    โš ๏ธ Important | Libfredo 15.8b introduces important bugfixes for Fredo's Extensions Update
    Dynamic Component of a bi-fold door
    Scheduled Pinned Locked Moved Dynamic Components
    15 Posts 7 Posters 7.2k Views 7 Watching
      lmcad
      I am trying to construct a bi-fold door will open 90 degrees and with the connecting door panel also rotating 90 degrees so that it will fold flat. Any help on how to do this will be greatly appreciated.
        remus
        have a look at the attached example. It is essentially all driven by the attribute dorrot, which is animated between 0 and 90. this provides the rotation for each of the components, and the distance along the red axis is provided by the 100*cos(doorrot), 100 being the length of the door.
        sliding door DC example.skp
          lmcad
          Remus,
          Thank you so much. This is what I was trying to do.
          Lou Muller
          LMCAD.COM
            remus
            Glad i could help ๐Ÿ˜„
              AVguy
              Hi Remus,
              I'm hoping you can help me as this DC stuff is causing my brain to overload. I want to create a folding wall similar to your sliding door DC but with about 10 sections. I've had a play around with your example about but I just can't get the 3rd (or 4th etc) section of door to fold properly.
              Could you please point me in the right direction.
              Huw
                mpomeroy
                AVguy,
                I am just learning dynamic components, so thought i would take a stab at it. It was good practice for me. Took me a while but i got it.
                Mike Pomeroy
                  AVguy
                  Hi Mike,
                  Thanks for the reply. It was busting my head trying to work out the cos and tan. I had a brain wave over the weekend though and managed to do it with nested components. This also had the advantage of scaleability. Some weirdness with scale going on when setting up the individual components but a whole lot easier to setup and understand IMHO.
                  Cheers
                  Huw
                    AVguy
                    Next step is to work out a way of making it add doors automaticlly as the length of the opening changes.
                      amo
                      Sorry to bring this back from a long slumber....but is there a way that the rotational axis is different for the two bi-fold panels. I am trying to make it work as a true bi-fold door. So the panel attached to the door frame is rotating on one corner lets call it "A" and the other panel is rotating at the opposite and flipped corner "B". See attached image. I have been trying to reuse the original model attached to the thread, but have had no luck getting it to rotate properly. I need it to have the same rotating parameters as the original does; i.e. opening 90, closing at 0.
                        AVguy
                        Hi Amo,
                        I found that you need to change the origin of the 2nd door component so that it rotates around the correct corner.
                        Hope that makes sense.
                          amo
                          AVguy could you show me how you got it to work. Every time I try to change the axis and have it rotate it either separates when it rotates or it overlaps when it rotates.
                          bifold.skp
                            AVguy
                            Hi Amo,
                            have a look at the attached file. What I've done is nest components within components within components. It's a bit messy in that you end up with a whole lot of similar components but it seems to work really well. The end result is scale-able and rotate-able.
                            Note the way the orgin of each nested component moves and the rotation instead of being 90 deg is x 2 to make it 180 deg (effectively facing it the opposite direction)
                            Hope helps
                            bi-fold doors.skp
                              amo
                              Thanks, that is exactly what I needed for a bifold. That is a very tricky thing to come up with. I don't think I would of thought of doing it that way.
                                sarkarshomit
                                Hi...sorry to wake up this age old topic...but can someone guide me in how to prepare a multi sliding folding door...i am able to do for a single component...but the moment it becomes more than one..it becomes complicated...I downloaded the skp examples done and submitted in this thread, but could not make head or tail of the formulae applied.
                                Kindly help..if possible a video tutorial on youtube...I know i may be asking too much...but there is no tut any where!!...
                                Regards,
                                Shomit
                                  pcmoor
                                  Start simple, create a rectangle, make it a component, "door" later you can replace it with any other component
                                  copy the door to make number required
                                  make all a component, then enter the component, make next set of doors a component but change the axis so that it is opposite to the parent
                                  do so until you reach last door, then in this case check to see if opposite if not then right click the axis when inside this door component and change
                                  build formulas as shown
                                  rotate about Z, opposite and reversed (90 x 2 = 180) x -1
                                  I used the generic parent as the reference rather than component1 as suggested by Dave and others, etc, so easy to copy through.
                                  the rest are always opposite to component 2, so -parent!rotz works
                                  always check as you build, so see that it works...
                                  Then you can modify the door component. however its important you stay within the initial dimensions of the door boundary box. To increase its size, use scale tool on the whole (component1)
                                  So add the size changes to component 1, the children will follow, its not wise to have the children tell the parents what to do. Unless its necessary.
                                  keep it simple
                                  ![make a "door" component and copy 3 times](/uploads/imported_attachments/lcN7_Capture2.JPG "make a "door" component and copy 3 times")
                                  make the four doors in to component#1
                                  enter the this component and make the next 3 into component#2, change axis to other side
                                  and then enter component#2, make component#3 of the last two doors
                                  enter the final door component and check axis position
                                  ![we are considering rotation about Z, direct reference to"RotZ" as using negative](/uploads/imported_attachments/eQ9T_Capture7.JPG "we are considering rotation about Z, direct reference to"RotZ" as using negative")
                                  ![the second set needs to swing opposite first set, so "-" and 180degs =2x90](/uploads/imported_attachments/Rirq_Capture8.JPG "the second set needs to swing opposite first set, so "-" and 180degs =2x90")
                                  from then on opposites... use the outliner as a way of selecting the embeded components
                                  make sure you  have the final door
                                  now you can pushpull the door height
                                  add a bit of detail but (color) keep within the lines, or within the boundary of the door
