    πŸ«› Lightbeans Update | Metallic and Roughness auto-applied in SketchUp 2025+ Download
    Can you render a section plane?
    6 Posts 6 Posters 4.3k Views 6 Watching
      shubba81
      Does anyone know if you can render a section plane in sketchup? When I rendered my model with section plane it just rendered the model as normal from that angle.
        remus
        You cant render a normal section plane, but if you download whaats zorro2 plugin, there is an option to cut the model at the section plane. You can then render it properly.
        To get to the option you right click on the section plane.
        http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=16038&hilit=+Plugin
        • AnssiA Offline
          Anssi
          Some rendering apps, like ArtLantis, have their own sectioning tools.
          Anssi
            richcat
            IRendernXt also can render Sketchup section planes
            http://wiki.renderplus.com/index.php?title=Section_Planes
              Ph33r1es5
              wow thks
                When asking rendering questions it'd make it a lot easier to answer if you mention which render engine you use...
