up is another.
                  Agree with you on that... ๐Ÿ˜‰
                  But setting things up in KT (materials, lightning and render method) is fairly easy and doesn't take that long... (max. 5-10 minutes, depending on the scene)
                  Cheers
                  Kim Frederik
                    If only KT did displacement... ๐Ÿ˜’
                    • SektaS Offline
                      Sekta
                      Hey, thanks guys for the responses. You know I didn't realise you could do rendered animation in KT, I should have mentioned in my first post I use KT echo for some simple occasional renders, I will definitely check out the step by steps Fredrick. Thanks.
                      Stan
                        dtrarch
                        Hi Sekta
                        SU to Kt is a very good option for path animation of the camera.
                        No object animation (maybe with Sketchy Physics) but fast and easy.
                        For object, moving people etc expect about one hour per second to produce.
                        You can import the KT files to an inexpensive Video editor and get some pretty good results.
                        I checked out Windows (XP) editor, Adobe Premier Elements, Virtual Dub (free) and a couple of others but selected Magix Movie Edit Pro 14 as it was super fast and easy to use (under $50 to buy) and very full featured.
                        (trial version is available)
                        The attached test render resolution has been reduced to fit here but
                        the higher rez version had smooth transitions and was very sharp.
                        Hope this is of some help
                        dtrMovie 2009-02-19.wmv
                        • E Offline
                          Ecuadorian
                          Real-world experience is what you asked for, real-world experience is what you get:
                          http://www.sketchucation.com/forums/scf/viewtopic.php?p=135023#p135023
                          For this particular test, Kerkythea was 9x faster than Podium. Podium took 55 minutes, and Kerky took 6 minutes.
                          How easy was it to setup in each renderer?
                          First, I created the four cameras in SketchUp.
                          Podium:
                          To be able to do the Podium test, I had to use an unofficial plug-in, called "SaphuA Plug-ins", and configure it before start. Then I had to run an additional external program called "PodiumAnimate" by the same author of the "SaphuA Plug-ins". To make things worse, the Podium output is not immediately usable in any video editor, as it is not a numbered sequence. You have to use a massive file renamer for that. And Podium's lack of internal exposure correction means for interior animations using only the sun, you'll have to do the corrections in post-processing, producing ugly posterization. And it crashed after rendering 175 frames, which means you'll have to sleep next to your PC with an eye open if you want to go this route.
                          Kerkythea:
                          Add "TG_" to any glass material before export, press the Kerkythea button in SketchUp (export took some three seconds), and in Kerky create a new Walkthrough animation using the SU cameras and hit render. Everything will be ready for the video editor after finishing.
                          How difficult was it to learn to render an animation in Kerky? I first opened KT on Wednesday 11th's morning, and by lunch I was already rendering my first animation. A few days after that I was already using it in commercial work.
                          For converting to JPG sequences to video I recommend VideoMach (about $50) and for more fancy editing Windows Movie Maker. VideoMach has some useful effects that Movie Maker lacks, as Motion Blur and white balance correction. Remember to buy the DivX pro codec (about $20) to use with VideoMach. If you need any more advice regarding Walk-through animations feel free to ask, as I've been doing it for years. (Well, my videos are not top-quality, but at least not that fugly)
                          -Miguel Lescano
                            dtrarch
                            Hi Ecuadorian
                            Yes KT wins.
                            Also I have ATL Studio and not up to speed at all.
                            I did check out VideoMach (shareware for $25 US)
                            MAGIX Movie Edit Pro 14 is a bunch more full featured and has all the exports/codecs to boot.
                            Up to 14 tracks as well (vid or sound)
                            Thx for your input too.
                            dtr
                            • SektaS Offline
                              Sekta
                              Hi Ecuadorian,
                              Thanks for the advice, very much appreciated ๐Ÿ‘ ๐Ÿ‘ Luckily I have been using KT for a while now so the next step to rendered aninmations should not be a huge one ๐Ÿ˜„ ๐Ÿ˜„
                              Stan
                              • soloS Offline
                                I'm going out on a limb here, firstly I have never used KT to an extent that Iv'e rendered anything worth posting. I have recently dabbled with NXT (the trial version) I do not know the price of this app but will say it works as expected, the animation render is faultless and fast. I was very impressed at how easy it was, on my first attempt it worked just as I hoped it would.
