    [Obsolete] FredoScale 1.0e (Free Scaling, Taper Scaling)
    140 Posts 61 Posters 37.6k Views 61 Watching
    • O Offline
      otb designworks
      That's funny James, I was just logging on to describe exactly what you are talking about.
      I, too, wanted to change my shortcut, but, in the shortcut window, there are four freeform scales listed, but, if I assign S to one of them, it applies to all of them and then has no effect at all while modeling.
      The context menu, like James describes, is all blank, but each space, if clicked on, operates a different function.
      Still, I am loving this plugin! One of my most used 5, no doubt.
      Thanks Fredo!
      Cheers, Chuck
      OTB Designworks is on Youtube
        a4chitect
        one of the most beautifully integrated scripts! thanks and bravo!!!
          Matt666
          This awesome plugin must contains awesome icons...
          Icon master CadFather!!! This plum job is naturally for you! πŸ˜„
          Frenglish at its best !
          My scripts
          • McGyverM Offline
            McGyver
            Thank you, this ruby looks very interesting... I will try it as soon I possible!!
            [Visit My ShareCG Freebie Gallery](http://www.ShareCG.com/pf/full_uploads.php?pf_user_name)
            • fredo6F Offline
              @james fraser said:
              Second: how it works on the Mac. I didn't see many people writing about this, so I thought I would let you know. The good news is that generally works fine, the only problem is a couple of UI things. The web dialogs do display, but it fills the bottom half of the window with nothing (presumably stretching the little blankspace border you normally get around things), but you can get around this by resizing the window until you see everything.
              The slightly bigger problem for me is labels. The mouseover description works fine, but the labels under icons are blank (when I turned them on), in the menu there are four blank lines, which work for selecting the tools, but have no names and I do not get anything in the flyout from the context menu (I mean there isn't a flyout, but there should be, the Freescale thing is there, but nothing happens). I don't care about the labels per se, but I use keyboard shortcuts a lot and without a label there is nothing to bind it to (I want to replace S for the normal scale tool πŸ˜„ ).
              to James, Kanonbal and other Mac users.
              Let's take things in order
              1. on the WebDialog UI, could anyone post a screenshot of the half visible dialog box.
              2. For the menus, FreeScale installs by default in Tools > Fredo6 Collection > FreeScale. From there, there are four command menus (i.e. the FreeScale tools), and 6 support menus (About..., support web, documentation, video, Translation and Default Parameters). Which ones do you see, and which ones do you not see ?. A screenshot would help as well.
                Additionally:
              • Do you get text in the status bar?
              • do you see the menus for LibFredo6 Settings (in Windowsmenu)?
              • could you switch to French, and advise if you see the FreeScale menu items?
              1. For the "labels", are you talking about the toolbar icon tooltips, or about the tooltips that appear at the cursor location (there may be a problem on Mac because may I use 2 lines tooltip)?
              Thanks very much for your feedback. As most of the problems mentioned are in functions managed in my Shared Library LibFredo6, I hope that fixing them for FreeScale will help to have a smoother release for my other plugins on Mac.
              • fredo6F Offline
                By the way, could some Mac User open the Ruby console and type the following command.
                FreeScale;;T6[;FSC_FREE_Menu]
                • CadFatherC Offline
                  CadFather
                  ..more icons coming soon.. as i can πŸ˜„
                  • ely862meE Offline
                    ely862me
                    http://www.messentools.com/images/emoticones/varios/www.MessenTools.com-Varios-big-179.gif
                    Manny thanks.....
                    Elisei
                    Elisei (sketchupper)
                    Come and See EliseiDesign
                      CadFather
                      Hi Matt, not the best, but here's a couple to start.. πŸ˜„
                      not much on line lately but i'll be back sometime soon - (got a couple of surprises)
                      Toolbar icons.rar
                        James Fraser
                        Hi Fredo, got some pictures for you.
                        This is what you get with 'Customise Toolbar', so what you would see if they were on the normal toolbar (instead of floating, like they do on the Mac).
                        This is the drop-down from the plugins menu, showing the blank lines (which do work if you click on them and are ticked if you have already selected the tool from the toolbar).
                        The context menu failing to fly out
                        Mouseover works
                        The real problem is the shortcuts
                        The half covered preferences window. The bottom bit scales with the window, always covering half, if you stretch to twice the length you can see everything.
                        I hope that makes things a bit clearer. I did try the Ruby thing as well and it returned Free Scale, which is confusing.
                        I noticed in FreeScale.def that there was the line:
                        T_DEFAULT_ToolbarName = "Freescale"
                        I tried capitalising the S, but it seemed to make no difference.
                        I did change the language to both French and Spanish and the problems appeared to be the same.
                        Also, Tab doesn't work, but I can right-click for the dimensions box. I am not too bothered about that, but I thought you might want to know anyway. It might just be bound to something else on the Mac, I will let you know if I find it.
                        Thanks again for a great plugin, it is now my default scale tool πŸ˜„
                        http://www.FormFonts.com
                          James Fraser
                          Oops. Sorry, I forgot to mention that all the instructions show up fine in the status bar. I think everything works fine, apart from the bits in the screen caps.
                          • EdsonE Offline
                            Edson
                            james,
                            i have had problems with non appearing icons (which nonetheless worked if you clicked on the blank space) with other scripts. in most cases the problem went away with simply moving the script to user/library/application support/google sketchup/sketchup/plugins.
                            for some reason 2 plugins folders are created when you install skp on a mac. some scripts work better at the user level plugins folder.
                            http://www.mahfuz.arq.br
                              James Fraser
                              Thanks Edson. I gave that a go, even migrating all my plugins, but that didn't seem to work this time. It did make me think about permissions and ownership, but they all seem fine. I think the rubies only need to be readable, as SU just reads them on startup and presumably then runs things from memory.
                              My own scripts work fine, despite having no execute permissions (644, must be something to do with Aquamacs, I will have to check the settings).
                                Matt666
                                As always, excellent work, CadFather! Thank you!
                                My scripts
                                • O Offline
                                  otb designworks
                                  I couldn't help but notice that James' toolbar has four icons.
                                  Mine only has two! And not just 2 blank and 2 showing, but only 2.
                                  The rest of my behaviors match what James has posted.
                                  I, too, migrated all of my plugins to the user library from the root library with no noticeable change to Freescale.
                                  Cheers, Chuck
                                    James Fraser
                                    Mine originally had two, but I changed it to show all of them down at the bottom of the preferences. You have to scroll down and resize the window in order to see it. I'll use the normal two more, but the target ones will be handy to have around.
                                    • O Offline
                                      otb designworks
                                      Thanks James, I don't know how I missed that!
                                      Cheers, Chuck
                                      • W Offline
                                        watkins
                                        Dear James,
                                        Can you be a bit more specific about where the icons are? I'm not too sure what you mean by 'at the bottom of the preferences'.
                                        Regards,
                                        Bob
                                          johnsenior1973
                                          @watkins said:
                                          Dear James,
                                          Regards,
                                          Bob
                                          Tools > Fredo6 Collection > Freescale > Default Paparameters
                                          Scroll down to Icons visible in the toolbar, click on the two that are unchecked.
                                          • W Offline
                                            watkins
                                            Dear Johnsenior,
                                            Many thanks,
                                            Bob
                                            • 6 / 7
