    [Plugin] Camera OrbitOnTarget v1
    27 Posts 15 Posters 24.4k Views 15 Watching
    • EdsonE Offline
      Edson
      1. Select the tool (on the bottom text bar there should appear short instructions). This is just to see if the tool was correctly loaded.
        You will also see the Inference-point around. Just move the mouse to see if the Inference-point move around the elements.
      no inference point to be seen. could you post a picture of what it looks like in windows?
      1. Then double-click. The screen must re-center. (try a point that in not too close the center, but even with a minimal distance it's easy to see something happened with the screen)
      re-centering works but nothing else besides that. no rotate, no zoom, no pan.
      edson mahfuz, architect| porto alegre โ€ข brasil
      http://www.mahfuz.arq.br
        MarcioAB
        Well, this is how it works here:
        [flash=425,350:1ajsikpg]http://www.youtube.com/v/IWx026cl23s[/flash:1ajsikpg]
        But I also tried to capture the video-screen with MS Windows Media 9 Encoder and the behavior became more or less like you mention. But I do not know how to fix this.
        • X Offline
          xrok1
          so ,any further dev.
          any luck with the MMB?
          โ€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.โ€
          • X Offline
            xrok1
            hey! the MMB double click works for me. ๐Ÿ˜
              MarcioAB
              Humm ... my initial expectation regard the Middle Mouse Button was to replace the default tool currently associated with the MMB - that is the standard SketchUP Orbit tool - by this one. But its not possible yet.
              So I think in this case it is pointless to connect any function to MMB if I can only use it when the OrbitOnTarget tool is activated.
              Regard any further development: I used that code in JointSU plugin with minor changes - When you are assembling components I find useful to have "OrbitOnTarget" with the target automatically set on the origin of the component axis you are working on. So, I think the idea now is to embed this "OrbitOnTarget" code into more specific plugins.
              What else could be improved in a tool like this ?
              Regards
              Marcio
              • X Offline
                xrok1
                oops i guess you made me find an SK feature thats already in place. if i MMB double click SK centers on that point (i didn't know that before now ๐Ÿ˜„ )and since SK orbit the center of the screen anyway; please explain the purpose of your plugin?
                  MarcioAB
                  Make a simple cube. Center it (using the double-click you mention) targeting any specific point over the cube and Orbit.
                  You will find it will not always orbit around that expected point.
                  The OrbitOnTarget plugin makes it orbit on the selected point (and by the way, the selection is made using the Inference Engine).
                  Regards
                  Marcio
                    Ross Macintosh
                    Thanks Marcio for developing the plugin. I'm finding your approach to the controls very good. I have the feeling they will become very intuitive for me with a bit more use. I'm happy.
                    Regards, Ross
                      MarcioAB
                      Great. Let me know if we can improve the interface or anything else.
                      Regards
                      Marcio
                      • X Offline
                        xrok1
                        O.K, thanks for the explaination, even if i never use your script thank you for making me discover the MMB function of SK without you i would have never discovered that which is a very valuable function. ๐Ÿ˜‰
                          jprokos
                          I really wish this worked on a Mac. The Double Click feature is all that works nothing else.
                          2009 iMac
                          OS 10.6
                          SU 7.1
                          • majidM Offline
                            majid
                            Regards
                            Marcio
                            dear Marcio, would you plz add a function for exact movement of camera? i.e 35cm to right? up dn ....?
                            • F Offline
                              fullyfledgeded
                              hey once you've define the target, can you say for example rotate exactly 180degrees around it?
                                smiggyuk
                                this is a pluggin i have been looking for cant believe it was so hard to find but I am not familiar with loading PNG . i have just loaded ruby plug ins before . what do i do (learner)
                                many thanks
                                  caddia
                                  please help not working on sketchup 2018 i need it so much.
                                    @caddia, The author hasn't visited Sketchucation in more than six years. It's likely that he's no longer supporting this plugin. Might be a good idea to look for an alternative.
                                    • jujuJ Offline
                                      juju
                                      quick off-the-cuff alternatives you might want to look into, there may be more:
                                      Camera Tools
                                      Curic Spin Camera
                                      Animate Rotation
                                      Camera Circle
                                      Camera Spiral
