    Import a 3DS file with textures?
    16 Posts 8 Posters 6.0k Views 8 Watching
    • G
      Gradius
      Hello everyone, I'm new here so sorry if I'm posting in the wrong place or anything.. Basically I need some help, I'm trying to import a 3DS file into sketchup, and it works fine except it doesn't seem to import the textures? I have read that you must save the texture file in the same folder as the 3DS file in order for Sketchup to import with the textures intact, so I have done this, however it still just imports my 3DS model in blank grey, no textures? 😞
      Any suggestions would be greatly appreciated, thanks.
      • L
        linea
        Yes unfortunately it can't be done. If you go sketchup up to 3DS though, textures are preserved.
        • G
          Gradius
          Ah, Thanks very much for the reply, I'm confused though, because it states in the sketchup help centre that it can be done just by saving the texture in the same folder as the 3DS, Link below.
          http://sketchup.google.com/support/bin/answer.py?hl=en&answer=36217
          So is their help page totally incorrect? I would be really pretty upset if so, I purchased Sketchup with the understanding that this would work, I suppose I should have tried it first 😢
          • X
            xrok1
            i'm pretty sure you're mistaken. i'm 99% sure i've done it before in fact here, try for yourself.
            unzip the file to your desktop or anywhere then import to sketchup, works here with textures.
            alleycat.zip
            • GaieusG
              @gradius said:
              I have read that you must save the texture file in the same folder as the 3DS file in order for Sketchup to import with the textures intact...
              AFAIK 3ds file format does not contain the material files (like skp) so you need to "link" them and keep them together with the 3ds file. But in order to do so (I mean to keep the material files "in the same folder"), you also need to apply them to the 3ds model from the same folder so that the linkage won't be broken. Otherwise you will need to keep the exact folder path relative from the 3ds file to the material files.
              • L
                linea
                I never knew that, sorry for the misinformation. You learn something new everyday 😄
                • G
                  Gradius
                  Thanks for all the help guys, I'll give it a try 😄
                  Edit - Well the allycat zip worked fine, I still cant seem to get my own model to work though..I'm not quite sure how to link the texture with the model, they both have the same name but that's all I can think of.
                  • GaieusG
                    Nono, Jon, That's only my "gueswork".
                    There are a couple of formats (mainly the ones that are actually some kind of text files) that work the same way; all xml formats (collada for instance) therefore they are generally packed with the texture images safely together (like if you open a GE kmz file, you can see all the images insie).
                    • soloS
                      Importing foriegn meshes with UV mapped textures is totally possible, and there are numerous methods of doing it.
                      I personally like .3ds format the best at moment.
                      The trick is being organised and having a good folder structure so that you keep your mesh and your texture images together a well as making sure your model units for both the exported model and SU match (commonly overlooked)
                      A trick that Silvershadow showed me that works is if you import a model and the texture is not attached, look at the 'errors' message in the import dialogue, it will ask for the texture and normally the problem is the naming of the texture, make a note of the name SU is looking bfor then rename the imported texture accordingly and do the import again, this time the texture will be mapped.
                      I use an expensive tool called Deep exploration to import into SU, so I pretty much bake my textures to the mesh and do a straight 3ds to skp coversion which makes life very simple, but at $2500.00, the above method is definately the cheapest way around.
                      • GaieusG
                        Also note that (AFAIK) 3ds being an "archaic" file format, you need to name your textures according to old conventions i.e. a 8+3 digit way (the name being max. 8 characters - no spaces and any special characters allowed - and the extension 3 digits, something like texture1.jpg 👍
                        but never texture 1.jpeg 👎 or Café.jpg 👎 )
                        • L
                          linea
                          I found a basic freeware app the other day that can be used for texture baking. I'm not really sure how much use it is yet.
                          404 Not Found
                          (www.frecle.net)
                          • X
                            xrok1
                            404 Not Found
                            (www.frecle.net)
                            looks cool but how could you get a sketcup file into it?
                            • X
                              xrok1
                              ok' sorry i see the 3ds import/export specs 😳
                              • halroachH
                                halroach
                                Hi Solo,
                                How would you convert a 3DS or MAX file into an SKP using Deep Exploration? How do you make sure the texture mapping doesn't jumble up? What temperature to do you turn the oven on when you "bake" it? 😉
                                FlexTools - Super Quick Windows, Doors, Slats...
                                • O
                                  okee
                                  Is this only in SU Pro, I can't see any errors when importing a 3ds file
                                  Is there any 3rd party program that can read a 3ds file and show the names
                                  of the Textures associated with the model ?
                                  I presume they're embedded in the 3ds file
                                  • brodieB
                                    brodie
                                    As has been mentioned 3ds files can come into SU just fine with textures. If you have a 3ds model and no control over it I don't know what to say. If you have a model in 3ds Max the trick is to change the materials from Vray or some other specialized format to Standard. Then they come into SU perfectly.
                                    -Brodie
