    [plugins]SP3 alpha2. Win & Mac
    34 Posts 14 Posters 10.0k Views 14 Watching
    • X
      xrok1
      did anyone notice that shift double click things stay even after sim is reset. is this normal? i don't think it was this way in SP2 was it?
      • C
        CPhillips
        Yeah, SP3 behaves a bit differently from SP2. After you ran a simulation in SP2 it would "undo" SP3 doesnt do that. It leaves the simulation on the undo stack but doesnt undo it automatically.
        That means anything created stays. I'll have to fix that in a future release.
        One reason I changed it was so you could edit controllers while the simulation is running.
        • P
          Platypus5
          can we upload on this version?
          • P
            Platypus5
            I found a glitch
            You can no longer type formulas into the controller for a motor
            • C
              CPhillips
              @platypus5 said:
              I found a glitch
              Can anyone confirm this? It seems to work fine for me.
              • P
                Platypus5
                @cphillips said:
                @platypus5 said:
                I found a glitch
                mabye I wasn't doing it right. Oh well.
                Another question: In sketchyphysics2, we could increase the mass of an object by grouping it with a bigger version of itself, setting the bigger copy to "ignore" and then hiding it. Now, SP3 sometimes fails to register this hidden mass. I noticed this when I tried to steer a tank using a flywheel; while the bullets (which have this "hidden mass" technique in them) are the same, the cylander in the flywheel group (motor and the cylander) which is set to ignore, spins but doesn't turn the vehicle. What is this inconsistancy? and finally, did what i said make any sense?
                • C
                  CPhillips
                  I think I understand but I don't know why. As far as I know that stuff should work the same. Post the model and I will take a look.
                  • MALAISEM
                    MALAISE
                    Hi Cphillips
                    Does still exist a manual even short ?
                    I try to make copies from simple models ( 2 box linked with a motor-joint ) but it seems not to be available. Is there a trick ?
                    Thanks a lot
                    MALAISE
                    • W
                      Wacov
                      MALAISE, until SPIV is out copying anything with joints in, or that is connected to a joint, is a bad idea. The simulation will go crazy, and there is no workaround.
                      • MALAISEM
                        MALAISE
                        Hi Cphillips
                        Thanks for that early answer. I'm really fond of this program. ☀
                        Cheers
                        MALAISE
                        • ton baetenT
                          ton baeten
                          Thank you very, very much for making your great utility available for Mac too.
                          Time to get started to learn and use, but........
                          I seem to have a problem, I get an error message restarting SU after download and installation:
                          Error Loading File SketchyPhysics.rb
                          Failed to load /Library/Application Support/Google SketchUp 7/SketchUp/plugins/SketchyPhysics3/dl.bundle
                          SketchyPhysics shows in SU, aswell in the Tool Pallettes, as in the plugins and the icons are available/visible.
                          Any ideas to solve this problem?
                          greetings,
                          Ton
                          • X
                            xrok1
                            any thoughts on adding some type of joint strength? for example a table (legs attached with joints)when dropped from 10' for example, would cause the joints to break thus allowing the legs to go their seperate ways. 😄
                            • P
                              Platypus5
                              Sorry I did not get back to you earlier. Here is a good example of what I am talking about. The flywheel that is on "ignore" will not influence the cube it is attacthed too. It should because of the mass, but it doesn't. However, the flywheel that is NOT ignored has a significant effect on its cube.
                              a glitch I found
                              • W
                                willeykj
                                Have you checked the directory mentioned to see if dl.bundle is there?
                                Make sure you installed the SP files and directory into the system library and not your personal library.
                                So it should be in /Library not in /Users/YOU/Library
                                And by the way, this will only work on INTEL macs - not on PowerPC systems... sorry for not mentioning that in the install file
                                • ton baetenT
                                  ton baeten
                                  Kevin,
                                  Everything is at the right place, but.........
                                  I will have to wait till my new 17" powerbook (intel-based) arrives.
                                  Thanks for your info,
                                  greetings,
                                  Ton
                                  • C
                                    CPhillips
                                    Breakable joints will be in SPIV.
                                      Sgal
                                      I found a new way to make a truster in SP:
                                      1. truster option (in UI)
                                      2. a magnet linked with a magnetic object
                                        and the new solution:
                                      3. a gear link between a motor and a slider. Motor is linked to a static object, slider is free.
                                        The model shows the three options together.
                                      homemade truster alfa.skp
                                        shareck
                                        I'm just wondering why are the SP joints stretching. Can you get rid of that? Or maybe could this be set for each joint separately? This stretching is sometimes helpfull but when you try to do things like chain links or tank tracks it's very annoying.
                                        • I
                                          ianbruce
                                          Outstanding! Can't wait to get started. Thanks Again.
                                          • I
                                            ianbruce
                                            Everything working amazing well... except I can't seem to rename controllers in the Mac version. I type a new name in the Inspector, but it doesn't seem to take. When I run the simulation, no sliders appear for motors or servos I attempted to rename.
                                            Is this a known bug?
                                            *** SEMI-WORKAROUND***
                                            I just created a new motor and used "slider('NEW NAME')" in the Controller field. That took... but it seems to only work once. I can't rename another motor, or (obviously) use the same name to run 2 motors off one slider.
