    30 Watt Fishbulb
    32 Posts 11 Posters 4.2k Views 11 Watching
    • B
      bubbalove
      Neat concept! Could be smoother though...
      "Success consists of going from failure to failure without loss of enthusiasm." - Churchill
      • EarthMoverE
        EarthMover
        PDC - Neat idea. Increase the number of bounces to get rid of some of the artifacts you see.
        Content Creator at Skapeup
          ScottPara
          Cool concept but if you are going to have the lightbulb as the main focal point then a high poly lightbulb is a must.
          Scott
          Love the fact that some HATE my avatar.....
          • soloS
            That's pretty cool and I must agree getting a higher polygon bulb will help, maybe just apply one iriteration of SDS to smooth it.
            • P
              princedragoncok
              Yeah I agree everyone. The bounces were already set at their highest, shadow quality not though. I tried 1 iriteration and in fact it worked the first time but I got greedy and went for 2 and messed things up. Now 1 doesn't seem work anymore (at least with regard to texture preservation).. will try again. Thanks for the feedback!
              • soloS
                Hope you do not mind, I liked the idea so much that I thought I'd give it a go too.
                I used Vue for the render.
                http://img207.imageshack.us/img207/2756/fishbulbwc4.jpg
                • GaieusG
                  If you plug the bulb in, an easy way tocook a fish soup... πŸ˜‰
                  • E
                    ENG. YASEEN
                    **It's amazing idea and work ،In particular the 2th photo
                    thank's**
                    My Website:
                    http://xyz4studio.blogspot.com/
                    • P
                      princedragoncok
                      Not at all, v nice. Your fishbulb appears to be a lot more robust than mine! I have to say i'm interested in trying out vue. So a few quick questions for the vue master: whats the learning curve like? and which package would you reccommend (as there seems to be loads). Thanks
                      • EarthMoverE
                        EarthMover
                        I think both renders would serve well with a touch of caustics reflection on the ground as the light passes through the water in the bulb.
                        • C
                          Click Draw
                          Very nice renders both. When rendering, do you set the glass material to 0% opacity and reflection to 100%?
                          Jeff
                          Have I mentioned how much of a laugh I get out of some of the Signatures on here!
                          • P
                            princedragoncok
                            Totally agree, but I don't think I have that option with Hypershot? correct me if I'm wrong
                            As far as I know, v-ray is the only renderer supporting caustics at the moment.
                            Jeff
                            Well with hypershot its simply a matter of applying a default glass material that comes with the program. If I was to make glass with Podium however I'd probably make a translucent material, set it to 10-15% opacity, and 85-90% reflection.
                            • C
                              Click Draw
                              Well....I finally bit the bullet. I just bought VRay for SU. I'm feeling a bit sick all of a sudden. I better take next week off from work ...LOL.
                              Jeff
                              • P
                                princedragoncok
                                Jeff
                                Nah your going have to work overtime now! V-ray is the benchmark so definitely not a bad investment. Learning curve is a bit horrible though, so brace yourself for a stressful first few renders. Hmm I'd actually like to try this current render out with v-ray.. or maybe let someone else do it - how about you clickdraw?
                                • C
                                  Click Draw
                                  Sure PDC,
                                  I'll give it a go for sure. I'm just waiting for my activation code via e-mail but once I have it I'm in! Post your model for me or PM me. Thanks for the chance πŸ˜„ .
                                  Jeff
                                  • soloS
                                    Jeff a Vray render of this would be great, nice one to sharpen your teeth on.
                                    Vue does caustics too, I chose not to have them as they complicated the scene to much (looked very busy)
                                    Vue's learning curve is hard to assess, I learned it so long ago, on version 4, it was easy as I only used it to create terrains for use in Max, and over time I started to learn it without trying to learn it. Vue is pretty straight forward really, the only difficult part is the node based functions IMO.
                                    • P
                                      princedragoncok
                                      Cheers for the info solo. The scene is available to everyone to download for seven days.
                                      https://www.yousendit.com/download/WnBSVWRqTStoMlVLSkE9PQ
                                      • EarthMoverE
                                        EarthMover
                                        Hey prince
                                        Thanks for sharing the model. I ran the bulb through SDS with 1 iteration and then gave it a go with hypershot. Render took about 3 min.
                                        • soloS
                                          Vue again.
                                          http://img294.imageshack.us/img294/5427/fishbulbrg0.jpg
                                          added a 'green' one too.
                                          http://img172.imageshack.us/img172/172/flourescentvuese3.jpg
                                          • EarthMoverE
                                            EarthMover
                                            Pete, that's great!! The caustics make a world of difference. Did they add a lot of render time?
