    [Plugin] Camera OrbitOnTarget v1
    27 Posts 15 Posters 23.4k Views 15 Watching
    • EdsonE Offline
      Edson
      i tried it on my macbook and it did not work. the tool bar is there and after i clicked twice on an object a dot appeared on it but other than that nothing happened.
      edson mahfuz, architect| porto alegre โ€ข brasil
      http://www.mahfuz.arq.br
        MarcioAB
        Humm ... I do not have a Mac to check but, just to see if the sequence is the expected one:
        1. Select the tool (on the bottom text bar there should appear short instructions). This is just to see if the tool was correctly loaded.
          You will also see the Inference-point around. Just move the mouse to see if the Inference-point move around the elements.
        2. Then double-click. The screen must re-center. (try a point that in not too close the center, but even with a minimal distance it's easy to see something happened with the screen)
        Could you double-check that please ?
        Also, there is a variation of this plugin for change the position of Components (in draft).
        http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=14193#p107373
        Abracos
        Marcio
        • EdsonE Offline
          Edson
          no inference point to be seen. could you post a picture of what it looks like in windows?
          1. Then double-click. The screen must re-center. (try a point that in not too close the center, but even with a minimal distance it's easy to see something happened with the screen)
          re-centering works but nothing else besides that. no rotate, no zoom, no pan.
            MarcioAB
            Well, this is how it works here:
            [flash=425,350:1ajsikpg]http://www.youtube.com/v/IWx026cl23s[/flash:1ajsikpg]
            But I also tried to capture the video-screen with MS Windows Media 9 Encoder and the behavior became more or less like you mention. But I do not know how to fix this.
            • X Offline
              xrok1
              so ,any further dev.
              any luck with the MMB?
              โ€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.โ€
              • X Offline
                xrok1
                hey! the MMB double click works for me. ๐Ÿ˜
                  MarcioAB
                  Humm ... my initial expectation regard the Middle Mouse Button was to replace the default tool currently associated with the MMB - that is the standard SketchUP Orbit tool - by this one. But its not possible yet.
                  So I think in this case it is pointless to connect any function to MMB if I can only use it when the OrbitOnTarget tool is activated.
                  Regard any further development: I used that code in JointSU plugin with minor changes - When you are assembling components I find useful to have "OrbitOnTarget" with the target automatically set on the origin of the component axis you are working on. So, I think the idea now is to embed this "OrbitOnTarget" code into more specific plugins.
                  What else could be improved in a tool like this ?
                  Regards
                  Marcio
                  • X Offline
                    xrok1
                    oops i guess you made me find an SK feature thats already in place. if i MMB double click SK centers on that point (i didn't know that before now ๐Ÿ˜„ )and since SK orbit the center of the screen anyway; please explain the purpose of your plugin?
                      MarcioAB
                      Make a simple cube. Center it (using the double-click you mention) targeting any specific point over the cube and Orbit.
                      You will find it will not always orbit around that expected point.
                      The OrbitOnTarget plugin makes it orbit on the selected point (and by the way, the selection is made using the Inference Engine).
                      Regards
                      Marcio
                        Ross Macintosh
                        Thanks Marcio for developing the plugin. I'm finding your approach to the controls very good. I have the feeling they will become very intuitive for me with a bit more use. I'm happy.
                        Regards, Ross
                          MarcioAB
                          Great. Let me know if we can improve the interface or anything else.
                          Regards
                          Marcio
                          • X Offline
                            xrok1
                            O.K, thanks for the explaination, even if i never use your script thank you for making me discover the MMB function of SK without you i would have never discovered that which is a very valuable function. ๐Ÿ˜‰
                              jprokos
                              I really wish this worked on a Mac. The Double Click feature is all that works nothing else.
                              2009 iMac
                              OS 10.6
                              SU 7.1
                              • majidM Offline
                                majid
                                Regards
                                Marcio
                                dear Marcio, would you plz add a function for exact movement of camera? i.e 35cm to right? up dn ....?
                                • F Offline
                                  fullyfledgeded
                                  hey once you've define the target, can you say for example rotate exactly 180degrees around it?
                                    smiggyuk
                                    this is a pluggin i have been looking for cant believe it was so hard to find but I am not familiar with loading PNG . i have just loaded ruby plug ins before . what do i do (learner)
                                    many thanks
                                      caddia
                                      please help not working on sketchup 2018 i need it so much.
                                        @caddia, The author hasn't visited Sketchucation in more than six years. It's likely that he's no longer supporting this plugin. Might be a good idea to look for an alternative.
                                        • jujuJ Offline
                                          juju
                                          quick off-the-cuff alternatives you might want to look into, there may be more:
                                          Camera Tools
                                          Curic Spin Camera
                                          Animate Rotation
                                          Camera Circle
                                          Camera Spiral
