    What's your beginners tip?
    305 Posts 169 Posters 340.0k Views 169 Watching
      Exactly. This is what Jean (Johnny) Lemire also suggests at his 3D BaseCamp session in the "Tips & Tricks" panel (last presenter in this video).
        Jim
        Do NOT assign shortcuts to the numberpad keys, especially if you ever use the Numberpad to enter Measuremensts (VCB) values.
          GreenToaster
          💭 And . . . don't use X as a shortcut key or you won't be able to create linear or radial patterns.
          If you really want something you won't ever stop pursuing it.
            remus
            Similarly, dont use "/" as a shortcut either as its already used for arrays.
            • boofredlayB Offline
              boofredlay
              Not true. I have used X as my x-ray shortcut for years and have never had a problem.
                GreenToaster
                Do this and it won't work - and I guarantee it:
                Step 1
                Select a group (very important)
                Step 2
                Window -->
                Preferences -->
                Shortcuts -->
                Edit/Item/Flip Along/Group's Green -->
                Add Shortcut (insert X in field) -->
                Press the "+" button -->
                OK
                Step 3
                Copy the group -->
                Now, the "x" function does NOT work
                  Maybe Eric uses the * symbol for multiplying in arrays 😉
                    boofredlay
                    Brad you are correct. If I do that "X" will not work as a shortcut. I was simply responding to your general statement saying: "Don't use X as a shortcut..." because you can, and I do.
                    • Chris FullmerC Offline
                      I use X for explode. No problems there either. Even if I move/array a group. It will not explode the group.
                      • JoelM3DMJ Offline
                        JoelM3DM
                        Another tip ... Some things that are very important for me, and probably helpful to others:
                        -- I have trouble controlling fine movements with my mouse, so I use a WACOM TABLET. It's wonderful for SU work. The stylus is easy to use. It has buttons I can set to whatever I want. I put the tablet on my lap when I am at my desk, and I also have a left mouse that I use sometimes, especially for Rclick.
                        -- And when I go to the local coffeeshop and work, I bring my laptop. I'm obsessive about lightweight. The Wacom Tablet is too heavy and I hate touchpads. I found just the thing: a V-MOUSE. http://www.v-mouse.com/ It is a very lightweight optical mouse that you hold like a pen. I also got a teeny-tiny mouse for my left hand that I use only for its buttons.
                        || Joel Metzger 3D Modeling
                        || story-shorts.net - Animation with SU
                          remus
                          Id second that, i really like my wacom.
                          • soloS Offline
                            While on the subject of hardware that can help, I would really suggest folks trying the 'Space Explorer' or 'navigator', it's not for everyone and does take getting used to, but once you get going it can increase productivity tremendously. I use it daily and owe my ability to model as fast as I do to it.
                            http://www.cadgraphicswest.com/assets/images/SpaceExplorer_header.JPG
                              DocuMike
                              This is my first post to this group. I've found that using a wireless KB/trackball has been a great help. For PC I use an Adesso WKB 3000UB (http://www.adesso.com/products_detail.asp?productid=336). It's like a 2 handed mouse so you can quickly toggle between orbit (scroll wheel in and trackball) and pan (scroll wheel in and L mouse and trackball) when moving around the model. I see they have many more models now. Some may be better (like programmable function keys) but I find this KB to be ergonomic heaven. Anyone else using it or other input tools like this?
                                Luis Esteves
                                Hi all,
                                Before doing a big change that you are not sure of the result.....first, for security, make a copy of your work (save as). Sometimes, it's difficult to go back (even with CTRL+Z).
                                I think it's a good idea to save multiple releases of the same project, at importants steps.
                                  tesmeko
                                  Erase all the centerlines that was been used for autocad before importing.
                                  Instead of using multiple curves, try to make points so you wouln't forget drawing the arc itself in sketchup as curves inn autocad almost seem to fail connecting in one of its ends.
                                  For fast modeling try to just use the exterior wall lines, use the windowizer for the doors and windows, its easier and faster when you're in a hurry.
                                  Enjoy every bit of it modeling.
                                  Tesmeko
                                  keep sketching
                                  • E Offline
                                    Ecuadorian
                                    1. When the 'scroll wheel zoom' is not working as you wish... Press Z and zoom the good, old fashioned way.
                                    2. To zoom on the selection, Right click > Zoom extents.
                                    3. Until you get used to the 3-point perspective SketchUp uses, you might want to activate the colored crosshairs (Window > Preferences > Drawing > Display crosshairs).
                                    My 2 cents.
                                    -Miguel Lescano
                                      Twistlok45
                                      As a complete newb myself, i would have to say use the instructor function to familiarize yourself with each tool and spend some time with each one.
                                      Think of a simple project to do and see how it turns out.
                                      Use this in conjunction with asking for advice and you will be pleasantly surprised.
                                      I would like to thank Gaieus for helping me out with a simple pvc fitting tut.
                                      With that, i was able to create more complicated fittings on my own, first try!
                                      Thank you Gaieus for the help!
                                      • cmdC Offline
                                        cmd
                                        Work with all aspects of "Inference Locking" so it becomes second nature to you.
                                        http://www.youtube.com/watch?v=fFfmIgJqlIw&feature=channel_page
                                        CMD
                                        • CMD
                                          boofredlay
                                          I don't know if this was mentioned yet but:
                                          Use the Tape Measure tool and the SU Axis lines to create Guides (Construction Lines).
                                          • broomstickB Offline
                                            broomstick
                                            @edson said:
                                            the three pillars of modelling well (IMHO, of course):
                                            1. work ALWAYS on layer 0;
                                            2. GROUP whatever geometry you are creating (in case there should be more than one copy of it, make it a COMPONENT);
                                            3. place it on another LAYER whose name makes sense (essential for controlling the model's visualization).
                                            This is very true, but it can lead to a lot of problems, when you export your model to another program, to render it. It happened to me, exporting the model to 3D Studio, and I had to open every group and re-assign all the geometry.
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 15 / 16
