    [Obsolete] FredoScale 1.0e (Free Scaling, Taper Scaling)
    140 Posts 61 Posters 44.8k Views 61 Watching
    • fredo6F Offline
      to James and other MAC Users
      Many thanks for this detailed report.
      On the menu issue, I really don't know what could be the difference between Mac and Windows. Just in case, I modified the code taking care of that (see attached file).
      on TAB, I thought the key code on Mac was 9, as in Windows. Could a ruby programmer equipped with a Mac confirm (or not) that this is what is got when getting the key in the onKeyDown and onKeyUp methods (and also to tell if we get the key on both Down and Up events).
      For the web dialogs, I need to see how I could overcome the problem (SU 7 has also a different behavior on Mac vs. SU6).
      Thanks again
      to drop in LIBFREDO6_Dir_30 folder
        James Fraser
        That's excellent Fredo, I have all the labels and the shortcuts are bound. I assume it was just splitting that line in declare_command, although I am not sure why that should affect it.
        Tab seems to highlight different tools, which can then be selected using space. It does something similar with Georeferencing sometimes. I think it is a Mac thing and it is Really Annoying, as space is the default (and most useful) binding for select. I really wish Google would choose the best aspects of the Windows and Mac versions and then make them both the same.
        But anyway, thank you for all your hard work, I am glad it is now working.
        http://www.FormFonts.com
        • fredo6F Offline
          James,
          On the menu, I am glad it's work. I assume you got back the context menu as well. Like you, I don't understand why the Ruby syntax would affect the interpretor differently on Mac and on Windows.
          On TAB, I am interested to understand more, because I usually use this key to call dialog boxes (this was already the case for JPP, RoundEdge, TOS and BezierSpline). So:
          • What does it do exactly?
          • Do you think there would be an alternate key that could be handy to use instead on Mac?
          By the way, the key F2 and F3 are assigned to toggle the live deformation and the wireframe. Do they work on Mac?
          More generally, I am interested in other potential problems that could be Mac specific.
            James Fraser
            Ok, now I am really confused.
            Things are fine in the plugins menu and the toolbars, but the context menu is still the same. Also, Tab works fine in JPP, but not in this. That does use the old version of LibTraductor (Dec 2007), although the section on keys appeared to be the same (I only looked briefly, so I might have missed something.
            F2 and F3 don't seem to do anything, although if selected from the menu (context menu when using the tool works, but not for selecting the tools at the start), it behaves as you would expect. The ASCII code for Tab does seem to be 9, but, interestingly, for F2 and F3 it is 120 and 99, which is the same as for x and c. The hex keyboard codes are 78 and 63 (rather than 7 and 8 for x and c). I don't know if this is the same on the PC or how things work in the rubies, but hopefully that will help you a bit.
            Here is a picture of the highlight thing, on the line tool at the moment, if I press it again it will move to the rectangle tool. It does that if you Tab with other tools in normal use, so maybe JPP was grabbing the input in another way?tab_highlight.jpg
              James Fraser
              Also, About Centre is toggled by Option (Alt) on the Mac, but that is fine as it is consistent with other tools (Ctrl is used to right click, in case you really feel the need to use a single button mouse).
                Blah11
                this will help me out ALOT with this I always wanted to model it, http://tokyobuy.com/images/kampfer.jpg
                • fredo6F Offline
                  to James and Mac users
                  The 2 attached files should solve the problems of context menu and of TAB (now trapped on Key up).
                  to drop in FREESCALE_Dir_10
                  • COSEDIMARCOC Offline
                    COSEDIMARCO
                    Thanks Fredo6 for this Plugin.
                    I've translated it in Italian.
                    Italian language file
                    [floatl:2wjeiugn]COSEDIMARCO - The Website[/floatl:2wjeiugn]
                    • fredo6F Offline
                      Marco,
                      Thanks very much for this. It will be integrated into the next sub-release.
                      As you noticed probably, there are remaining strings in English when using FreeScale. They actually belong to LibFredo6, which can also be translated itself into Italian, if you have time.
                      Again, many thanks
                        COSEDIMARCO
                        Done
                        Italian language file for LibFredo6
                          crvela
                          thank you
                            bellwells
                            WOW, another amazing script!! You coding guys are too much. Thank you, thank you.
                            Ron
                              James Fraser
                              That appears to be it, Fredo, everything is working.
                              Hopefully that will mean things will be fine on the Mac in the future, but I will look forward to testing whatever you come up with next πŸ˜„
                                gshowells
                                I have looked everywhere to get the download of this Plugin but haven't been successful. Is there something I'm doing wrong?
                                Graham
                                • Chris FullmerC Offline
                                  The link is at the bottom of the first post. Its a zip file. Hope that helps,
                                  • fredo6F Offline
                                    To all Users
                                    Version 1.0e: Update 10 Feb 09, fixing a big bug in Scale To Target and introducing the Italian translation (kindly provided by Marco Cosedi). Please re-install when you can.
                                    Attachment in first message of this thread at http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=16021&st=0&sk=t&sd=a#p124685
                                    Please signal problems you may have with FreeScale
                                    Thanks to all
                                    • N Offline
                                      numerobis
                                      fredo i have to thank you again for this fantastic plugin!!!
                                      it's really very helpful every day. 😎
                                        Hi, is it a known bug that copies of groups ALL get changed when scaling? Try this:
                                        Make a square. Then turn it into a group. Then copy that group a few times. Then just scale on of those. And they all get scaled. Perhaps its already been brought up, but I didnt find anything when I searched for "group" in this thread. Thanks,
                                        EDIT: More specifically, I think it only occurs with the 2 tapering tools.
                                          hm.. sounds like it modifies the definition of the groups instead of the instances...
                                          • fredo6F Offline
                                            It seems that SU tries to optimize the size of file, and it uses the same entities for Groups, until they are edited. When you copy a group, you can check that in the Entity window, it does tell you that there are several instances. BUT, you don't have the "Make Unique" feature. The workaround I found to make a group unique is simply to open it and close it.
                                            From the Ruby standpoint, there seems to be no way to detect that a group exists in multiple instances.
                                            In SU6, I use make_uniquemethod on Groups in a rather blind way.
                                            In SU7, you get a warning message telling you this method is deprecated, so I thought SU7 would automatically make a group unique as soon as you apply some transformation to its entities. It does not seem to be the case.
                                            Anyway, the bug is easy to fix. It will go to the next version. But I can't remove this bloody Warning messge from the Ruby console!
                                            If anyone knows how to check a Group is in one or several copies in the model, thanks to advise
                                            • 7 / 7
