    POST YOUR RENDERS NR.2: WAREHOUSE
    130 Posts 45 Posters 34.9k Views 45 Watching
      AndriyG81
      quick vue sunset
      http://andriyg.com
      • N Offline
        NeonGolden
        Had to do one more...(rendertime 13min)
        click to enlarge
        • EarthMoverE Offline
          EarthMover
          Here's one I did in Hypershot. Render time was 15 minutes with some post work in Photoshop. Dump truck by Jon from 3DW - http://sketchup.google.com/3dwarehouse/details?mid=40597e0ca3a8eca9a1cba95c26616410&ct=mdrm&prevstart=0
          Content Creator at Skapeup
            tomsdesk
            Beautiful work, Guys! After trying to fake a grainy PR I see just how lovely the textures really look in yours...gonna havta learn me one a those render programs.
            2.5D Trees & Shrubs!
            • O Offline
              oalexis
              Heres my go with IDX renditioner free edition. A little diffuse glow added in photoshop after
                rangerrick
                Kerkythea render preset 19 MLT/31 passes @ 3 hours. Post process, tone mapping, color balance, some diffuse glow.
                Thanks for the challenge kwistenbiebel. A beautifully done model to work with.
                Kerkythea MLT
                • soloS Offline
                  Threads like these are a great way to evaluate the different render engines using a standard model, obviously the render engine is only a part of a great render, the users skill with it is what makes a good renderer a great one.
                  I used IDX Renditioner for this one.
                  http://img502.imageshack.us/img502/8808/whousehh2.jpg
                  • V Offline
                    VOSKO
                    Heres my attempt at it... Done with Kerkythea 😃
                    • daleD Offline
                      dale
                      Kerkythea, 4 spotlight, global sky, exposure 2, otherwise defaults, 4:13 A.M
                      • W Offline
                        wmanning
                        This looked too fun to pass up. Just to be different, I'll go vertical... with IDX Renditioner. Hazy lighting condition setting and a background image, no post.
                        William
                          EarthMover
                          Gave it a go with Vray for Max. I rendered with just Vray sun and HDRI for lighting. I also rendered an Ambient Occlusion output using this free plugin for Max - http://plugins.angstraum.at/vrayao/ In photoshop I then combined the AO with the raw rendered and set the AO to multiply. I used the alpha output to add a background behind the glass. In photoshop I did additional tweaking and exposure corrections including a high pass filter and slight bit of sharpening.
                          Vray render - 8min 33sec
                          AO render 47 seconds
                          Post processing - 10 minutes
                          Raw Render
                          Ambient Occlusion Render
                          Final after post processing
                          B&W for fun
                            richcat
                            Night shift
                            10mins
                            A bit more burn
                            • soloS Offline
                              Richcat, what render engine did you use?
                              Looks like a First person shooter scene, put a gun barrel in foreground and it's Doom.
                              • soloS Offline
                                Vue 7, with volumetric lighting, the dust in sunlight is rendered using a noise filter in volumetric sunlight.
                                http://img90.imageshack.us/img90/9499/whvueub1.jpg
                                Sketchy
                                http://img144.imageshack.us/img144/9397/whpqi2.jpg
                                  richcat
                                  IRender nXt
                                  one tries and learns and tries again[floatl:1z3vonmv][/floatl:1z3vonmv]
                                  7 mins
                                    richcat
                                    This is addictive - done with IRender nXt4 seconds just to see what I got5 mins
                                    7 mins
                                      EarthMover
                                      Nice Pete! Had a go with Vue 7 myself. Car is from Vue's object library. I used radiosity with the render settings on final. The background is an infinite procedural terrain.
                                      • boofredlayB Offline
                                        boofredlay
                                        I had a quick go with Podium.
                                        Under 3 min.
                                          kwistenbiebel
                                          @Earthmover,
                                          The Ambient Occlusion render pass overlay is a common and very effective way to add randomness and crispyness to a render.
                                          I am dying to have this for Vray for sketchup as well for a long time now.
                                          It wouldn't be to hard for a Ruby master to code a AO renderer i guess.
                                          I know AdamB is using AO as an option is his LightUp.
                                          It would be cool to have a standalone AO render plug though.
                                            EarthMover
                                            Yes, the nice thing about the AO plugin that I use for Max is that it is just a one click solution. It will render out the AO pass without disturbing any of your Vray settings. As soon as you close the plugin, your right back where you left off. If someone could imitate this plugin for Vray for Sketchup that would be great.
                                            On another note Kwist, have you picked out the next model for rendering yet? 😄 Seems as though this is turning into a fun and exciting way to practice rendering scenes you wouldn't necessarily have a chance to render in your daily work. I would be up for a nice exterior project next.
                                            • 2 / 7
