    30 Watt Fishbulb
    32 Posts 11 Posters 4.2k Views 11 Watching
    • GaieusG
      If you plug the bulb in, an easy way tocook a fish soup... 😉
      • E
        ENG. YASEEN
        **It's amazing idea and work ،In particular the 2th photo
        thank's**
        My Website:
        http://xyz4studio.blogspot.com/
        • P
          princedragoncok
          @solo said:
          Hope you do not mind, I liked the idea so much that I thought I'd give it a go too.
          I used Vue for the render.
          Not at all, v nice. Your fishbulb appears to be a lot more robust than mine! I have to say i'm interested in trying out vue. So a few quick questions for the vue master: whats the learning curve like? and which package would you reccommend (as there seems to be loads). Thanks
          • EarthMoverE
            EarthMover
            I think both renders would serve well with a touch of caustics reflection on the ground as the light passes through the water in the bulb.
            Content Creator at Skapeup
            • C
              Click Draw
              Very nice renders both. When rendering, do you set the glass material to 0% opacity and reflection to 100%?
              Jeff
              Have I mentioned how much of a laugh I get out of some of the Signatures on here!
              • P
                princedragoncok
                Totally agree, but I don't think I have that option with Hypershot? correct me if I'm wrong
                As far as I know, v-ray is the only renderer supporting caustics at the moment.
                Jeff
                Well with hypershot its simply a matter of applying a default glass material that comes with the program. If I was to make glass with Podium however I'd probably make a translucent material, set it to 10-15% opacity, and 85-90% reflection.
                • C
                  Click Draw
                  Well....I finally bit the bullet. I just bought VRay for SU. I'm feeling a bit sick all of a sudden. I better take next week off from work ...LOL.
                  Jeff
                  • P
                    princedragoncok
                    Jeff
                    Nah your going have to work overtime now! V-ray is the benchmark so definitely not a bad investment. Learning curve is a bit horrible though, so brace yourself for a stressful first few renders. Hmm I'd actually like to try this current render out with v-ray.. or maybe let someone else do it - how about you clickdraw?
                    • C
                      Click Draw
                      Sure PDC,
                      I'll give it a go for sure. I'm just waiting for my activation code via e-mail but once I have it I'm in! Post your model for me or PM me. Thanks for the chance 😄 .
                      Jeff
                      • soloS
                        Jeff a Vray render of this would be great, nice one to sharpen your teeth on.
                        Vue does caustics too, I chose not to have them as they complicated the scene to much (looked very busy)
                        Vue's learning curve is hard to assess, I learned it so long ago, on version 4, it was easy as I only used it to create terrains for use in Max, and over time I started to learn it without trying to learn it. Vue is pretty straight forward really, the only difficult part is the node based functions IMO.
                        • P
                          princedragoncok
                          Cheers for the info solo. The scene is available to everyone to download for seven days.
                          https://www.yousendit.com/download/WnBSVWRqTStoMlVLSkE9PQ
                          • EarthMoverE
                            EarthMover
                            Hey prince
                            Thanks for sharing the model. I ran the bulb through SDS with 1 iteration and then gave it a go with hypershot. Render took about 3 min.
                            • soloS
                              Vue again.
                              http://img294.imageshack.us/img294/5427/fishbulbrg0.jpg
                              added a 'green' one too.
                              http://img172.imageshack.us/img172/172/flourescentvuese3.jpg
                              • EarthMoverE
                                EarthMover
                                Pete, that's great!! The caustics make a world of difference. Did they add a lot of render time?
                                • soloS
                                  Actually it was faster this time as I reduced the radiosity (I had radiosity and skydome in first one) and slightly increased the ambience, so the render was slightly faster, I did enable the 'accurate caustics' in render settings.
                                  • K
                                    kwistenbiebel
                                    Glass and fluids in glass are extremely difficult to render in Sketchup (if not impossible).
                                    The normals are difficult to control.
                                    Here's my try, but it is completely wrong:
                                    http://i140.photobucket.com/albums/r3/kwistenbiebel1/bulb-a.jpg
                                    • C
                                      Crazy Eyes
                                      I thought that I would add a V-Ray version. This is set in exactly the same scene as you uploaded it.
                                      It took about 30 minutes to render on my twin core duo.
                                      1st attempt
                                      I wasn't too happy with my result, so I thought I'd try again.
                                      The fish still looks like it's been pasted in afterwards...!
                                      2nd attempt
                                      Some people are lovers, some are fighters, if you love to fight, fight for love!
                                      • soloS
                                        http://img89.imageshack.us/img89/8373/sushirx9.jpg
                                        • EarthMoverE
                                          EarthMover
                                          🤣 That's just wrong!
                                          • EarthMoverE
                                            EarthMover
                                            Not to beat a dead horse, but I had this idea......
                                            http://img204.imageshack.us/img204/7373/64835326bg5.jpg
