    Leopard hang fix
    80 Posts 53 Posters 37.5k Views 53 Watching
      bjanzen
      Hi, all -
      After some discussion, and me having tested on PC and Mac, our suggestion on Mac is going to be what happens on the PC by default, and that is to turn off hw acceleration (Preferences->OpenGL). With both fast feedback and hw acceleration on PC, things are pretty ugly as well. We've been in contact with Apple on this issue (after the original driver in Leopard causing a hang). If you look at http://developer.apple.com/graphicsimaging/opengl/capabilities/ this card only supports OpenGL 1.2, which is a concern if this a machine you're trying to make your living on. I'd like to thank inio for an INCREDIBLE job of filing a fix for this, but right now I can't convince enough people that this needs immediate fixing. Sorry, and thanks for the comments.
      Barry
        Sylvan.Being
        Thanks for the fix Inio! This makes using SketchUp WAY less frustrating now. Is it recommended to leave hardware acceleration and fast feedback on with this patch and the Intel GMA X3100 integrated card?
        • I Offline
          inio
          I wasn't aware that this bug even affected the X3100.
          As for leaving those things on - that's up to you. The Google position appears to be to turn them both off, but if it's usable I don't see why you couldn't leave them on.
            thedyt
            I'm using Mac Book with 2.4 Intel processor and 2 GB of RAM.
            I just switch from using SWEET HOME 3D to GOOGLE SKETCHUP 7 FREE, and had the same problem of SU7 runs slow on MAC.
            I think everybody has tried INIO's solution and its working well.
            i tried to download the thawup installer, but it is said i am not authorized to do so.
            Could you inform me, hot to get the patch?
            thanks INIO
              Hi Thedyt and welcome,
              If you are logged in to the forums, you should be able to download it (it's a zip file). Please, advise if you cannot (or send a PM) and I'll email it to you but first of all we should make sure you can use the forum properly and there is no problem with you logging in.
              • I Offline
                inio
                Since this seems to be a recurring problem, I've put up a mirror on my own webspace and added a link below the download box.
                  lilawisl
                  ThawUp worked for my MacBook with OS 10.5.6 and SketchUp 7.0.8656. Thanks Inio
                    redinhawaii
                    SketchUp Pro 7 still crashing,
                    I am on a MacBook Pro, 2GHz, latest sketchup, OS 10.5.6
                    tried the ThawUp and still crashing.
                    I can create a crash by going into layers and hit add layer....
                    sometimes just SU crashes, some times the spinning beach ball of death..
                    any thoughts or insights.
                    next stop the Genius Bar....
                    • I Offline
                      inio
                      ThawUp doesn't resolve any crashes - just the hang after box-selecting or other interactive operations.
                      • F Offline
                        funkey6
                        Hi Inio,
                        I'm a pretty new user to Sketchup 7 using a MacBook running Leopard 10.5.6 & ur fix did the business for me as I was pretty close to giving up using SU7.... Thank you so much for keeping me sane!
                          julianotxr
                          Hi there,
                          Ater installing the patch provided, my sketchup 6 or 7 are still slow when dealing with models containing just a few a few extra layers and objects. I have not seen this happen in windows environment, even on Dell non-proffesional laptops like inspiuron 1525, that seem to use the same graphix card that my macbook does.
                          My computer info:
                          White Macbook 2.4GHz Intel (dual core, the latest model before aluminun macbook was lauched, bought on september 2008)
                          160GB HDD (55GB free)
                          4G RAM
                          Mac Os 10.5.6
                          Intel Graphics card GMA X3100
                          I have tried to use either Skecthup Pro 6 or 7 (I have both), but it seems not to work.
                          am I condemned to spend more than 2000 bucks on a Macbook Pro or imac? Xan someone please help? I am an architect and have switched to macintosh recently. I got used to it very easily, but the bad performance for autocad 3d and sketchup have brought me many problems with my work.
                          Any help will be muchly appreciated.
                          Thanks in advance,
                          Juliano
                          • I Offline
                            inio
                            This patch only improves the performance of certain interactive operations, like box-selecting. If these operations are not dramatically slow (making SketchUp hang or freeze for half a second or more) while others (like orbiting) are fast, this patch won't help you.
                            • broomstickB Offline
                              broomstick
                              Hello all,
                              I am about to buy a month old imac 24 2.8, but I am concerned with this slowness. I had the opportunity to try the pc, and install SKP (version 6) on it to feel how it went. It was all ok, apart from a certain slowness in orbiting. Well it wasn't really slow... the orbit movement wasn't exactly fluid, it came in steps, not in a unique animation.
                              I don't know what version of Leopard was on that machine (i forgot to ask, but I assume it is the latest), and I am wondering if this package will solve my problems or not.
                              Thank you for any answer on this!
                              • I Offline
                                inio
                                @broomstick said:
                                Hello all,
                                As I said in the last post - this patch won't help general slowness. Just specific, unreasonable hangs AFTER particular actions (not during). In your case, it sounds like it was maybe using the software renderer instead of OpenGL.
                                  broomstick
                                  that's strange, I had just installed the software on the computer :S
                                  oh well, I'll ask to take a further look!
                                  • EdsonE Offline
                                    Edson
                                    i must say the hang problem is not restricted to the card mentioned by barry a couple of posts before. my macbook pro has a geforce8600 and i have the same problem with the latest SU7 build (10035). i will revert to the original build (8656) to see if the patch will work.
                                    http://www.mahfuz.arq.br
                                    • EdsonE Offline
                                      Edson
                                      @inio said:
                                      Short answer: If you have Intel GMA950 graphics (early MacBooks and all Mac Minis?) and SketchUp is locking up after you box-select or just randomly after you try to select objects, this download my resolve the issue. The latest versions of MacOS and SketchUp that this patch has been confirmed useful with are 10.5.6 and 7.0.8656.
                                      does it work for the latest build (10035)? is it restricted to Intel GMA950 graphics? it seems that the same problem afflicts other macs running 10.5.6 as well.
                                      • I Offline
                                        inio
                                        There should't be anything build-specific about the patch. It just causes a certain OpenGL call (glClear) to make an extra call (CGLFlushDrawable) when it's called after drawing to the front buffer. As long as SketchUp follows the same call pattern, it should continue working.
                                        It's possible that this bug exists in other drivers. I'll test on a current-gen MacBook tonight if I remember. Other than that I don't have any other Intel macs available.
                                        • EdsonE Offline
                                          Edson
                                          thanks. for what it is worth, i own an intel macbook pro 2.4ghz and its graphic card is the geforce 8600M GT.
                                            bjanzen
                                            1. Make sure you're not affected by http://support.apple.com/kb/TS2377.
                                            2. We also look at http://developer.apple.com/graphicsimaging/opengl/capabilities/ but you should be OK with that list.
                                            3. Send me the model, steps to test, and time, and I'll write an automation script to repeat it and time it with multiple tries.
                                            4. Look at Mitchel's 3D Basecamp presentation on working with large models: http://www.youtube.com/watch?v=hnhkei2dSrY if it's not hardware related.
                                            Hope that helps.
                                            b
                                            • 3 / 4