                                and a feature I just love is the ability to render lines.
                                Here is a .gif (so image quality sucks due to conversion), took 6 minutes to make using a quad core using almost the lowest settings possible.
                                http://img11.imageshack.us/img11/5952/testball.gif
                                • E Offline
                                  Ecuadorian
                                  The beauty of the 3D rendering world is that it's full of options. No company has yet built a monopoly over it (Well, Autodesk kinda tries to do that...).
                                  I used Art*lantis 4.5 for Walkthrough animations for years when I worked for Furoiani Building Co. (Actually, it was the local distributor of ArchiCAD and Artlantis who found me that job), and I have to say that it was the fastest renderer I've ever used. I haven't used the new version, but Coen Nanick highly recommends it, so it's worth considering. Artlantis Studio 2 (the version that does animations) + a collection of objects and shaders currently goes for $4,795. The naked version (without libraries) goes for $1,385. Yes, I remember Artlantis, ArchiCAD and the extras were big business for the local distributor... ala Gillette.
                                  Yet another option, if you want extremely quick, no-hassle, animations from SketchUp, is LightUp, which goes for around $150.
                                  -Miguel Lescano
                                    kwistenbiebel
                                    Bargain!
                                    Wuahaahaaaa. ๐Ÿ˜„
                                    For a render engine that is sub standard on photorealism that is a lot of Dinero.
                                    • FrederikF Offline
                                      Frederik
                                      @solo said:
                                      ...firstly I have never used KT to an extent that Iv'e rendered anything worth posting.
                                      ๐Ÿ˜ I have to admit that I'm slightly puzzled why a person with your talent haven't been able to get along with KT... ๐Ÿ˜•
                                      Many users have adapted KT very quickly... Are you sure you've given it a fair trial...?!? ๐Ÿ˜‰
                                      Cheers
                                      Kim Frederik
                                      • Al HartA Offline
                                        Al Hart
                                        Nice GIF. I have never seen this technique before (We work out of our bath tub and never see the real world)
                                        What is the trick for turning an animation into a GIF?
                                        How crazy can you get (size, length, etc.)?
                                        Al Hart
                                        IRender nXt from Render Plus
                                        • soloS Offline
                                          AL
                                          I use Corel animation studio to convert the .avi to .gif and I can optimise it so that it will be small enough to embed, it's an instant conversion, no waiting for a rerender.
                                          I can size it to pretty much any size, aspect ratio, I can also recentre and overlap videos too.
                                          • E Offline
                                            Ecuadorian
                                            Sekta, in a similar thread I mentioned 3dsMAX as an option if you want to have animated cars, people, etc. This is an animation I made in MAX a year ago:
                                            http://www.youtube.com/watch?v=-bLour3iMuc
                                            Youtube degraded it a lot in the conversion ๐Ÿ˜  .
                                            But of course preparing a presentation with moving objects is exhausting and time-consuming, so most of my MAX walk-throughs were almost completely static. Here are a couple of examples:
                                            http://www.youtube.com/watch?v=E6w5PxjKEpQ
                                            http://www.youtube.com/watch?v=WbhQTy0pZ4k
                                            BTW, I faked the caustics (light reflecting from water) you see in the first MAX video using projector lights. Kerky has projector lights, too, so it shouldn't be hard to emulate this effect.
                                            I feel a bit bad for having bashed Art-lantis in a previous post, so to set the record straight here are a couple of videos I made years ago with version 4.5:
                                            http://www.youtube.com/watch?v=tR3zw-G3PvM
                                            http://www.youtube.com/watch?v=Uut3l2dJPns
                                            Of course my videos are not photorealistic at all... But if I keep trying hard, I hope to some day be at least 10% as good as Neoshed or Master Kwistenbiebel.
                                            I'll soon start posting some Kerky walk-throughs... As soon as I find a nice model to render, or a client asks for one. Until then, here's my first attemp, rendered just hours after opening Kerky for the first time. SketchUp model by Pibuz, modified by Master Solo:
                                            http://www.youtube.com/watch?v=MiS3l6otTQw
                                            -Miguel Lescano
