    [Obsolete] FredoScale 1.0e (Free Scaling, Taper Scaling)
    140 Posts 61 Posters 52.7k Views 61 Watching
    • JClementsJ
      JClements
      Fredo:
      Thank you!
      How many times have I been frustrated with scaling. Your script should now reduce a lot of that frustration.
      You foresight/anticipation of what many of us experience and wish could be remedied is remarkable.
      Regards, John
        johnsenior1973
        I had no commercial intention however, especially for a plugin that actually should be part of SU in standard.
        Typo fixed.
        • fredo6F
          @l.frisken said:
          The only problem I can find is that it is much slower (causes my computer to lag) when scaling big geometry
          Yes, the algorithm to compute the best fitting box, even in 2D, depends on the number of entities in the selection. However, once done at startup of the tool, it should be faster to change the orientation and to perform the scaling, even interactively. So, unless you need to have a specific orientation, you should use the native Scale tool for big selections.
          Taper Scale can also be slow to perform deformation for big selections. I think that in practice however, you would rarely taper a complex model, because the transformation is usually not ideal in the "real world".
          fredo
          • fredo6F
            Fred,
            I think I have found an answer to why this is not working: http://www.sketchucation.com/forums/scf/viewtopic.php?p=61288#p61288 from this topic.
            I don't know if recompiling those .rb files (if I say that correctly) is going to make them work, but in any case it would be nice if you could release separate Linux versions of your scripts. More and more people are switching to Linux these days. I for one am not going back to Windows. But I would still like to have this script working.
            Coen,
            I was not aware of this problem of character encoding on Linux.
            The best would be that Linux users get this dostounixutility and perfrom the transformation on their machine, so that everything is under control.
            Did you try, and does it solve the problem ?
            • B
              Ben Ritter
              Fredo,
              I just want to let you know how much I appreciate your efforts, and, your incredible generosity in making this script available.
              Ben
              • C
                craigbic
                Fredo,
                Absolutely awesome! Thank you so much for giving us some much need functionality in Sketchup. Brilliant!
                Checkout the Sketchup Graphics Blog at http://sketchupgraphics.com
                  snowflake
                  Fredo6
                  This is an amazing tool. Indispensable.
                  The work you have put into it is really appreciated.
                  Thank you.
                  I played around with it today and have a small comment.
                  There is an interesting behaviour modification of the component/group elements when the scale is applied ON them, but not WITHIN them.
                  The angle between the axis changes to non perpendicular. (see screenshots).
                  On both occasions the scale tool was used parallel to the wall of the box.
                  Was not aware this is possible.
                  Once again thank you for the toy.
                  • fredo6F
                    Interesting.
                    Actually, the Ruby API is very poor to tell what are the local axes of a component from within a component, so that I have to trust the chaining of transformations for obtaining teh right results in case of nested groups and components.
                    I hope that the cases where the local axes are no longer orthogonal does not mess up anything in the model.
                    • T
                      tomot
                      Fredo6: thanks for this great scale plugin adaptation
                      my plugins
                      tomot
                      • fredo6F
                        to ALL users,
                        I made a small update (dated 28 Jan 09, 23:30 CET) to include some fixes of problems that were reported so far and also to include the Spanish translation (kindly provided by Pichuneke).
                        You need to re-install both LibFredo6 and FreeScale
                        • LibFredo6 3.0a --> http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=16020#p124684
                        • FreeScale 1.0a --> http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=16021#p124685
                          Daniel S
                          Hi Fredo, I update to this new version.
                          The first thing I try is a problem that I have in the previous version, but the problem is still there.
                          I have some issues trying to scale about center (after press CTRL key).
                          I attach a video showing what happens. Is like the center of the group is updated when you try to scale.
                          Daniel S
                          Scale about venter problem video .wmv
                          • JClementsJ
                            JClements
                            Fredo:
                            Is there anyway for you to add a "Check for Update" function in LibFredo6 ?
                            It could check for an internal date or variable in the User's version of LibFredo6 and compare it to one on a server OR simply have it display a message which shows the most recent rev level with a link to a download page.
                            I can see where LibFredo6 might be the "heart" of many important scripts and we'll (your loyal users) want to make sure its always kepT current.
                            John
                            • fredo6F
                              Daniel,
                              That's a bug, and actually quite subtle to fix. Thanks for signaling.
                              Since you seem to know how to reproduce it, would you mind to try with the attached updated file.
                              Again, many thanks
                              to drop in subfolder FREESCALE_Dir_10
                                Daniel S
                                Yes, now works very well! thank you!. For me was easy to reproduce because it happened every time I tried to scale about center.
                                Another problem that I have is when trying to scale Red, Green, Blue (all togheter) with a negative number.
                                I attach a video showing this.
                                In the video you will see that if I try to scale only red axis negative, only green negative or only blue negative all works well... but if I take a red blue and green grip to a negative number it turns crazy. The same happens if I press the ctrl key. It works well if I scale one axis only.
                                Daniel S
                                video of the problem .wmv
                                  Jim57
                                  Fred06— I can't thank you enough for this script. I've been begging for something like this, and it's so easy to use. I love the way it reads out in percentage and dimension, right on the screen where it's most visible. It's how the SU scale tool should have been done in the first place.
                                  Jim
                                    jmmad
                                    Thxs a lot Fred for this plugin, your ruby scripts are amazing.
                                    Do you think you could add more transformations to it, like bend, twist, Bulge
                                    Maibe for a comercial plugin?
                                    Deform
                                    Get Upa !
                                    • fredo6F
                                      [attachment=0:gebfklnj]<!-- ia0 -->Transforms.jpg<!-- ia0 -->[/attachment:gebfklnj]
                                      I can add shear and twist without too much problem. But the royal way to all these deformations is definitely Sketchy FFD.
                                      • K
                                        kwistenbiebel
                                        [attachment=0:3oyx96kl]<!-- ia0 -->Transforms.jpg<!-- ia0 -->[/attachment:3oyx96kl]
                                        Please add it Fredo. 👍
                                        I find your plugin to run more smoothly and controllable than FFD.
                                        Shear and twist would be wonderful as a tool.
                                        By the way, since I installed your plugin,I never use the default SU scaling tool anymore.
                                        The plugin is fantastic and works very intuitive.
                                        Thank you again.
                                        • soloS
                                          +1 for sheer and twist.
                                            jmmad
                                            I Know FFD is very powerful for deformation tool, but its not as fast and easy to use as your Taper Deformation Script.
                                            with FFD it is very hard to do an accurate bend or twist, also you canot deform Nested Components or Grups, and you canot align the deformation as easy as you can do it with Taper deformation in your ruby.
                                            Get Upa !
                                            • 4 / 7
